trying to increase towing
Discussion in '1st Gen. Tacomas (1995-2004)' started by ness005, Dec 28, 2011.
  1. Dec 28, 2011 at 2:57 PM
    ness005
    ness005 [OP] New Member
    I have a 2002 toyota tacoma 5-speed 2.4l with the 2RZ-FE engine. it only has 3500 towing. from what ive seen that if it had towing package it could pull 7500. If that the case where can i get a towing package so i can install it or what can i do to increase towing with out going to crazy?
  2. Dec 28, 2011 at 8:00 PM
    shampoop
    shampoop Well-Known Member
    southwest WA
    08 tacoma extracab v6 auto trd offroad 4x4
  3. Dec 28, 2011 at 8:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Welcome to TW! Your not going to get that kinda tow capacity with the 2.4.
  4. Dec 28, 2011 at 8:10 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
  5. Dec 28, 2011 at 8:55 PM
    Snowman
    Snowman I have a problem for your solutionÂ…
    Craig
    Somewhere in Canada
    Check out my build
    You cant really improve PL. You would have to essentially replace everything, engine power, drivetrain, suspension, frame, brakes. Everything.
  6. Dec 28, 2011 at 9:03 PM
    Tacomadude89
    Tacomadude89 Well-Known Member
    Austen
    7500 pounds is waayy too much for the 4 cylinder. This out of the v6 territory too.
    Best to find a different rig for that job.
  7. Dec 28, 2011 at 9:12 PM
    Stubbs95tacoma
    Stubbs95tacoma Well-Known Member
    Blake
    Wichita
    07 SR5
    6 Inch Lift
    buy a diesel..
  8. Dec 29, 2011 at 5:53 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    You need a bigger boat! ( Jaw's)
  9. Dec 30, 2011 at 6:30 AM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    7500 is way out for that truck. Our company trucks pull 3000-3500lb all day, everyday from dealership til we wear them out and sell them. This is about the "safest" limit. Try stopping a 1st gen reg cab on a wet road with 3500 lbs behind it..... it doesn't. You go through what ever is in front of you.
  10. Dec 30, 2011 at 6:37 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Exactly. There's a reason why I don't tow my Tacoma with a Tacoma.
  11. Dec 30, 2011 at 6:38 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    Your trailer must have built in jack stands...... :D
  12. Dec 30, 2011 at 6:42 AM
    mjp2
    NJ
    Close! I managed to break the suspension hangers and it was on jackstands for about a month as I found time to cut, grind, and weld in the evenings after work. :)
  13. Dec 30, 2011 at 6:46 AM
    chadderkdawg
    Des Moines, Iowa
    09 FX4 F150
    Haha ur a pretty good sport kiddo :thumbsup:
  14. Dec 30, 2011 at 11:40 AM
    IDtrucks
    IDtrucks Unhinged and Fluid
    Mark "Buck"
    Jackson Wyoming
    trailer queen:p
    but 7500? where did you get those numbers from? the 2nd gen v6 with tow package is only 6500. do yourself and other motorists a favor and dont exceed 3500 lbs towing. remember your first gen is still a mini truck.
