Trying to learn more about rear lifts (Questions)
Discussion in 'Suspension' started by CanisLupus, Apr 14, 2013.
  1. Apr 14, 2013 at 8:21 PM
    CanisLupus
    CanisLupus [OP] Well-Known Member
    Ashburn | VA
    '11 DCSB 4WD / '13 Ninja 300 / '04 CRF 150F
    Hi all, I'm trying to "edumacate" myself some more on rear lifts because I have learned a lot about front lifts since joining but for some reason never really focused on things about rear lifts. I've been searching on Google/TW for a while now but I still have some questions.
    For a leaf pack like the OME Dakars, do you need anything else with them (to run them safely) when installing besides extended rear shocks? Are longer bump stops required with a leaf pack like this? Are extended rear brake lines really needed with Dakars / All-Pros unless you are doing some serious flexing?
    Also, I have heard things about centering pins and shims, and have a general idea of what they are but I don't really understand how shims fix driveline vibes if they raising the leaf pack more?
    For something like a U-Bolt Flip Kit, how do the bump stops need to be adapted/fixed? Do they actually come off completely when you do a flip kit and need to be re-welded or how do they go back on?
    I may come up with some more questions later , but hopefully some people can help me and this can also be a resource for others trying to learn more.
  2. Apr 14, 2013 at 9:17 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    No Truck..well, maybe
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Hi Matt, depending on if its a 1st gen or 2nd gen... with 1st gens you'll almost always have to get ext. shocks & brakeline when lifting, 2nd gens not so much. This applies to ANY spring used for lifting. As far as shims go, if you look closely you'll notice they're slightly angled (tapered) Its purpose is not to raise the springs but rather change differential angle to put it more into driveline parallel that changes when either lifting or lowering....
    Now I have a question for you.... Where did you find this sig ??
    vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
    Lead, follow, or get the fuck out of the way!
    :spy::spy:
  3. Apr 15, 2013 at 4:15 AM
    CanisLupus
    Ashburn | VA
    Thanks for the reply Doug...slowly learning...
    And it's a saying I heard a while ago that was supposedly said by General Patton. :infantry:
  4. Apr 15, 2013 at 10:03 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Haha, just call me general then, that's my old sig, I rocked it at the bottom of my page since I joined TW in '09 , used it up to about 2 months ago..Although sounds like something Patton would say for sure..:D
  5. Apr 15, 2013 at 10:13 AM
    CanisLupus
    Ashburn | VA
    :thumbsup:
    Should always have at least one person with it at all times...
  6. Apr 15, 2013 at 10:17 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Absolutely brother...;)
  7. Apr 22, 2013 at 5:49 PM
    CanisLupus
    Ashburn | VA
    The question above is my main one for you experts. I think if I get this pack (or even before) I will be getting the All-Pro U-Bolt Flip Kit with Timbren Rear Bump Stops. Will these be sufficient for Dakars?
    Also, do I need to buy anything else specifically for the Dakars besides the actual leaf pack? I see on the page for the Dakars on TRDParts4U that they have an option for "Tacoma bushings." Do I need these if I run the Dakars?
  8. Apr 23, 2013 at 3:51 AM
    CliffordBRD
    CliffordBRD Well-Known Member
    Cliff
    Tampa, FL
    09 DCLB 4x4 Pyrite Mica
    I'm pretty sure new bushings will come with any leaf set you get. I'm interested in the bump stops and such as well. How much lift are you going for and what type ofnoffroading do you do? Do you carry any weight?
  9. Apr 23, 2013 at 5:24 AM
    Lumpskie
    Lumpskie Independent Thinker
    New Hampshire
    '96, 4x4, v6, manual hub
    Toytec 16" coilovers with Tundra Bilstein 5100s, Light Racing UCAs, Alcan Leafs with Orbit Eyes, 12" Bilstein 7100 short Bodies, ARB rear locker, 33x12.5 Duratracs, CBI sliders, Bushwacker fender flares, self made front bumper, M8000, Vision X 6.7" Hi/Lo Beam HIDs, full skids, Inchworm dual case setup - 15º clocking
    One thing to remember with the U-bolt flip is that you will need to relocate your shocks. (because the lower shock mount is attached to the plate your stock U-bolts attach to) I don't know if you weld or not, but it's something to keep in mind...
