Trying to decide on a lift...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Evan_P, Jun 8, 2021.
  1. Jun 8, 2021 at 11:19 PM
    Evan_P
    Evan_P [OP] Well-Known Member
    Evan
    Hillsboro OR
    2020 Voodoo Blue TRD Off-Road
    I know, another one of these threads. I hate to be that guy, just trying to make my mind up. I am starting to plan out the next mods for the truck, which is gears and a lift. I think I have settled on 5.29's as I will be going up to a 32-33" tire when the time comes for new ones (currently on 265/70R17), and I plan to add some weight to the truck. Skids, sliders, bed rack and tent ect. plus I will be hauling my KTM 690 on the back (~325lb) when going on camoing trips. I have narrowed my choice down to as follows:
    #1: OME BP51 with OME UCA's and HD Dakars (leaning towards the most due to adjustability)
    #2: ICON Stage 8 kit with tubular UCA's and RXT leaf pack
    I am aiming for 2"-2.5" of lift with the ability to carry the weight without sagging, hence Dakars or RXT's, and I want to maintain a good ride. I am leaning towards the BP-51 setup due to the overall adjustability offered while also maintaining good ride quality.
    Looking for experience with either kit. Thanks in advance.
    71tattooguy likes this.
  2. Jun 9, 2021 at 2:50 AM
    Coyote501
    Coyote501 Well-Known Member
    Ohio
    2019 Barc Red AC
    Too many horror stories about lifts..........
  3. Jun 9, 2021 at 7:17 AM
    Evan_P
    Evan
    Hillsboro OR
    Example? Seems to me that a large portion of Tacoma’s are lifted in some sense and I don’t really see horror stories popping up.
  4. Jun 9, 2021 at 8:11 AM
    skibums_toyo
    skibums_toyo Well-Known Member
    Kevin
    2018 Tacoma TRD Off-Road Cement
    There are a couple threads about getting vibrations after lift install. I'd recommend planning on throwing an ECGS Clamshell bushing in while you're getting the lift installed. Just save some time and headache. But as far as the lift goes stick to what works with your budget. Both of those set ups will be pretty sweet, have heard great things about both. I'd probably lean more towards the RXT leaf packs over the OME's whatever direction you go with. You may also want to throw on some bump stops as well. Just my two cents.
  5. Jun 9, 2021 at 8:42 AM
    Evan_P
    Evan
    Hillsboro OR
    Busing is getting done when I hear it. That’s coming before the lift. I’ll look into bump stops.
