Trying to pick correct lug nuts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Peanut47711, Jun 15, 2019.
  1. Jun 15, 2019 at 9:28 AM
    Peanut47711
    Peanut47711 [OP] Member
    2007 White Doublecab PreRunner
    Hey folks, picked up a set of 17" 4runner wheels for my 2007 Prerunner. Anybody know the correct lug nut size, length, style, etc. The appear to take a mag style lug nut, not the acorn style but I could be wrong.Screenshot_20190609-164022.jpg Screenshot_20190609-164022.jpg
  2. Jun 15, 2019 at 9:33 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Tacoma and 4 runners should use the same type lug nuts for stock rims. Those look like it would use acorn lugnuts.
  3. Jun 15, 2019 at 10:05 AM
    Peanut47711
    I should add I am going from steelies to these pictured above. The mounting surface on these appear to be flat, not beveled.
  4. Jun 15, 2019 at 10:27 AM
    TacoJoeBro
    TacoJoeBro Well-Known Member
    Not Joe
    Midwest
    12 DCSB OffRoad
    6112/5160 Icon RXT JBA KO2
    I believe steel wheels have different seats on the lugs. Beveled as you stated is for steel wheels and acorn type seats. The seats for the factory aluminum is flat with a washer. If you had aluminum wheels originally you would be set, as they are the same seat,thread pitch as 4Runner just slightly shorter.
    TRDSport10 likes this.
  5. Jun 15, 2019 at 10:38 AM
    Peanut47711
    I guess what i actually need to know is,do i need tacoma lugnuts, or for a 4runner as in the length being different. I have to buy lugnuts regardless, just wanna make sure i get em right the first time. Thanks for the replies!
  6. Jun 15, 2019 at 10:47 AM
    TacoJoeBro
    Not Joe
    Midwest
    12 DCSB OffRoad
    Either will work.
    I guess I should correct myself from earlier... What I noticed was the Tacoma lug nuts were slightly recessed into wheel further than they were on the 4Runner. I didn't physically measure them. Regardless, I put the wheels from my 4Runner on my truck and used the tacos lug nuts. (I started with aluminum wheels)
  7. Jun 15, 2019 at 10:58 AM
    jkuniverse
    jkuniverse Well-Known Member
    Arlington TX
    2013 Limited DCSB 4x4 Super White
    I’ve recently purchased 24 factory chrome lug nuts off of a 2018 4 runner for my ‘13, and they fit perfectly.
    Steves104x4 likes this.
  8. Jun 15, 2019 at 12:27 PM
    fb40dash5
    fb40dash5 Well-Known Member
    People's Republic of MD
    11 V6 AC 4x4
    There's 2 lengths of the correct style (mag with the captured washer) nuts, although the part that matters is the same, it's just the length of the hex that changes. There's also chrome capped ones, which are Satan in lug nut form, as they rust under the stainless cap, leading to the cap swelling so you can't get a socket on, and/or the cap crimp loosening and it falling off.
    I got a bulk pack of the shorter Gorilla nuts off Amazon, it was $80 or $90 for 60 of them, bought a pack of wheel locks, and sold the other 2 sets of 20, it worked out pretty cheap. They're not the best of the best, but they're better quality than the super-cheap ones, or OE capped ones, and it worked out to about the same cost. Unfortunately they're otherwise only sold in 4-packs, and they're $12ish per pack, so buying 6 packs is almost as much as buying the bulk pack.
  9. Jun 15, 2019 at 12:54 PM
    Peanut47711
    Good info fb40, thanks alot
  10. Jun 15, 2019 at 4:42 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    I put those same 4Runner wheels on my '08. Got a deal on 800mi. take-offs. Luckily the owner saved the OEM lug nuts, so it was good to go.
  11. Jun 15, 2019 at 4:46 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    The ones on left came off my tacoma trd wheels. the small one on right is what Discount tire tried to give me to replace the OEM ones they never gave me back and lost. Not sure how much that helps OP.
  12. Jun 15, 2019 at 5:19 PM
    Peanut47711
    The set I bought had 195 miles on them. Owner ordered new 4runner and specific trd wheels. 4runner showed up with these wheels, so he drove on them for two weeks until correct wheels showed up to dealership. Stole em from him for $125
  13. Jun 16, 2019 at 7:27 AM
    Tacoma Nick
    Tacoma Nick Active Member
    Nick
    Michigan
    2008 Indigo Ink Pearl Regular Cab 2TR auto 2WD
    All new under the floor, factory frame swap. Bucket seat swap. Bilstein 4600 shocks and X Runner rear swaybar. 4:10 DIfferential. 225/60/17 on Sienna 5 spoke alloy wheels. After market black headlights. OE replica fog lights. OE Intermittent wipers plug and play. Leather steering wheel (OE eBay) that came with a cruise stalk, I bought the $38 OE wire to plug into the clock spring, plug and play.
  14. Jun 16, 2019 at 7:37 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Mag seat lugs 12x1.5
    Peanut47711[OP] likes this.
  15. Jun 16, 2019 at 12:17 PM
    Peanut47711
  16. Jun 16, 2019 at 12:58 PM
    gotoman1969
    Contact gorilla automotive. I believe you can order direct in bulk 24. Pn# 73138T(chrome)or 73138TBC(black) those are the bulk part #s the bag # just add a B to the end.
  17. Jun 16, 2019 at 1:00 PM
    gotoman1969
    The longer ones in chrome are 73138TXL add a B for bag.
  18. Jun 16, 2019 at 4:33 PM
    B Dog
    B Dog Active Member
    Barry
    Eugene, Or
    2009 silver Tacoma PreRunner Double Cab
    I had the same wheels put on my truck. I switched from the 17" TRD wheels and used the same lug nuts.
