Trying to make my manual window to power window
Discussion in '1st Gen. Tacomas (1995-2004)' started by pineapple, Jul 1, 2023.
  1. Jul 1, 2023 at 9:36 PM
    pineapple
    pineapple [OP] Well-Known Member
    HAWAII
    2003 Tacoma 2WD
    I wanted to make my driver side manual window to power window so, I bought a drive side power window regulator with motor . The problem is the power window regulator won’t bolt to door panel. The manual window regulator mounting hole are different. am I doing something wrong or it doesn’t work that way. Any ideas?. The manual regulator has 3 bolts for mounting . Thanks for any help
  2. Jul 1, 2023 at 9:47 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    I think the doors are different. Bartmaster on here has more info
  3. Jul 1, 2023 at 10:26 PM
    pineapple
    HAWAII
    2003 Tacoma 2WD
    Thanks that’s right he did do it.
    Rastopher likes this.
  4. Jul 3, 2023 at 11:16 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    What year did your power window regulator come out of ??
    Is it aftermarket one model fits everything??
    Worse case make an adapter plate to make it work.
  5. Jul 6, 2023 at 9:10 AM
    Bivouac
    So just which year Tacoma did you have this done to??
    Just what parts did the shop use for $400.00 per window??
  6. Jul 6, 2023 at 9:15 AM
    Bivouac
    well what make you must have an invoice?
    Details for $400.00 what make parts??
    How about post some pictures? Show us what $400.00 buys We would love to see this install .
  7. Jul 6, 2023 at 7:09 PM
    Bivouac
    Any updates on this project OP ??
  8. Jul 7, 2023 at 8:32 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    The door shells are all the same. The regulators bolt in different places however. The FSM will show you where to mount these.
    Also it’s not as easy as just plugging in the door harnesses in if you have the factory plugs pre-installed under the dash, the integration module will have to be changed. I ran my own relays and wires instead from the stock door harnesses to the other door.
    Bivouac and mechanicjon like this.
