Trying to maximize my A/C output
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SedonaTRD, Aug 4, 2025.
  1. Aug 4, 2025 at 11:17 AM
    SedonaTRD
    SedonaTRD [OP] Member
    2012 Tacoma TRD 4x4
    None
    Been well over 100 every day in Arizona this summer, so Im looking for ways to maximize my A/C output. Just read that wrapping the A/C refrigerant lines under the hood can help. Any one ever done this?? If so, any suggestion on the type of wrap? Thanks!
  2. Aug 4, 2025 at 11:31 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I honestly don't think you'll gain much by wrapping any pipes. Being as the a/c was designed without them, you may cause other problems in the system if internal components are getting too cold.
    You could find any foam wrap or tape in the plumbing section at your local hardware store.
    Gunshot-6A likes this.
  3. Aug 4, 2025 at 11:35 AM
    Schlappesepple
    Schlappesepple Well-Known Member
    Joe
    2020 4Runner ORP
    Fan on max, vents set to face and feet (hopefully you're wearing shorts), and recirculate on.
    2nd gen AC was never amazing, and the face blowers kind of sucked (steering wheel was between you and the vent). In Georgia, doing anything less than max fan was pointless when it was super hot, I imagine AZ is much worse.
    Do you have a windshield reflector for parking? Keeping the car a few degrees cooler before you get in helps a lot.
    2015WhiteOR and Gunshot-6A like this.
  4. Aug 4, 2025 at 11:43 AM
    soggyBottom
    soggyBottom Well-Known Member
    You could try to clean the condenser and add tint.
    Use a/c coil cleaner. Remove the grill, fix any bent fins, and spray the condenser with coil cleaner. Basically just follow the instructions on the can.
    If you don't already have tint, add some.
    Last, you can do something like add dynomat with the reflective barrier but in reality, this only helps keep heat in.
  5. Aug 4, 2025 at 12:21 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    We haven’t even hit the 90s yet and my MGM colored Tacoma is at code red as far as the AC goes. You may need some dry ice to correct your problem in Arizona.
  6. Aug 4, 2025 at 12:51 PM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I spray the bugs and any mud out of the condenser and radiator with a pressure washer once in awhile
    2015WhiteOR likes this.
  7. Aug 4, 2025 at 1:12 PM
    truckmike26
    truckmike26 New Member (2009)
    Toronto
    '21 DC TRD Off-Road, '94 Pickup (Hilux) V6/Auto 4WD
    Yes, airflow across the condenser is the main contributor to A/C performance so keeping it clean is sage advice. I also like my factory grill and I keep it free of Raptor lights or anything else that could potentially impede airflow through the condenser.
    Rob MacRuger likes this.
  8. Aug 4, 2025 at 2:39 PM
    4x4junkie
    4x4junkie Well-Known Member
    So Calif. (SFV)
    2018 TRD Sport ACLB MT
    I wrapped all the hoses & tubing for the A/C on my 3rd-gen (it had a good 6-7 feet of exposed suction line snaking all around the hot engine).
    Like someone said, the poly foam pipe insulation from a hardware/plumbing store works real well for this (insulation for ½" pipe fits best). Securing (wrapping) it with electrical tape every few inches will keep it in place (I used Scotch Super-88 tape, the adhesive on the 88 seems to be unaffected by engine heat unlike cheaper / no-name tapes).
    The 3rd-gen reportedly had issues with the A/C shutting down whenever it got to 100° or more (has a TSB for this), but with everything insulated, it's always worked well even in 117° heat (no TSB done on mine).
  9. Aug 4, 2025 at 2:57 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Are you new to AZ? This is one of the tamest summers we've ever had, lol.
    mikalcarbine likes this.
  10. Aug 4, 2025 at 3:00 PM
    menoarenoniceguy
    menoarenoniceguy Well-Known Member
    SoCal
    2013 Spruce Mica AC
    Quality ceramic tint all the way around
    JGO and Revelations like this.
  11. Aug 4, 2025 at 3:01 PM
    Bishop84
    Bishop84 Well-Known Member
    I remove my cabin filter in the summer, I block the windows with covers and rear.
    anything over 100f40c I would die, not sure I’d ever adjust.
