trying to identify a noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stephenm, Mar 7, 2011.
  1. Mar 7, 2011 at 6:56 PM
    stephenm
    stephenm [OP] Well-Known Member
    Stephen
    Frazier Mtn / Long Beach
    2007 TRD PreRunner (Sport Package)
    Procomp 6" kit ES3000 shocks Snugtop Supersport shell Bedrug Bedliner
    Hi,
    I had my truck repaired after getting impaled by a out of control civic about a month ago. although it was an impressive accident the damage was moderate. They had to do some body work and replace the front left suspension (replaced shock, repair on the spring I believe and some other things), they realigned it too.
    anyway, ever since I got it back there is a noise that seems to be coming from the front left area. It only happens when I am trying through a hole bump and it seems the more I have my wheels turned the more you can hear it.
    As for the noise itself, it sounds like something is loose, something that is moving/vibrating that shouldn't.
    I could try to record it, it's predictable.
    the repairs are still under warranty.. I was going to add a lift kit this week but I certainly don't want to do it before this has been taken care of... Although I am pretty sure the shop that will add the lift kit could fix that, I would like to get some input before.
    thanks
  2. Mar 7, 2011 at 8:38 PM
    stephenm
    Stephen
    anyone's got an idea?
  3. Mar 7, 2011 at 8:41 PM
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    After being through an accident it could be anything. Good luck!
  4. Mar 7, 2011 at 8:43 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    x2,take it back and show them what its doing
  5. Mar 7, 2011 at 8:50 PM
    gpend5.7sport
    gpend5.7sport Well-Known Member
    Gabe
    Houston
    2010 Toyota Tundra TRD Sport
    too damn many
    loose cv joint? or something wrong with it? or the rotor is messing up
  6. Mar 7, 2011 at 8:56 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Check and see if the wheel balancing weights are hitting your sway bar. Mine would rub when the wheel was turned.
    Note I have a three inch lift with the sway bar relocation kit.
    Good luck.
  7. Mar 7, 2011 at 9:27 PM
    stephenm
    Stephen
    thanks for your responses!
  8. Mar 8, 2011 at 5:54 PM
    stephenm
    Stephen
    the truck is at the garage (repairs were under warranty!) until tomorrow, I will post whatever they find (or don't find) if anyone is interested.
  9. Sep 25, 2012 at 9:11 PM
    henryque69
    henryque69 Member
    San Ysidro
    09 TRD Prerunner
    King all 4 corners, Deavers, Soltek HID
    Post response? No one has ever given a response to this problem.
