Trying to fit dog crates in backseat- Taco is 2" too narrow door to door
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Patapsco Mike, Nov 19, 2021.
  1. Nov 19, 2021 at 9:53 AM
    Patapsco Mike
    Patapsco Mike [OP] Active Member
    2022 TRD Off-Road 4x4 double cab 6' with tech, LED and premium offroad packages
    Recently purchased a 2022 TRD Off-Road 4x4 double cab 6' bed. Plan was to put two dog crates end to end in the folded down backseats. Did all the measurements, thought it would fit, but the Taco doors are so incredibly thick and the armrests stick so into the cabin that the crates won't fit. The crates together are 1-2" too wide. We can't just get different crates- the dogs need a certain size for long trips.
    Would welcome any potential solutions. Seems like what we need is maybe a different, thinner door panel, or to somehow remove the armrest part of the door. Is this something that anyone could do? Better ideas welcomed!
    sdsurfer likes this.
  2. Nov 19, 2021 at 9:58 AM
    DWD484
    DWD484 Could Be Joking
    Dave
    Louisiana
    '19 DCSB TRD Sport
    Super White
  3. Nov 19, 2021 at 9:59 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    I personally don't have a solution for your issue. That said, I typically just get a seat cover made specifically for pets and then bring along a collapsible/foldable dog crate for each of my two dogs.
    https://www.amazon.com/gp/slredirec...7344682&id=7276239199912867&widgetName=sp_atf
    https://www.amazon.com/MidWest-Fold...0&sr=1-1-f4ff053e-b1e8-4d31-8f95-56d755c862ba
    tcjacado, Speedbird and Hobbs like this.
  4. Nov 19, 2021 at 9:59 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    Remove door panel, trace it onto a sheet of thin HDPE then put that on as the new door panel. You may need to put some cut outs for certain things, but that will give you a door panel without the thickness.
  5. Nov 19, 2021 at 10:09 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    First thing i bought was the rear seat delete. Tons more room for a dog crate. After gettting this from goose gear, their instructions, wait, they dont have any. Well their install video, wait, no, that video is too old and didn't help. After calling, nope, calling was useless, they had no fuxking clue what the inside of my 2021 looked like in back....
    Id build my own. Its cheaper and not hard after seeing what i got for my money. BUT, im still glad i have it.
    My shepherd is 84 lbs, and.l can sit up, stand, and turn around in there. He actually has tons of room.
  6. Nov 19, 2021 at 10:10 AM
    Patapsco Mike
    I would do this but I want the door to be usable (i.e. able to be opened from the inside).
    Soft crates aren't an option for these expensive dogs. Need to have crates that are crash tested etc. just in case.
  7. Nov 19, 2021 at 10:20 AM
    HVLA
    HVLA Well-Known Member
    Idaho
    2020 Voodoo Blue OR DCSB 6MT
    Sounds to me that a Tacoma wasnt a wise choice for you since you have very specific needs for your dogs.
  8. Nov 19, 2021 at 10:21 AM
    pnw.river.junkie
    pnw.river.junkie Well-Known Member
    PNW
    Find a different crate that is a little shorter, done deal.
    jtnumberthree likes this.
  9. Nov 19, 2021 at 10:22 AM
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    You could remove the back plastic buckets, that should give you enough room.
    EDIT: I'm dumb, didn't read... I'm thinking of the wrong dimension...
  10. Nov 19, 2021 at 10:25 AM
    Patapsco Mike
    This isn't helpful.
    We can't just get different crates- the dogs need a certain size for long trips. Unfortunately crash-tested crates don't come in a ton of sizes. This is a solution we explored, believe me.
    TDImark, mrtonyd and deuceb like this.
  11. Nov 19, 2021 at 10:27 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Curious on what kennel you are using? Sounds silly but I had a similar issue for my Lab's transport in my F150 SCrew. I was just running a Port-a-Pet that splits in half. I just put the parts in first and built it in the truck. Now, my boy has the back seats to himself with a great hammock from Gun Dog Supply and I have a seatbelt attachment on him with an shock cord device.