  10. Apr 23, 2013 at 6:41 AM
    CanisLupus
    Ashburn | VA
    The Dakars (2.75") provide me the approximate lift I want and I have heard good things about their weight support. I don't haul much but I like to not sag when I do carry stuff.
    That is very true, I forgot about the shock relocation. I think I would just have a shop do that for me since I don't know how to weld. Would I need to buy relocation plates for the shock seat to sit in and do you know where I should get those from?
  11. Apr 23, 2013 at 6:50 AM
    Lumpskie
    New Hampshire
    Here are some options for your lower mounts. I know that other vendors sell them as well.
    http://www.marlincrawler.com/suspension/shock-equip/axle-shock-mount
    https://www.allprooffroad.com/9504tacomarearsuspension/9504shockmounts
    Also, for bump stops, I'm thinking about extending the upper strike plate rather than the lower rubber stop. That way the rubber can't over compress or break due to torsional loading. I'll probably just use square tube and plate to make mine, but Marlin does sell something simlar to what I envision. (with the offset towards the center of the truck).
    http://www.marlincrawler.com/suspension/parts/bumpstop-extensions
  12. Apr 23, 2013 at 7:24 AM
    CanisLupus
    Ashburn | VA
    Thanks for the links. Would those All-Pro mounts work for 05-11 Tacoma's also? They don't seem to have shock mounts listed for 05-11 on their site, only for 96-04.
    Also, are the Marlin mounts universal and/or are the mounts for a 3'' axle housing correct for 05-11 Tacoma's?
  13. Apr 23, 2013 at 9:26 AM
    DevL
    DevL Well-Known Member
    I run the Allpro Ubolt flip for Timbrens but with modified factory bumps so I do not lose travel. You just hammer em flat, trim to fit, and mount em up.
  14. Apr 23, 2013 at 9:36 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    You will need longer U-bolts & new bushings for the Dakars.
    Longer than stock shocks.
    Stock brake lines are fine.
    Bump stops depends on tire size & wheel specs. My rear wheels stuff just fine with stock bump stops.
    The Emu Gurus are at Old Man Emu: Questions, Answers & Pictures ([​IMG] 1 2 3 ... Last Page)
  15. Apr 23, 2013 at 9:52 AM
    CanisLupus
    Ashburn | VA
    Ok, I was just planning on running the OME N182's if I got Dakar's anyway. Are these the right U-Bolts for Dakars and do they work with the stock U-bolt locations or is there some other flip kit that has longer U-bolts for leaf packs?
  16. Apr 23, 2013 at 1:47 PM
    DevL
    The Allpro U bolts will fit and you need the round U bolts, not the flat ones to run a flip kit... just use the flip kit made for Timbren and modify your factory bumps.
  17. Apr 23, 2013 at 2:05 PM
    CanisLupus
    Ashburn | VA
    But who sells longer U-Bolts so that I could run the All-Pro Flip Kit with Dakars? I would like to have both a flip kit and Dakars, I just don't know who makes a kit that is compatible.
  18. Apr 25, 2013 at 3:47 AM
    DevL
    Pretty sure the Ubolts are long enough as is on the AllPro flip kit.
  19. Apr 25, 2013 at 12:56 PM
    Lumpskie
    New Hampshire
    Out of curiosity, why are you set on doing the U-bolt flip right away?
  20. Apr 25, 2013 at 1:10 PM
    CanisLupus
    Ashburn | VA
    Well, I would eventually like to do a flip kit to get some more clearance around the rear axle, and I figured if I was going to go through the trouble of putting a leaf pack on, I would put the flip kit and bump stops on, and relocate the shocks anyway. So, ideally, I would like to get all the needed parts (flip kit, bump stops, shock relocation mounts, and leaf pack), and do it all at the same time.
