Trying to figure out lift and tires; need definitive answers
Discussion in 'Suspension' started by IDtrucks, Feb 8, 2012.
  1. Feb 8, 2012 at 9:17 AM
    IDtrucks
    IDtrucks [OP] Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    Nevermind, I got my question answered
  2. Feb 8, 2012 at 9:17 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    bump for answers:(
  3. Feb 8, 2012 at 10:58 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Do it man, you're not the first to do that combo! That's a pretty basic lift and should fit 33" AT's with trimming. Not sure on 1st gens but you may need wheel spacers to clear the stock wheels and the UCA's??? Did you search?
  4. Feb 8, 2012 at 11:00 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    this!
  5. Feb 8, 2012 at 11:12 PM
    IDtrucks
    Mark "Buck"
    Jackson Wyoming
    dear lord, i deleted the part in the op about me searching. but yes, i looked around, searched and asked many questions and i got a bunch of maybes and it might works. but nobody said "yes i have tried to fit 33s on stock wheels and it rubbed frame at full lock/no it did not rub frame"
    edit: just looked at it, with 33s it will be close i believe, im thinking 1/4" wheelers spacers will be enough to give it that little extra bit of breathing room
  6. Feb 9, 2012 at 2:02 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Ya, wheel spacers "should" push the tire out enough to clear the frame. Your main issue (at least for 2nd gens) is clearing the UCA! Thats why most guys run a new wheel with 4.5" BS for that reason. Just do it and see! Usually solving one problem leads to another.......but thats part of the fun!
    Edit - Actually, are the stock tires 10.5"? If so, you're just getting a taller tire and should be fine! A wider tire will give you the most issue.......trimming plastic is easy!
  7. Feb 9, 2012 at 5:51 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    If it's that close where some rub and some don't, it's likely determined by the shape of the side-tread of the tire and how aggressive that is.
    The first gens have 4.5" BS from the factory.
