Trying to compare apples and oranges
Discussion in 'Lighting' started by Sky King, Jan 22, 2013.
  1. Jan 22, 2013 at 1:07 PM
    Sky King
    Sky King [OP] Well-Known Member
    Sam
    Memphis, Tn
    07 PreRunner SR5
    Serious sound deadening in the cab and extensive audio system.
    Welllll not actually. You can not run DC through a transformer. (well you can but all you will get out of it is smoke) You have to convert it to AC, run it through the transformer to step it up, then through a rectifyer to change it back to DC. Just get the GE Q4631s, they run off 12 volts and they are 50 watts more than the H3s you mentioned. Just need some heavy wire because they are going to draw 20 amps for each bulb.
  2. Jan 22, 2013 at 1:13 PM
    Sky King
    Sam
    Memphis, Tn
    07 PreRunner SR5
    Think about your basic electicity. You don't get something for nothing. Yes stepping up the voltage on the secondary side will reduce the current draw BUT to get 24 volts at 16.66 amps out the secondary, when you put in HALF the voltage on the primary, you will have to DOUBLE the current into the primary. BUT you still have to run the DC through an inverter to get the AC that you will need to run through the transformer.
  3. Jan 22, 2013 at 7:10 PM
    acdronin
    acdronin Well-Known Member
    So if I am correct here, I can run those on a 12 volt system right?, it would just be a tad bit dimmer?
    EDIT: Nevermind, read your post above:)
  4. Jan 22, 2013 at 7:21 PM
    acdronin
    Those are sealed beams, look like they might fit into my Hella 500 housings. IDK.
    Yeah as I researched it I found all that out, kinda complicated but doable for an insane person (like me). Four spots are the way to go IMO, LED's just don't compare with the throw of good, big reflectors. When you want to see WAY THE HELL DOWN THE ROAD and all the way from side to side. What you're looking for is the same thing I'm lookin for, movement and the reflection of animal eyes.
  5. Jan 22, 2013 at 7:58 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Good point :D
  6. Jan 23, 2013 at 6:43 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Haven't had a problem myself, but our max here is 70mph.
    However, I did get myself a small 2 point buck this year with the fender of our ambulance, so I know exactly what you're talking about when you say there's only one thing on their mind. And god damn are they dopey around that time.