  12. Aug 4, 2025 at 4:55 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I've always had a suspicion that the AC in the Tacoma was designed around the cooling load of the single cab, which is why it seems so weak on the double cab model.
    But it could also be that there just isn't a lot of room for a big enough condenser and evaporator due to the truck's size.
    My old single cab F150 would freeze your tits off WITHOUT using MAX A/C and I always assumed that truck was the opposite where it had the AC tonnage meant for the Expedition.
    Steelhead Bum likes this.
  13. Aug 4, 2025 at 4:55 PM
    ridefreak
    NM
    2006 DCSB TRD
    minor tweaks
    Don't worry, it's a dry heat :D
    Jimmyh likes this.
  14. Aug 4, 2025 at 4:59 PM
    Bishop84
    Had the same truck, you could see my dogs breath in the middle of summer.
    joba27n and truckmike26 like this.
  15. Aug 5, 2025 at 8:50 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    You might look into a heater core control valve. I think Tacomas have the circuit to the heater core open all the time. I may be wrong.
    Jimmyh likes this.
  16. Aug 5, 2025 at 11:23 AM
    Rob MacRuger
    Rob MacRuger Well-Known Member
    2006 4X4 SR5 4.0
    My 06 Access cab has nice cold air, lower 40's F in this year's summer heat. This truck is only a few months away from 20 years old so I'm very happy. Right now the heat is brutal here in central Florida but I imagine AZ is much worse.
    One thing I have done so far to help with the AC temp is to build a small removable air dam that directs some air flow to the AC condenser. I did that mod several years ago. It seemed to help with the AC temp as well as the tranny temp as the external cooler is right there also.
    An air mister spraying on the condenser would also be nice.
    I recently insulated the low pressure AC pipe from the bottom of the right side of the engine bay up to the firewall. I used some left over insulation from re-insulating my home outdoor AC pipes this year. If I had to do again I would research and probably buy something different as the truck lines are 1/2" and my home AC pipes are 3/4". All insulation was completely wrapped in heat resistant fabric tape and secured with metal tie wraps which was a real slow process.
    Next time I would also swap out the pipe clamps to accommodate the insulation instead of stopping and starting at the clamps.
    The remaining section of pipe at the bottom front of the engine running to the compressor is too close to the drive belt and pulleys so I opted to not insulate that part. I may just wrap it in some kind of rubber fusion tape later.
    The AC actually feels cooler than before the insulation installation and it only cost me $10 for the tape. I'm sure some educated people will say insulating is not needed. How can it not help if even a little?
    I was working on my grandson's 97 Geo Prism (which is a rebadged Corolla) this year and noticed that the low side AC pipe was factory insulated.
    GilbertOz and ridefreak like this.
  17. Aug 6, 2025 at 3:58 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Yes it has full flow all the time. Uses the Blend Servo to control hot and cold ratio.
    HBMurphy[QUOTED] likes this.
  18. Aug 10, 2025 at 12:43 PM
    JGO
    JGO Well-Known Member
    South Central Kentucky
    '14, 4 Cyl, A/T, Silver A/C
    +10
  19. Aug 10, 2025 at 3:12 PM
    Wallsjm1
    Wallsjm1 Well-Known Member
    Justin
    Tennessee
    2007 Speedway Blue 4x4 TRD-Off Road
    XD Rockstars 18's, Nitto Terra Grapplers, Billies all the way around, set to 3 inches, AAL, Chrome push bar, Westin step bars
    I wonder what vent temps should be in 85-90° weather. My whole AC system was just replaced and I get like 47° vent temps maybe closer to 49° on number 2 speed max ac mode recirculating
  20. Aug 10, 2025 at 5:36 PM
    mikalcarbine
    mikalcarbine Well-Known Member
    Phoenix, AZ
    2015 AC TRD OR
    I think general rule of thumb for R134a systems is 35-40* lower than ambient temps. IIRC the best place to check is the center vent drive side.
    Wallsjm1 likes this.
