Trying to fit dog crates in backseat- Taco is 2" too narrow door to door
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Patapsco Mike, Nov 19, 2021.
  1. Nov 20, 2021 at 6:50 AM
    #161
    gwiz
    gwiz Well-Known Member
    Indiana
    2020 Tacoma SR5 4x4 V6
    GFC v2
    Maybe this has been suggested and I missed it, but how about some crash tested dog harnesses that tie into the rear seatbelts or attach like a car seat?
    https://www.autoanything.com/pet-travel/kurgo-impact-harness
    edit: I should mention that I don’t have the above-linked harness just linking for concept.
  2. Nov 20, 2021 at 6:52 AM
    #162
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I really think your best option is to just leave the doors and crates alone and put in a riser. People drive trucks all the time with no view through a rear window, you get used to using your side mirrors.
    I personally use good harnesses and cables attached to the LATCH hooks behind the seats. It's very secure, and probably as protective as a crate in a crash.
    Jojee117 and lostMarbles like this.
  3. Nov 20, 2021 at 6:52 AM
    #163
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I did a little research of the claims on this site and none of the standards mentioned involve dogs. They are about securing cargo so it doesn’t get free and hurt the occupants and about seats and restraints for humans.
    https://4x4northamerica.com/crash-tested-dog-crates-canada/
    I have a vague memory of my wife researching dog safety restraint systems many years ago and determining they don’t really exist in the same way they do for humans. Things might have changed since then, but I’m still skeptical about the term “crash tested”.
    These are the certifications mentioned on the website.
    https://www.iso.org/standard/44441.html
    https://unece.org/DAM/trans/main/wp29/wp29regs/2015/R017r5e.pdf
    https://www.maxi-cosi.com/c/interna...ules-explained-what-does-ece-r4404-label-mean
  4. Nov 20, 2021 at 6:54 AM
    #164
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
    D. Lengua likes this.
  5. Nov 20, 2021 at 6:59 AM
    #165
    Patapsco Mike
    Patapsco Mike [OP] Active Member
    2022 TRD Off-Road 4x4 double cab 6' with tech, LED and premium offroad packages
    Thank you.
    Yeah this harness or a cargo net is sort of what 'gwiz' and a few others have said. It is protective for sure. I'm not sure how these hyperactive hunting dogs would deal with that. We don't really want them to be able to see out the windows. They go nuts every time they see another dog, squirrel, etc. They'd be wrestling with each other and raising hell. When a dog goes into a crate they kind of shut down and mostly just go to sleep. It's pretty great and it's what they are used to in a car. It's a good suggestion though, much appreciated.
  6. Nov 20, 2021 at 7:01 AM
    #166
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    People remove the seats create a platform that is slightly higher than the arms rest and hard mount the kennels inside the vehicle. There is a thread on here somewhere called show us your dogs and platforms is an offshoot of it.
  7. Nov 20, 2021 at 7:03 AM
    #167
    Patapsco Mike
    Ah, OK, I see what you mean. Yeah that would work. Thanks.
  8. Nov 20, 2021 at 7:11 AM
    #168
    MNMLST
    MNMLST Well-Known Member
    Earth
    tinfoil lined cab runflat headlights pee-thru seats
    Dogs should not be transported in the passenger compartment of a vehicle, for several reasons.
    You have a truck.
    It can be avoided.
  9. Nov 20, 2021 at 7:20 AM
    #169
    MNMLST
    Earth
    well, maybe not ‘exactly’…
    DES2009[QUOTED] likes this.
  10. Nov 20, 2021 at 7:24 AM
    #170
    tacoshell88
    tacoshell88 Not that well known member
    Michelle
    Somewhere along the Mexican border
    2021 DC Cement TRDOF
    Wow…
    :popcorn::popcorn::popcorn::popcorn::popcorn:
    Mark77 likes this.
  11. Nov 20, 2021 at 7:24 AM
    #171
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Simple solution.
    Dogs in crates.
    Crates in truck bed against front wall
    Secure crates with ratchet straps.
    Done.
  12. Nov 20, 2021 at 7:26 AM
    #172
    Travlr
    Travlr Lost in the ozone again
    Middle'a Utah
    2012 Baja Series Access Cab
    Oh... "expensive" dogs... well THAT changes everything... (sarcasm)
    If you really cared about your expensive dogs you would have just bought a minivan.
    DES2009 and Mark77 like this.
  13. Nov 20, 2021 at 7:33 AM
    #173
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    It’s not his truck, or crates, or dogs.
    whatstcp, D. Lengua, tcjacado and 6 others like this.
  14. Nov 20, 2021 at 7:36 AM
    #174
    MNMLST
    Earth
    Expensive ‘hunting’ dogs…
    I have NEVER seen a real working dog in anything but a quality, bed mounted or custom box(es), or SUV with a rear cage wall…
    Travlr[QUOTED] and Mark77 like this.
  15. Nov 20, 2021 at 7:37 AM
    #175
    Travlr
    Middle'a Utah
    So this, "Recently purchased a 2022 TRD Off-Road 4x4 double cab 6' bed." is someone else buying the truck for him to use?
    It's still a ridiculous amount of trouble for a couple of dogs that could be easily accomodated.
    Mark77, lostMarbles and MNMLST like this.
  16. Nov 20, 2021 at 7:39 AM
    #176
    Tacoma091919
    Tim
    2019 OR DCLB
    It sounds like he is just along to handle the crates.
    whatstcp, D. Lengua, Mark77 and 2 others like this.
  17. Nov 20, 2021 at 7:45 AM
    #177
    MNMLST
    Earth
    Clearly not for the jar opening or bathroom spider killing…
    Mark77, DES2009 and lostMarbles like this.
  18. Nov 20, 2021 at 7:46 AM
    #178
    Knute
    shoot fire box matches. so much ado over a little thing.
    FWIW, I imported my dog when I returned from China. The dog was required to have a specific travel crate defined by airlines. The flight is a 15+ hour flight.....just from wheel off the runway to touchdown. Including all the transport, handling, pre-flight, Customs, Immigration.......he was in the crate for nearly 28 hours.
    The airline, Cathay Pacific, simply used ratchet straps to secure the crate in the heated, pressurized cargo hold.
    So. OP, @Patapsco Mike, find crates that comply with airline regulations. Put the dogs in the crate, then secure the crate in the bed with ratchet straps. I'm sure your expensive dogs will survive a few hours.
    Mark77 and DES2009 like this.
  19. Nov 20, 2021 at 7:46 AM
    #179
    CrispyTacoLover
    CrispyTacoLover Well-Known Member
    2024 Tacoma and 4Runner Offroad Premium
    Where do you live? In Texas it is very common to transport dogs in air conditioning.
    MNMLST[QUOTED] and DingleTower like this.
  20. Nov 20, 2021 at 7:48 AM
    #180
    MNMLST
    Earth
    As noted above… then get a vehicle with a divider.
