tryin to get some ideas
Discussion in '2nd Gen. Tacomas (2005-2015)' started by basktaco, Oct 17, 2008.
  1. Oct 17, 2008 at 6:39 PM
    basktaco
    basktaco [OP] Well-Known Member
    Bliss, Idaho.
    2012 SR5 DCLB
    duratracs/ultra phantom wheels/plasti derped all the chrome
    hey guys i am getting ready to order a 3" lift for my truck. i cant decide if i want 285's or 265's. i want my truck to look good but i also want to keep a little bit of my gas mileage. if any of you have pix of trucks with a 3" and 265s or 285s would you mind posting them for me??
    thanx again guys i really appreciate it
  2. Oct 17, 2008 at 6:44 PM
    zero niner
    zero niner romeo oscar bravo
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    All Pro front plate bumper, 5100 1.75" Bilstein up front, 1" block and TSB in rear, UWS lowpro tool box, Toyota Side Steps
    Just wanted to state that you can get different heights of 285 and 265 based on whether you get the next number a 70 or 75 as this is actually the height factor of a tire. The 285/265 only indicates the width of the tire. Hope that helps cause you can get either a 31" or 32" with 265 and a 32" or 33" with a 285. Just some things to think about.
    Rob
  3. Oct 17, 2008 at 6:52 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    the width is whats really gonna kill the mileage of the tires...that and weight of them
  4. Oct 17, 2008 at 6:59 PM
    basktaco
    Bliss, Idaho.
    2012 SR5 DCLB
    hey thanks zero niner, i gues i should have been a little more specific. right now i have 265/75/16 toyo mts and my mileage went down just because of those tires because they are so heavy. i wasnt really thinking when i bought them one of those impulse buys ya know. anyways i was thinking about getting a little bit bigger and lighter tire so maybe my gas mileage will stay about the same. what do you guys think?
  5. Oct 17, 2008 at 8:04 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Well you can always go skinny and tall and remember that different load rating tires are different weights too. I use Tirerack.com for comparisons and getting the weights and dimensions. If you're concerned with the weight and mpg, sounds like you may be looking at getting a 265/75R17, this way you have the height you're looking for, an inch taller and then just look at getting some 17" rims. Or you could play with the tire calculator and see what will work for you.
    http://www.tacomaworld.com/forum/tirecalc.php
    Best of luck finding your tire, post up your decision and pics when it's all done.
    Rob
  6. Oct 17, 2008 at 8:17 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Hey, I just noticed you put on bigger tires with your stock lift, do you have pics you could post of your truck with the tires? I have the 5100's all around and only a 1.75" lift in front and 1" in back and was thinking of just going to your tire size, 265/75R16. Thanks in advance.
    Rob
    Oops, just saw your post. Are those black wheels aftermarket? Or did you paint them, black wheels always make the tires look so much bigger! Looking good!
  7. Oct 17, 2008 at 8:31 PM
    The_Hodge
    SC
    i'm running 255/75/17's (32x10) on my truck and i still get 19 mpg w/ it...it'll get better once i get some more miles on it (4400 or so now) and if they werent so damn heavy. i was getting 20...sometimes 21mpg in the prerunner w/ the same setup
  8. Oct 17, 2008 at 9:07 PM
    basktaco
    Bliss, Idaho.
    2012 SR5 DCLB
    this is my truck now. 1 1/2 inch leveling kit with 265/75/16 toyo mts. And yes those are aftermarket wheels
  9. Oct 17, 2008 at 9:09 PM
    zero niner
    Rob
    Pacific Northwest
    09 DC SB Prerunner
    Sweet! What are those wheels? I really like them, specs (price, size and backspace if you can)? Thanks in advance.
    Rob
  10. Oct 17, 2008 at 9:11 PM
    basktaco
    Bliss, Idaho.
    2012 SR5 DCLB
    and if they werent so damn heavy. i was getting 20...sometimes 21mpg in the prerunner w/ the same setup[/quote]
    tell me about it these toyo mt are a really good tire but they weigh a ton. you dont really need a 10 ply tire on a tacoma but they just look so cool. my plan is to keep these tires for winter and get some new lighter ones for summer
