Trying to figure out why the gas station pump clicks off while trying to fill my First Gen Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by SeaJunkie, Sep 7, 2025 at 10:33 AM.
  1. Sep 7, 2025 at 10:33 AM
    SeaJunkie
    SeaJunkie [OP] Member
    Ella
    03TacomaExtCab2.7L
    I can put about .25 cents of gas and the pump clicks off, no positioning of it changes that.
    I ve had a Evap code for a while and tried a new gas cap about 5 times. Ive been watching vids on YT to try to figure this out. Before I attempt any diagnostics myself, has anyone had any experience with this? What to check, how to etc
    High mileage Tacoma but this problem itself has only been my last few trips to fuel up. Im assuming it cant vent
  2. Sep 7, 2025 at 10:42 AM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    The gas tank vent on the truck isn't working correctly. Probably clogged up with something.
  3. Sep 7, 2025 at 12:02 PM
    SeaJunkie
    Ella
    03TacomaExtCab2.7L
    Easiest way to clear it? Hoping to not have to drop the gas tank but that certainly sounds like I would have to
  4. Sep 7, 2025 at 2:14 PM
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner & 2017 SR
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Check out this thread:
    https://www.tacomaworld.com/threads/can’t-fill-up-tank.843811/page-2
    Valve assembly fuel tank Inlet #77390-35010
    Take off the 3 bolts holding the bed on the drivers side, loosen 3 bed bolts on the passenger side. Remove the filler neck and lift the bed high enough to put a 6x6 block between the bed and the frame. You'll have enough room to remove the valve and replace it. This is what I did with mine. Much easier than removing the tank.
  5. Sep 7, 2025 at 3:08 PM
    SeaJunkie
    Ella
    03TacomaExtCab2.7L
    Incredible. Is there a way I can be sure that this is the problem before hand?
  6. Sep 7, 2025 at 5:28 PM
    toyodajeff
    jeff
    06 reg cab sr5
    Google and YouTube may have info on how to diagnose it.
  7. Sep 7, 2025 at 6:04 PM
    MyTaco
    Az
    There's good info in that thread. There is also 3 VSV valves that should be checked before tearing into it. Check your emission sticker under the hood for their location.
  8. Sep 7, 2025 at 6:44 PM
    SeaJunkie
    Ella
    03TacomaExtCab2.7L
    Great, thank you! I will look into it tomorrow.
  9. Sep 8, 2025 at 2:56 AM
    loudboy
    loudboy Well-Known Member
    Portland, OR
    '04 4x4 TRD Off-Road Limited
    All-Pro lift, Addicted tube bumper, Revenge sliders, stuff and crap
    Yea, if you "put about .25 cents of gas and the pump clicks off" then you've properly performed your test.
    TACOTU3 and Moonrman like this.
  10. Sep 8, 2025 at 9:24 PM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    This was me a few months back small leak code it was my check valve on top of gas tank and seal was able to purchase on Amazon OEM. I took off the bolts holding the bed then lifted the bed with a 2x4 a jack replaced my parts an I also replace my filler neck and no more problems can pump gas line it supposed to be.
    SeaJunkie[OP] likes this.
  11. Sep 9, 2025 at 9:36 AM
    SeaJunkie
    Ella
    03TacomaExtCab2.7L
    WOW, ok.
  12. Sep 9, 2025 at 9:37 AM
    SeaJunkie
    Ella
    03TacomaExtCab2.7L
    Very good info, thank you. Roller valve possible problem, but that check valve, hmmm
  13. Sep 9, 2025 at 9:58 AM
    Birdogsetter
    Birdogsetter Member
    09 Tacoma
    Had any gas stolen ??While running a Collison shop we had the same problem after someone tried stealing gas .. If you really tried to force gas into the tank it would blow back out the neck. Damn tweaker, wish we could of caught them..
  14. Sep 9, 2025 at 11:12 AM
    SeaJunkie
    Ella
    03TacomaExtCab2.7L
    Not that Im aware of, LOL
    I did have the gas blow back out several weeks ago, I cant remember if I didnt have the pump gun inserted correctly or wasnt paying attention while pumping. Maybe I tried to pump after it stopped? Im not usually into that habit.
    Sometimes theres the release of suction when the gas cap is removed but that has not happened in a while. HMMMM
  15. Sep 9, 2025 at 4:34 PM
    taco03Trd
    Carlos
    Riverside ca
    My bad it was roll over valve and gasket fix my problem
  16. Sep 9, 2025 at 4:48 PM
    SeaJunkie
    Ella
    03TacomaExtCab2.7L
    My poor communication, apologies! I was referring to my own truck. Could be the roll over valve but It could be the other too.
  17. Sep 10, 2025 at 8:14 AM
    chasetheCarguy4x4
    chasetheCarguy4x4 Well-Known Member
    2003 Toyota Tacoma 4WD 3.4L MFI DOHC 6cyl (5VZ-FE) 4SPD AT
    The charcoal canister has likely clogged over time and will need replaced, I have the same issue with my truck but I just fill it up slowly and remember the likely expected number for the pump to click off on as I gauge my fuel economy religiously.
  18. Sep 10, 2025 at 3:02 PM
    SeaJunkie
    Ella
    03TacomaExtCab2.7L
    You know, it’s probably that because the truck while I’m driving will buck sometimes I think that means the canister is full. anyone?
