Trying to Reduce Oil Change Intervals on a Barely Driven Taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Beanster, Apr 28, 2016.
  1. Apr 28, 2016 at 12:07 PM
    Beanster
    Beanster [OP] Active Member
    Jay
    Maryland
    '13 SR5 Tacoma
    My Tacoma (2013) doesnt get used very often... perhaps less than 5,000 miles per year. I'd like to reduce the frequency of oil changes which are only happening because the time interval expires (not the mileage interval).
    Would switching to a synthetic oil allow me to reduce oil change intervals since I dont drive the truck very often or very far?
    Thanks
    Joe
  2. Apr 28, 2016 at 12:20 PM
    Iowa10
    Iowa10 Well-Known Member
    Meh, just change oil and filter once a year and be done with it. Use synthetic or regular dino. With 5K miles, it ain't gonna make a difference.
    Lester Lugnut and NAAC3TACO like this.
  3. Apr 28, 2016 at 12:40 PM
    BDL5589
    BDL5589 Well-Known Member
    NE Georgia
    '14 MGM 4WD RC
    Agreed. Once a year will be fine.
  4. Apr 28, 2016 at 12:59 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    More important than anything is to not take short trips. If you go out for a drive, drive around long enough to burn off any condensation that has formed inside the crank case.
    This moisture, when combined with motor oil, degrades it at an accelerated rate.
    I'd venture to say that you can even go with a conventional oil at 1 year intervals as long as your driving practices are good.
  5. Apr 28, 2016 at 1:10 PM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    2021 TRD PRO 6MT Midnight Black
    Pennzoil dino once a year FTW.
  6. Apr 28, 2016 at 3:43 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    First, follow the owner's manual until you are out of warranty.
    Then go 1 year or 5000 miles whichever comes first. Modern mineral oil (dino oil) is very good oil. Whatever you use, be sure it has the API starburst symbol and you're golden.
    http://www.api.org/~/media/files/oi...ine oil/motor_oil_guide_2010_120210.pdf?la=en
    Since you are driving low miles, don't let it sit longer than a month without running it up to normal temperature. It's just not good for engines to sit idle too long.