  12. Nov 19, 2021 at 10:27 AM
    HVLA
    Idaho
    Wasnt trying to be rude. You are trying to dismantle your brand new truck for a couple of dog crates. Does that seem reasonable to you? You arent willing to get different crates.
    If I had something that was so incredibly important to me I would be checking dimenaions before making large purchases. Not much different than taking the kids along to make sure everybody fits comfortably right?
    MJTH, burgershot, lostMarbles and 5 others like this.
  13. Nov 19, 2021 at 10:28 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
  14. Nov 19, 2021 at 10:29 AM
    5nahalf
    Erik
    Minnesota
    It would still be usable. You just would not have a speaker or a arm rest anymore. You can still mount the door handle to open the door on there. Then you use a flat strap to pull the door closed. People do this all the time with "race cars" that still need to be fully functional.
  15. Nov 19, 2021 at 10:32 AM
    pnw.river.junkie
    PNW
    Right, but the dimensions of similar sized crates vary across manufacturers. Gunner is a little shorter but wider/taller than the same size crate from Ruffland for example. Your dog isn't going know the difference if the crate is one inch shorter on one side and longer on the other.
    plurpimpin likes this.
  16. Nov 19, 2021 at 10:32 AM
    theluharlifestyle
    theluharlifestyle Well-Known Member
    Parth
    SoCal
    2019 DCSB TRD OR
    Truck cap. Put them in the bed and leave the rear window open between the truck and bed
    Circuit Rider, Tnc and na8rboy like this.
  17. Nov 19, 2021 at 10:39 AM
    usmc2msu
    usmc2msu Well-Known Member
    TJ
    2017 SR5
    If the taco doesn't end up working for you, my friend has really expensive show dogs and uses expensive crash tested crates as well. She went with a Toyota Sienna. It's pretty plush and gets out of it's own way when needed. You didn't state why you need a truck, but if you don't NEED a truck, maybe that's a better solution.
    JasonLee and Mark77 like this.
  18. Nov 19, 2021 at 10:39 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    You are not helping yourself.... Crates don't fit. Not crash tested. Expensive dogs.
    But your not providing any useful info. What breed? How large? What crate have you tried?
    If you gotta open the crate doors on TWO crates while they're in the truck.... you're probably SOL.
  19. Nov 19, 2021 at 10:40 AM
    HVLA
    Idaho
    Going out on a limb that these dogs would never be put in a lowly truck bed.
  20. Nov 19, 2021 at 10:41 AM
    Minny Taco
    Minny Taco For the Horde!
    Minnesota
    2015 TRD Off Road DCSB
    - Dobinsons shocks and leaf pack - Level 8 MK6 wheels - 265/70/17 Goodyear Wrangler Duratracs load C - SPC UCA - Moog LCA - TRD Pro headlights - Bullet Proof Fab skid plate w/ Line-X - 3M Matte Black roof vinyl - Astrostart remote - Debadged - Black shifter bezel - Front window tint 50% - Color matched grill surround - MESO LED red/white map lights - Osram Super Bright H4 bulbs - Headlight Services upgraded wiring harness - Auxito LED reverse lights - Zulu Nylon Gear MOLLE visor cover - Truxedo Lo Pro QT tonneau - Weathertech floor mats - Weathertech vent visors - Redline Tuning Elite hood struts - OEM bed mat - AJT Design custom shift knob - AJT Design custom climate knobs - Center console organizer - Salex glove box organizer - 1" driver seat spacers - AntennaX 14" antenna - AVS door sill protectors - Trimmed OEM mud flaps - Candyapple red tow hook - Painted pinch weld and radiator frame - Custom radio knobs from Hondo Garage - Xtunes black tail lights - Black LED third brake light - Ruff Tuff Kryptek Typhon seat covers - ACEkraut license plate relocation bracket - Cali Raised Side Shooter ditch lights w/ lo-pro mounts - Subaru tweeters + Rockford Fosgate speakers - Thinkware F800 Pro dash cam - Stickers n shit
    Man, aside from removing the arm rests back there I'm not sure what else to do. Bummer it's so close to fitting.
    Gunshot-6A and Patapsco Mike[OP] like this.
