trying to get a good CB ground plane
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, Nov 4, 2014.
  1. Nov 18, 2014 at 5:56 AM
    #61
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Just because the SWR is off does not mean it's too long you need to know the point of resonance it may well have been not long enough.
  2. Nov 18, 2014 at 7:03 PM
    #62
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    I was under the assumption that if SWR IS HIGHER ON channel 40 then on channel 1 the antena is too long...and vice versa ...too short. I found this on right channel radios website
  3. Nov 19, 2014 at 4:52 AM
    #63
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    An antenna is resonate over a range of frequencies it is best to tune it in the middle of the band not at either end that way the SWR will be correct at both ends of the band. If you tune the antenna on ch 1 to the lowest SWR ch 40 most likely will suffer unfortunately you can't have it both ways. If you achieve a flat SWR in the center of the band both ends should be 2:1 or less. Don't stress over a 2:1 match that's fine. The cheap SWR meters are not overly accurate so you do the best you can with what you got and it will be close enough. Think about this the most popular CB frequency is 19 and that's about as close to the center as it comes so that would be where you want the antenna to work the very best. It is correct the higher the frequency the shorter the antenna but you need a starting point other wise you'll be chasing the SWR all across the band. If you haven't moved the antenna and you plan to once it's moved away from the cab you'r SWR will change.
  4. Nov 23, 2014 at 3:17 PM
    #64
    TOYOTA 09
    Maine
    Moved the antena from the center to far left drivers side....it's still up against the cab....antena mount is grounded but my SWR is higher around 5. I probably should have just left things the way they were when I first connected everything...at that point I had an SWR of 2.5
    I think buy cutting 1/4 inch off the antena I f'd it up or made it too short. I'm gonna buy a firstick tunable tip and see if that helps.
  5. Nov 23, 2014 at 3:19 PM
    #65
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Fixed. :)
  6. Nov 23, 2014 at 3:30 PM
    #66
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Being a radio tech, I have never understood why people spend so much money and effort even messing with CB band. Even a $32 chinese handheld ham will outperform almost any legal CB radio. Why even mess with it? http://www.amazon.com/Baofeng-UV5R-136-174-400-480-Dual-Band/dp/B007H4VT7A
    I've noticed CB is really only good for line of sight up close even under the best conditions, even if you don't want to do the Ham thing there are cheap motorola FRS radios that will do that... I use these for hunting and road trips, 35 mile rated range is a bit of a stretch, but five miles car to car LOS no problemo. http://www.amazon.com/Motorola-MR350R-35-Mile-22-Channel-Two-Way/sim/B001UE6MJ8/2
  7. Nov 23, 2014 at 3:39 PM
    #67
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    My CB gets out just fine. :notsure:
  8. Nov 23, 2014 at 3:53 PM
    #68
    TOYOTA 09
    Maine
  9. Nov 23, 2014 at 3:54 PM
    #69
    TOYOTA 09
    Maine
    Just order a regular fire stick cable and tunable tip firstick II antena....I'll post updates when done.
  10. Nov 23, 2014 at 3:59 PM
    #70
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  11. Nov 23, 2014 at 4:00 PM
    #71
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
  12. Nov 23, 2014 at 4:08 PM
    #72
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I've noticed CB is really only good for line of sight up close even under the best conditions, even if you don't want to do the Ham thing there are cheap motorola FRS radios that will do that... I use these for hunting and road trips, 35 mile rated range is a bit of a stretch, but five miles car to car LOS no problemo. http://www.amazon.com/Motorola-MR350R-35-Mile-22-Channel-Two-Way/sim/B001UE6MJ8/2[/QUOTE]
    Be careful of flying pigs.
  13. Nov 23, 2014 at 4:21 PM
    #73
    username
    username Fluffer
    Pendleton, Or
    mostly stock
  14. Nov 23, 2014 at 5:45 PM
    #74
    bobank
    bobank Well-Known Member
    Bob
    Nutting Lake MA
    06 SR5 DCSB Silverstreak Mica
    New Frame, Leer Cap, Vent Shades, Timbren's, Interior LED's, Fluid Film, Royal Purple.
  15. Nov 23, 2014 at 6:15 PM
    #75
    TOYOTA 09
    Maine
    And thread has been derailed!
  16. Nov 23, 2014 at 6:20 PM
    #76
    username
    username Fluffer
    Pendleton, Or
    mostly stock
  17. Nov 23, 2014 at 6:21 PM
    #77
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    It's TW, I thought that was encouraged. My bad. :D Fwiw, I have my antenna center mounted on my roof. Also, the bedsides have ground wires behind the tail lights that connect to the frame.
  18. Nov 24, 2014 at 5:20 AM
    #78
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
  19. Nov 24, 2014 at 5:38 AM
    #79
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Not really CB outlaws cause all kinds of problems on numerous forms of communication. Every so often they get caught and receive fines that resemble a down payment on a nice house.
  20. Nov 24, 2014 at 5:59 AM
    #80
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
