Trying to put stock navigation in where there currently isnt..
Discussion in 'Audio & Video' started by Gumpit, Jul 10, 2013.
  1. Jul 10, 2013 at 4:07 PM
    Gumpit
    Gumpit [OP] Member
    Randy
    Massachusetts
    2013 Tacoma 2wd 4cyl SR5 Double Cab auto
    I bought a 2013 Double cab automatic 2wd 4cyl. SR5 which comes with am/fm/bluetooth only. They told me I couldnt get Navigation in this model. WHY NOT? Do you mean to tell me the "LIMITED" which I believe has the NAVIGATION ENTUNE is completely different? Why wouldnt that radio be able to be swapped right in? Does anyone have pics of a 2013 with factory Navigation. Pics of the front and back to compare it to the one I have. Or a plug and play unit that has no need for any modifications other than remove and replace with maybe a plug and play adaptor already wired so the steering wheel controls work. I realize I would need antenns for the NAV. I DONT CARE ABOUT SATELITE RADIO. Thanks Randy
  2. Jul 10, 2013 at 4:46 PM
    JohnWJ
    JohnWJ Well-Known Member
    New Mexico
    2013 Dark Grey 4x4 access cab
  3. Jul 10, 2013 at 6:18 PM
    919motoring
    919motoring Active Member
    Shaun
    Raleigh, NC
    13 DC Mag Gray TRD sport 4x4
    Hey Randy,
    When you say regular radio? Do you mean the standard radio or standard 6.1" non entune?
    Shaun
  4. Jul 11, 2013 at 7:00 PM
    Gumpit
    Gumpit [OP] Member
    Randy
    Massachusetts
    I just want a radio with am/fm/BT and Navigation. I am not sure what the Entune gives you but I probably dont need it.
  5. Sep 2, 2013 at 7:52 PM
    Gumpit
    Gumpit [OP] Member
    Randy
    Massachusetts
    This is what I have. The 57053 radio. I want NAVIGATION and the steering controls to work as well as Bluetooth... Any thoughts?
  6. Sep 2, 2013 at 7:54 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    Completely different systems...not just plug and play
    Entune unit has a sub and amp running with the jbl system
  7. Sep 2, 2013 at 8:17 PM
    Gumpit
    Gumpit [OP] Member
    Randy
    Massachusetts
    I am not an audiophile. I don't care about upgrading the radio sound. The way the stock one sounds is fine. I just want to have Navigation,bluetooth and my steering wheel controls still working am/fm is fine. I don't need SAT. . Any thoughts?
  8. Sep 2, 2013 at 8:18 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    yea but if you want to retain the stock unit working with the nav you need to run the jbl amp and do a bunch of new wiring to get it to power up...
  9. Sep 2, 2013 at 8:20 PM
    Gumpit
    Gumpit [OP] Member
    Randy
    Massachusetts
    Is there a non JBL radio with NAV that will work?
  10. Sep 2, 2013 at 8:30 PM
    Gumpit
    Gumpit [OP] Member
    Randy
    Massachusetts
    I see you can make the backup camera show on the radio. Is there a way to run a GPS into the AUX jack or through Bluetooth somehow and get it to show on the screen?
  11. Sep 2, 2013 at 8:36 PM
    Newlife
    Newlife Well-Known Member
    Adam
    Knoxville TN
    Underdog
    iPad mini 2 w/ retina in dash, Alpine amp and subs, avs window visors, 3" omelift with bastard pack, full synthetic fluid swap, 15% tint all over, debadged all the way around.,two cree led pods near windshield,50'' up top, and pods in lower bumper , Katzkins grey and barracuda red leather interior all around. Wrangler MTR's 35" . American out law buckshot 16x9. Bruteforce Fab rear bumper. SOS concepts front bumper. Engo 10000s winch And a bunch of other money tied up in it,
    in order to get anything to display on a screen b/t nor an auxillary 3.5mm jack can do. You would have to find a way to hook up a/v cables to the headunit. Even then you still won't be able to control the navigation. Might as well accept it for what it is. If you want nav buy a nav unit or a tom tom.
  12. Sep 2, 2013 at 8:43 PM
    Gumpit
    Gumpit [OP] Member
    Randy
    Massachusetts
    So the ONLY factory radio that will have Navigation is the JBL Entune unit? Is there any aftermarket radios that will have NAV and Bluetooth and still work with factory steering wheel controls?
  13. Sep 2, 2013 at 8:44 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Not OEM. If you want in-dash nav, you'll need to go aftermarket, but that's not going to give you steering wheel controls.
  14. Sep 2, 2013 at 8:47 PM
    Jerez
    Rod
    Diamond Bar, CA
    08 TRD Sport
    Estock
    not fully true...they sell the modules for it.
    unless they havent made one for the newer truck yet :notsure:
  15. Sep 2, 2013 at 8:49 PM
    Newlife
    Adam
    Knoxville TN
    Underdog
    OK I am going to try my best to point you in the right direction....
    You need a aftermarket head unit ok tons of choices
    My favorite and have used for years : Pioneer Avic Series. I believe the newest is a 810bt (could be wrong)
    Then you're going to need a dash kit and wiring harness. Both of those you can get for free from ordering from someone like Crutchfield.com or Sonicelectronix.com I have ordered from both and both top notch customer service. Sonicelectronix is a little cheaper though.
    Then you're going to need a steering wheel adapter kit. an axxis aswc is what I used. Works great and ordered from sonicelectronix.
    Now I am making an assumption here. But since you asked about BT or aux displaying a nav screen. You are going to need someone reputable to install the new radio and steering wheels controls.
  16. Sep 2, 2013 at 8:50 PM
    Gumpit
    Gumpit [OP] Member
    Randy
    Massachusetts
    module?
  17. Sep 2, 2013 at 8:53 PM
    Newlife
    Adam
    Knoxville TN
    Underdog
    Now I currently do not have nor use an indash nav unit. I do however have the pioneer avh-x3500bhs . It has bt, xm radio, dvd, rear view cam, pandora, All the bells and whistles minus the nav for less than 400.00. Now for another 3-400.00 you can get the add on nav unit. Or if you have an iphone you can use app radio mode on it. And it works like a charm.
  18. Sep 2, 2013 at 8:53 PM
    Gumpit
    Gumpit [OP] Member
    Randy
    Massachusetts
    So if I go to a reputable installer. They should be able to get me everything I want in an aftermarket radio? I just need a simple radio without too many sub menus. I don't want to spend a lot of time trying to figure it out. Are there specific links to some radios I could check out or just see what the installer is familiar with first and choose from there?
  19. Sep 2, 2013 at 8:54 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    Assuming he doesn't currently have it.
    He'll need the PAC adapter and the proper steering wheel trim... maybe a different spiral cable and harness from the column to the stereo....
    Short story, and I really really hate to be an ass and say this, but we've all been in the same boat at one time or another.
    "Should have spent a little more time looking at the options and ordered the truck you wanted, rather than accept the truck the dealer had and assume you could install what you wanted."
    I made that mistake on my Tundra, and ended up spending a lot of time and money adding options that came with the Limited, but fortunately, I was able to do everything I wanted. I didn't make that mistake with my '06 Silverado... that bitch was loaded to the hilt.
  20. Sep 2, 2013 at 8:56 PM
    Newlife
    Adam
    Knoxville TN
    Underdog
    You tell me what you want in a radio specifically. And I will point you to some links.
    However I am going to for warn you cheap and nav units do not go hand in hand unless you get an older nav unit that is outdated. and maps cost a lot.
