Trying different grades of fuel on 4th gen
Discussion in '4th Gen. Tacomas (2024+)' started by tacoscott24, Jul 2, 2024.
  1. Jul 2, 2024 at 12:42 PM
    tacoscott24
    tacoscott24 [OP] Active Member
    24 SR5 DBLCAB
    Has anyone noticed and benefits of using higher octane fuel in their 4th gen Tacoma? I know the owner’s manual states a minimum of 87 just curious to see if anyone has had any real world results of different grades.
  2. Jul 2, 2024 at 12:56 PM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Oh u just opened a can of worms … here we go again … on octane…:facepalm:
    dleithaus, Squirt, usmc2msu and 11 others like this.
  3. Jul 2, 2024 at 1:03 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    What the door say?
    Stevie17 likes this.
  4. Jul 2, 2024 at 1:20 PM
    Newwt
    Newwt Well-Known Member
    Tampa, FL
    21 SUPER WHITE TRD OR 4X4 , 24 BCM TRD OR
    I started using 93 and gained about 15hp
  5. Jul 2, 2024 at 1:22 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    You realize that a 4th gen with a turbo motor is likely to respond well to higher octane, right? They don't want to advertise them as needing high octane because it could deter buyers, so they tune it for 87. Doesn't mean it won't be better on higher octane, and this is a turbo motor so that is very likely.
    LawTaco, Squirt and Stevie17 like this.
  6. Jul 2, 2024 at 1:27 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    It should be in the manual, but it is amazing these modern tunes.
    Wife's car has a turbo. The manual clearly says that the rated horsepower is only achieved on >91 octane, but that it is perfectly fine to run on anything above 86.
  7. Jul 2, 2024 at 1:28 PM
    trey_is_a_jedi
    trey_is_a_jedi Active Member
    I have run through tanks of 87 and tanks of 93. 93 the truck gets better mileage on for me it was ~1.5mpg better overall for my mostly city driving.
  8. Jul 2, 2024 at 1:33 PM
    BLtheP
    Plano, TX
    It's weird, most manufacturers do put that in the manual for the cars shipping with turbos. I specifically looked for that and Toyota mentions nothing, but I would guess that it's still the same concept, where it will run fine on 87 and above but probably will perform better with higher octane. I know for sure that Ford puts that in their manuals.
  9. Jul 2, 2024 at 1:36 PM
    Bitflogger
    Bitflogger Well-Known Member
    2024 TRD OR long bed
    What methods or instrumentation were able to report that?
    Seeing @tacoscott24 I'm guessing it is not a hybrid. My big curiosity here for not yet decided on what we'll buy is how the hybrid powertrain does with lower octane. That's a turnoff for me, and sure is a surprise that it is not for my wife's interest in the Land Cruiser.
    Our German car with turbo doesn't require high octane and most all the time it is just not worth it to pay the extra amount.
  10. Jul 2, 2024 at 1:38 PM
    Clearwater Bill
    Billy
    Largo Florida
    And how does that work on on a cost per mile with the price delta of the 87 vs 93?
    usmc2msu likes this.
  11. Jul 2, 2024 at 1:45 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I can't say for sure about the 24 Tacoma, but generally speaking a higher octane gas should pick up a little more HP, and run cooler with turbo engines. I can't see why Toyota should be any different. You won't see any better fuel mileage so a little more power will cost you more at the pump.
    Ford has been putting turbo engines in their trucks since 2011. For normal driving they claim they are fine with 87 octane but require 91 octane if you're towing. Some of the problems with Ford's engine overheating can be traced back to guys trying to tow with 87 octane fuel in them.
    Squirt likes this.
  12. Jul 2, 2024 at 1:57 PM
    tacoscott24
    24 SR5 DBLCAB
    I did find in the owners manual 87 or higher. My truck is a non hybrid btw and the thing that made me think of this was the simple fact that it’s turbocharged with a 11:1 compression ratio so would there be any benefit from the higher octane fuel. Hence towing or “spirited” driving as Toyota calls it.
  13. Jul 2, 2024 at 2:10 PM
    Newwt
    Tampa, FL
    a dyno
  14. Jul 2, 2024 at 2:13 PM
    Jacob06
    Jacob06 Well-Known Member
    Atlanta
    2024 TRDOR 6MT
    Mine seems to show a higher miles to empty after a fillup with 89 octane.
    I tried 93 a few times but there doesnt seem to be any benefit, neither MPG or seat of the pants.
    I wasn't very scientific about it, but if there was a benefit to 93 octane I needed it to be so obvious that it would be worth the $$$
  15. Jul 2, 2024 at 3:16 PM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    Your truck has no idea what the octane rating is in the tank. That distance figure is dependent on the mileage you got with the last tank.
  16. Jul 2, 2024 at 3:37 PM
    Jacob06
    Atlanta
    2024 TRDOR 6MT
    Well maybe it should!
    I've heard that as well
    Still, if its dependent on the mileage of the last tank and 89 is what I've been using, would that mean I'm getting better mpg with 89?
    Highest I've got that miles to empty to show is 300 miles. Usually 296 or 297 but I've seen 300 twice!
    Highest MPG that computer has shown me was 23.1
    I'm all for putting better fuel in it if it either performs better or is more efficient
  17. Jul 2, 2024 at 3:40 PM
    6starwars
    6starwars Well-Known Member
    VA
    24 TRD SPORT DCSB 4x4
    My truck knows nothing. I am approaching 2k miles, and it has never shown more than 280 miles to empty after fill up. I know there’s another thread on this. I don’t drive for the mpgs, but I haven’t been flooring it too much either.
  18. Jul 2, 2024 at 4:08 PM
    Rocko
    Rocko Well-Known Member
    Washington
    2024 TRD Auto
    I'll try premium the next few tanks. It will likely take a few trips for the ECU to recognize the increase in octane. I track mpg per trip, and have a long commute, so I have a good feel as to what I should be getting. I did switch to midgrade after the first couple tanks, and the motor did seem to quiet down, I think I was hearing very slight knocking on occasion. Obviously 87 is fine, but I will give premium a shot for a bit.
  19. Jul 2, 2024 at 4:13 PM
    Want-a-taco
    Want-a-taco Well-Known Member
    New Brunswick, Canada
    2024 TRD Offroad 6MT black
    I’m using 87 in the summer because I burn 2 tanks or more a month.
    I use 93 in the winter because I use 1 tank every 2 months and in the province of New Brunswick, the 87 has up to 10% corn in it which has a 1 month shelf life.
    Small engines will never taste corn.
    PDKTaco likes this.
  20. Jul 2, 2024 at 4:17 PM
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    Yep. The only non-87 octane fuel I buy is the 91 octane non-ethanol premium I can get at the pump. I use it exclusively for my small lawn / fun toys. I'll never put ethanol blends in those things again.
