Trying to figure out Grille Lights wiring for DRL
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hcenteno21, Jan 22, 2020.
  1. Jan 22, 2020 at 10:10 AM
    hcenteno21
    hcenteno21 [OP] Well-Known Member
    Tito
    El Paso, TX
    2020 AG Tacoma TRD Pro Supercharged
    As the title says I just installed some grille lights on my 2020 and ideally I wanted them to come on with DRLs and headlights. After reading every post I could find here I have not found a solution. I see people have said tap to pink, or green, or both or add a fuse to headlamp etc.
    I have tried tapping to pink - It turns on with parking lights and headlights
    Add a fuse to HL low - it only turns on with headlights
    Tap to green and pink DRLs turn on parking lights
    Add a fuse to DRL - grille lights stay on all the time
    I do not want my lights on with ignition, I want them on with DRL and headlights, in case I want to turn all my lights off I still have that option.
    It seems like my only option right now is to maybe run a switch and turn em on as I please.
    I was wondering if someone knew of a way to have them turn on in auto with DRLs and headlights! Thanks! :frusty:
    MY1STGENTACO likes this.
  2. Jan 22, 2020 at 10:55 AM
    caribe makaira
    Caribbean, Puerto Rico
    Tullie D and Skydvrr like this.
  3. Jan 22, 2020 at 11:27 AM
    hcenteno21
    Tito
    El Paso, TX
  4. Jan 22, 2020 at 11:38 AM
    caribe makaira
    Fused power from tapped DRL (Green wire on harness to headlamps) goes into pin 1 of the orange connector.
    Fused power from Low Beam (Blue wire on harness to headlamps) goes to into pin 3
    Pin 2 goes to Grill Lamp (+)
    The 3 slot connector is not weather-resistant, so it need to be inside the fuse box or covered with silicone tape.
    Skydvrr likes this.
  5. Jan 22, 2020 at 11:40 AM
    caribe makaira
    The Black should be Blue...
  6. Jan 22, 2020 at 11:46 AM
    hcenteno21
    Tito
    El Paso, TX
    This is my head lamp connector.. Is this what we are talking about?
    I have
    Green
    Pink
    Red
    White w black stripe
    solid white
  7. Jan 22, 2020 at 11:54 AM
    caribe makaira
  8. Jan 22, 2020 at 11:57 AM
    caribe makaira
    So you don't cut into the harness, use an add-a-fuse on the low beam fuse. For the DRL tap, you could open the small fuse box next to the Main Engine fuse box and insert a wire underneath and next to the DRL relay pin 5.
    The box comes off pulling up, it has 3 parts, top cover, relay tray and bottom cover.
  9. Jan 22, 2020 at 12:14 PM
    hcenteno21
    Tito
    El Paso, TX
    Going to try this now, thanks!
  10. Jan 22, 2020 at 12:34 PM
    hcenteno21
    Tito
    El Paso, TX
    Ok so what happens when I do
    Add a fuse to low beam
    Wire tap to DRL pin 5 is
    When DRLs are on headlights are also on. Like it's bridging it together. As soon as I remove wire from relay head lights come off, but so do grille lights.
  11. Jan 22, 2020 at 2:37 PM
    caribe makaira
    Where is the diode...?
  12. Jan 22, 2020 at 2:51 PM
    hcenteno21
    Tito
    El Paso, TX
    lol I am sorry I don't understand.. Do I add a diode? And if so which kind? Thanks a ton for your time!
  13. Jan 22, 2020 at 2:56 PM
    caribe makaira
    Post #2 has the info on the parts
  14. Jan 22, 2020 at 3:07 PM
    hcenteno21
    Tito
    El Paso, TX
    I do appreciate it, it's just a bit hard to understand I am still confused
    I get now I need a diode so do I just buy 82345-32010 diode and use that to wire it? Do I need two of those?
    What would the orange connector 90980-11070 be ?
    I will be more than happy to send you something for all your help :spending:
  15. Jan 22, 2020 at 3:15 PM
    caribe makaira
    Diode goes into orange connector. The diode is a dual kind. You'll need some terminals that go inside the connector to mate the dual diode.
    hcenteno21[OP] likes this.
  16. Jan 22, 2020 at 3:21 PM
    caribe makaira
    What fuse do your Grill lights use?
  17. Jan 22, 2020 at 3:23 PM
    hcenteno21
    Tito
    El Paso, TX
    These grille lights did not come with fuse, I am using an add a fuse with 2 10a to the headlamp fuse
  18. Jan 22, 2020 at 3:27 PM
    caribe makaira
    Lower the top fuse to 5A...and add a fuse holder (5A) to the DRL tap...
  19. Jan 22, 2020 at 3:27 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    For your consideration, an alternate method.
  20. Jan 22, 2020 at 3:33 PM
    hcenteno21
    Tito
    El Paso, TX
    lol im overwhelmed! I am going to try top method just bc I kinda wrapped my head around it
    PhenixFord[QUOTED] likes this.
