Trying to figure out tires sizes..need some help.
Discussion in 'Wheels & Tires' started by BluTaco08, Aug 10, 2009.
  1. Aug 10, 2009 at 4:21 PM
    BluTaco08
    BluTaco08 [OP] I LiKe TaCos
    Recently I've been looking at getting some bigger tires when I install the lift on my Tacoma but I can't seem to quite put my finger on exactly what to purchase.
    Currently I'm running 225/75/16 on a 7.5inch wheel which, if my FIRST TIME tire metric to inches conversions are correct that would put me with a 29.0"x9.0"x16" wheel and tire package (rounding up). First of all I just want to make sure I did that correct...
    Now, I have plans of installing the readylift sst kit on my 5-lug which should yield about 2.75'' of lift according to the website. So this is my question....the 29" tires are going to be way too small looking once the truck is lifted so what is a good tire size to go with that will 1)not kill my gas mileage that much and 2) look the most appropriate on a 2.75" lift. The readylift website says that the popular tire size for for such a lift is a 31'' tire..which leads me to my next question. What does that translate to in metric size ? (I'm not a math whiz so don't hate). And also how tall of a 31" tire can I fit without getting into problems with my UCA's or having rubbing issues. I know these kinds of questions are a PITA for you guys, but I've got to learn somewhere right ?
    Thanks for and explanations or help you can offer.
  2. Aug 10, 2009 at 4:27 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  3. Aug 10, 2009 at 4:28 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    Here is the formula I use.
    265/75/R16
    265X2X .75=397.5/ by 25.4=15.64+16=31.6"
    The Blue numbers will always be the same.
  4. Aug 10, 2009 at 4:41 PM
    BluTaco08
    Okay....so if I want to go with a 31 inch tire what width can I fit on 16x7.5'' wheel with a 2.75" lift without any complications ?
    I'm guessing a 245/80/16 or a 245/75/16 ? I need some help with this.
  5. Aug 10, 2009 at 4:44 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i'd probably stay with an 8 inch wide tire....maybe 8.5 or 9
  6. Aug 10, 2009 at 4:48 PM
    BluTaco08
    So basically, I can't go any wider than a 225 ?
  7. Aug 10, 2009 at 4:51 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im not saying you cant per say....but the chances of rubbing and all are greater the wider you go. wheel offset will play a role as well.........
  8. Aug 10, 2009 at 5:01 PM
    BluTaco08
    My offset is a +42 with 5.65'' backspacing.
  9. Aug 10, 2009 at 5:07 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah...with that,you'll wanna keep them pretty skinny as not to rub.....or find some wheel spacers for the front.
  10. Aug 10, 2009 at 5:18 PM
    BluTaco08
    I've thought about wheel spacers but I've heard from some people that they are the devil. And I just need them for the front ?
  11. Aug 10, 2009 at 5:21 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah.....depending on width.......you'd only need them for the front. rears should be fine.
    side note.....lots of wheel spacers are junk, so you'd need to find a good set. maybe check with spidertrax and see if they make a set for the 5 lug.
  12. Aug 10, 2009 at 5:38 PM
    BluTaco08
    Okay...thanks so much for all the information. Just one more question for you. Let's just suppose I get a set of spacers and put them on the front. Is there still a maximum number of width I can go to for the wheel ? For example, a 245 or a 265 ?
  13. Aug 10, 2009 at 6:17 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well....by the tire calculator's measurements....a 265/75/16 is only a hair more than 1.5 inches wider than the 225 you are running now....so im thinking that either the 245 or the 265 should be fine with the readylift.
  14. Aug 10, 2009 at 7:25 PM
    BluTaco08
    Thank you so much for all your help! I guess once the lift is on and I pick up some spacers it'll be time to tackle this a little more in depth but I'm very relieved to know that I can put a fatter tire on. Thank you for your help!
  15. Aug 10, 2009 at 8:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    no prob man.....post pics when you are done.:)
