Trying to find noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beerline123, Jan 25, 2018.
  1. Jan 25, 2018 at 9:35 AM
    Beerline123
    Beerline123 [OP] Well-Known Member
    07 Tacoma access 4x4
    well I jacked up rear wheels and put it in drive since the noise occurs mostly as I'm in gear and driving. Of course I couldn't get the noise to occur. I know jacking locations have been discussed many times before. I used rear pumpkin which is what the manual shows. The front I tend to use frame as close to wheels as I can get. The manual shows a midpoint in the front which I believe is along a crossmember where a round oblong piece with a hole on the bottom of it is. I've always been afraid to use that area because I think one member said that crossmember bent. What's the boards opinion on that spot. Any ideas how to locate this noise I'll take any suggestions. Tia
  2. Jan 25, 2018 at 9:37 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    what kind of noise? grinding, squealing, vib?
  3. Jan 25, 2018 at 9:42 AM
    Beerline123
    Vibration sounding but no feeling in pedal seat or steering wheel. Checked almost everything but nothing is loose and vibrating that I can see. Truck drives great shifts great. Noise will stop when I take foot off accelerator. Tends to occur at lower Rpms
  4. Jan 25, 2018 at 11:17 AM
    wilcam47
    Will
    Bourbon state
    check the typical...ujoints, center/carrier bearing.
  5. Jan 25, 2018 at 1:38 PM
    Beerline123
    Thanks wilcam I've checked all those things. It's most likely going to my mechanic. I had thought about investing in those steelman chassis ear device. I'm just not sure if I have enough knowledge to know what to listen for or identify what I'm hearing.
  6. Jan 25, 2018 at 1:42 PM
    TOP TACO
    TOP TACO Well-Known Member
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    needle bearing...does it go away when you put it in 4hi?
  7. Jan 25, 2018 at 1:46 PM
    Beerline123
    No, goes away when I let off accelerator.
  8. Jan 25, 2018 at 1:47 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    drive in 4hi. if it still occurs in 4hi you can eliminate that as a possibility.
  9. Jan 25, 2018 at 1:52 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
  10. Jan 26, 2018 at 1:13 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    any luck OP?
  11. Jan 26, 2018 at 1:27 PM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Good luck OP, our trucks have all kinds of noises so it’d be very hard to pinpoint. I’ve had certain noises since I bought my truck 8 years ago and still can’t figure out where they’re coming from.
  12. Jan 26, 2018 at 1:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    That center jacking point is fine and designed just for that purpose. It will not bend.
  13. Jan 26, 2018 at 3:03 PM
    Beerline123
    No luck. Funny thing is I had to drive into town for a service call and as I leave my house it's making the noise again. When I increase speed noise goes away, so I'm driving down I 95 doing 60 mph truck sounds great it's about 10 miles to city exit and as soon has I start going into slower traffic I'm expecting to hear the noise. Truck sounded great it appears that being driven at higher speed for a few miles seems to change something because I had noticed this happening before ran great when got back to my neighborhood where I drive slower. But tomorrow when I'm doing local travel it will be back. Very frustrating . Thanks guys for the help
  14. Jan 26, 2018 at 4:58 PM
    TOP TACO
    Marz
    Sacramento
    15 Tundra Crewmax
    Blackvue dash cam
    Did you try 4hi?
  15. Jan 26, 2018 at 5:07 PM
    Beerline123
    Yeah no change
  16. Jan 26, 2018 at 7:39 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    When you say you checked the universal joints etc... did you remove the drive shaft from the truck. You know you can't check them without pulling the shaft and manipulating each joint to inspect for binding and excessive looseness.
    This is the key normally to u-joints starting to fail:
    TOP TACO likes this.
  17. Jan 27, 2018 at 4:26 AM
    Beerline123
    No I didn't take driveshaft off. Noise stops when foot off gas. Driveshaft still turns so doesn't make sense. Noise goes away at higher speed or quicker acceleration. There is no vibrations felt in truck it's a vibratory sound. It will do it occasionally while standing still in drive or reverse but tends to be worse at low Rpms . Had found a hole in muffler and Han it replaced when I first started the truck and drove it sounded great and no noise. Drove it home and no noise. The next morning back again.
  18. Jan 27, 2018 at 4:34 AM
    Beerline123
    I'm gonna try to record the noise this weekend. Maybe it will help members by hearing it. If not it goes to my mechanic next week
  19. Jan 27, 2018 at 9:11 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Well if it does it standing still it isn't the drive line.
    I have no idea what a vibratory sound means...
  20. Jan 27, 2018 at 9:50 PM
    desertrunner24
    desertrunner24 Well-Known Member
    Jake
    Fresno , CA
    2011 TRD offroad 4x4
    Some
    Long shot but have you checked your intake tube at the inner fender?
    Jimmyh likes this.
