Try to get Tonneau cover installed at factory or wait for aftermarket?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LtTaco, Oct 3, 2015.
  1. Oct 23, 2015 at 10:24 AM
    #161
    NV_Tacoma
    NV_Tacoma Well-Known Member
    Paul
    Northern Nevada
    2013 MGM ACLB TX Off Road
    2016 White DCSB TRD Off Road (Sold)
    You're welcome, I wasn't sure if someone else had mentioned it yet. Once I did that I've actually started to like the cover.
  2. Oct 23, 2015 at 10:27 AM
    #162
    tincan
    tincan Well-Known Member
    Jim
    Tulsa, OK
    2018 CEMENT 7544, OF, TP
    Yep..good eye. The rubber foot on the Tonneau was resting firmly on the cleat holding it up just enough to let in water. It hits in cleat position 1 and position 2 if you are counting from back to front on the rail.
    Thanks!
    NV_Tacoma[QUOTED] likes this.
  3. Oct 23, 2015 at 10:31 AM
    #163
    NV_Tacoma
    Paul
    Northern Nevada
    Glad I was able to help someone out with that:thumbsup:
  4. Oct 23, 2015 at 10:33 AM
    #164
    tincan
    Jim
    Tulsa, OK
    Yes, I've been pretty critical of it...but it is solid. Not ideal, but I'm learning to appreciate it. I had to take it off a couple times already to carry loads. I use my truck daily for work, and now that I have it somewhat organized with cargo bar and my gear it's nice to have.
  5. Oct 23, 2015 at 10:33 AM
    #165
    -dustin
    -dustin Well-Known Member
    Leander, TX
    2020SWDCSBTRDPROFTW
    can the tonneau be removed and stored? easily?
  6. Oct 23, 2015 at 10:37 AM
    #166
    tincan
    Jim
    Tulsa, OK
    You need a 12mm socket and it folds up with straps to keep it together. There is a third door catch that needs to be released and then you just pick it up. It's bulky and heavy, but I lift it off by myself. ...you have to be standing in bed to do it alone though.
  7. Oct 23, 2015 at 12:20 PM
    #167
    PJnc284
    PJnc284 Well-Known Member
    Garner, NC
    2016 Tacoma TRD Off Road 4x4
    Not sure the placement matters. I didn't have the cleats in and was still getting water in the bed. All really a moot point anyways as the manual even says it's not watertight and to take care with stuff that can be damaged by water.
  8. Oct 26, 2015 at 2:45 PM
    #168
    Bumrush
    Bumrush Well-Known Member
    Brian
    Middle TN
    16 TRD OR SB quicksand
    Is this how the factory covers are installed?
  9. Oct 26, 2015 at 3:02 PM
    #169
    VetteVert
    VetteVert Well-Known Member
    '17 Storm Trooper DCSBOR
    Yes
  10. Oct 26, 2015 at 3:06 PM
    #170
    TacoBella
    TacoBella Well-Known Member
    Tom
    2016 Tacoma (SOLD) leased RTL-E Ridgeline
    AVS Bug Deflector. TruXedo Lo Pro
    YEP and I am glad I did not order one with a tonneau that needs that kind of cutting and messing with ti install. Mine will install using clamps on the rails.
  11. Oct 26, 2015 at 3:06 PM
    #171
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    Looks like a subpar afterthought as far as aesthetic finish goes.
    bdunna likes this.
  12. Oct 26, 2015 at 3:08 PM
    #172
    Aaronp18
    Aaronp18 Well-Known Member
    Vancouver, BC
    2016 White Tacoma TRD Sport 4x4 DCLB
    I think I'm going to wait for the BakFlip F1, they don't need to cut anything for that install do they?
  13. Oct 26, 2015 at 3:11 PM
    #173
    TacoBella
    Tom
    Don't know. I will be ordering a Truxport when they are ready. I prefer the vinyl to the hard stuff. For weight reasons as well as being able to use the whole bed or a portion.
    http://www.truxedo.com/truxport/land.php
  14. Oct 26, 2015 at 3:15 PM
    #174
    Aaronp18
    Vancouver, BC
    Had that exact cover on our F150, I did like it but I prefer the hard covers.
    The BakFlips do allow you to use all or a portion of the bed as well. Sure when you fold it all the way up it blocks your back window but if i need to use the full bed chances are whatever is in there will be blocking my view regardless! Plus, have a backup camera if an when I need to reverse with a full bed.
    EDIT:
    By looking at their website they have, in the past, used the existing deck rail system in the Tacomas to install the covers. That's encouraging.
    TacoBella[QUOTED] likes this.
  15. Oct 26, 2015 at 6:54 PM
    #175
    Bumrush
    Brian
    Middle TN
    So I think it comes down to the bak flip or the fold a cover. I like the functionality of the fold a cover but I like the ability to use the entire bed with the bak flip. Torn
    TacoBella likes this.
  16. Oct 26, 2015 at 7:05 PM
    #176
    be_unscared
    be_unscared Wardaddy
    Brendan
    So Cal
    2016 TRD Sport 4X4
    Just to inform those who are considering getting the factory cover… If it is not on your truck already, I was told it cannot be ordered. I tried to buy one since none of the trucks in my color came with them and was told I had to buy aftermarket and that the factory would not ship these out individually. This sounds made up, but its something to be aware of. If that is the cover you want, get it on the truck when you buy or (supposedly) not at all.
  17. Oct 26, 2015 at 7:06 PM
    #177
    VetteVert
    Not made up. Posted repeatedly. Look how they have to chop up the rails to install it...
  18. Oct 26, 2015 at 7:07 PM
    #178
    Bumrush
    Brian
    Middle TN
    Prolly cause no one else will cut the bed all up like that.
  19. Oct 26, 2015 at 7:35 PM
    #179
    Larry
    Larry CARL
    CARL
    If I buy a gen3. It WILL have the factory cover. I like it a lot.
  20. Oct 26, 2015 at 7:42 PM
    #180
    be_unscared
    Brendan
    So Cal
    2016 TRD Sport 4X4
    Go for it, brother. It just didn't seem to me like Toyota was doing us any favors by throwing it on there, price-wise. For about the same price, we could find one that suits our specific needs and do an install without messing with any of the factory settings. It looks smooth, but if you haven't seen one on the lot that they left in the "open" position for too long, think twice. As I drove away in my new truck, I noticed the truck I test drove the day before now had the cover down. The cover was massively warped and did not look good at all… and this was BRAND.NEW. Just my .02 but I decided to look elsewhere. Yours is going to look AMAZING!
    BTW if I can swing by the dealer this week and snap a pick of that cover-warp, I will.
