Trying to disable the ANC (noise cancelling)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by brianhammster, Jan 22, 2022.
  1. Jan 22, 2022 at 8:00 AM
    brianhammster
    brianhammster [OP] New Member
    I was wondering if anyone has info on disabling the noise control mics ..the ANC...
    My new subwooofer has problems competing with it...
    I have a 21 tacoma TRD
    Thanks
  2. Jan 22, 2022 at 8:02 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    What have you tried? What head unit is installed?
  3. Jan 22, 2022 at 9:13 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    There’s noise control mics? They must not work very well
  4. Jan 22, 2022 at 9:20 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    Where are the ANC mics located?
  5. Jan 22, 2022 at 1:52 PM
    brianhammster
    It's the factory head unit 21 tacoma
  6. Jan 22, 2022 at 2:06 PM
    Siblue
    So Cal
    25 Tundra TRD pro
    Do you have premium audio?
    I plan on adding a sub also.
  7. Jan 22, 2022 at 2:35 PM
    GrundleJuice
    Michigan
    2016 TRD Bro
    There is more than one factory head unit. Premium audio and navigation?
  8. Jan 23, 2022 at 1:24 PM
    metalmule
    metalmule Well-Known Member
    21 DCSB
    As far as I know the Tacoma does not come with ANC. Is it the factory subwoofer?
    Tacosha likes this.
  9. Jan 23, 2022 at 1:32 PM
    Siblue
    So Cal
    25 Tundra TRD pro
    That’s what I thought as well.
    The audio does not have any visible mics.
  10. Jan 23, 2022 at 1:43 PM
    Shellshock
    Iowa
    I don’t believe there is ANC but there is a thing for auto volume adjustment
  11. Jan 28, 2022 at 6:43 AM
    metalmule
    21 DCSB
    I'm wondering if the subwoofer is out of phase or if the gain has not been set correctly.
  12. Jan 28, 2022 at 6:53 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    The factory head unit has 2 issues, the rear speaker outputs suck, take bass input off the front and as volume gets higher the bass rolls off to protect the factory speakers. I have noticed this effect with my 10" sub set up. I am considering using a AudioControl processor with Accubass to combat this bass roll off.
    There are no ANC in previous models, I don't think there are any in later models.
    metalmule likes this.
  13. Jan 28, 2022 at 3:06 PM
    brianhammster
    ya I have the LC2I runing to my Rockford Fosgate 300x4.
    When I try and get a voltage reading from the RCA MAin out of the LC2i with the HU at 75%ish... i barely get 2 volts... should it be at least 7?
  14. Sep 1, 2024 at 6:47 AM
    Screaminr1
    Screaminr1 Member
    2023 Tacoma SR
    I am using a Lc7i and still have have engine noise or static coming through my speaker. Also does anyone know why you lose your microphone and back up camera after installing aftermarket system
  15. Sep 2, 2024 at 9:26 AM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    I would check your grounds and make sure they are clean. This can cause noise.
    You can get adapters for the back up camera to work with aftermarket head units. And there is a microphone that you can buy that fits in the factory spot. It isn't perfect but it works well enough.
    Chew likes this.
  16. Sep 2, 2024 at 9:56 AM
    Screaminr1
    Screaminr1 Member
    2023 Tacoma SR
    Ok thanks
  17. Sep 4, 2024 at 5:04 AM
    Screaminr1
    Screaminr1 Member
    2023 Tacoma SR
    Microphone and back up camera are working had to check the plugs under the passenger seat.
