TRYING to replace wheel bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoBlitz, Jul 24, 2011.
  1. Jul 24, 2011 at 6:13 PM
    TacoBlitz
    TacoBlitz [OP] Well-Known Member
    Jake
    Omaha, Nebraska
    01 DoubleCab SR5 TRD, white
    Topper, Yakima Racks, Yakima Loadwarrior roof basket (lights all around) 20% window tint (all 4 doors), Spectre ProFab Air Intake System, Black grille, Rino Lined rocker panels, rear bumper and flares Suspension: New OME 881 coils and OME 5 leaf rear springs, Blilstein shocks and struts, Daystar Greasable lift shackels Extended rear brake line
    I am attempting to change out my front right wheel bearing and am looking for some help from someone who has done it before or has knowledge about it. I would really appreciate any posts. thank you
    - Would it be easier to just replace the entire hub instead of just doing the bearing?
    - Should you replace both sides when you do one?
    this is what the bearing that I bought looks like:
    I can take it back if I need to
    Thanks
  2. Jul 24, 2011 at 6:16 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    it has to be pressed out.and then pressed back in.
  3. Jul 24, 2011 at 6:45 PM
    TacoBlitz
    Jake
    Omaha, Nebraska
    I thought that it needed to be but a mechanic told me that I would probably be able to do it myself with basic tools.
  4. Jul 24, 2011 at 6:55 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    I just got my rear wheel bearings done last week by my mechanic at work. I watched him do it and it was a pain in the ass! He couldnt even press it out. Had to take the torch out and heat it up, and it popped out no problem.
    The front im not too familiar with. But im pretty sure you need a press. Whats the hub assembly worth? Might be cheaper to get the hub and do it yourself rather than get someone to press your bearings.
  5. Jul 24, 2011 at 7:03 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    I would just replace the hub. And you must use a press. No way around it. Good luck.
  6. Jul 24, 2011 at 7:06 PM
    Greybeard11
    Greybeard11 New Member
    Oak Hill, Ohio
    05 SR5 Doublecab Longbed
    You are gonna definitely need a press. Even with one it was a bear to get out and back in. I had to do one side at about 120,000 miles and just did the other side at 146,000. If you want to save doing it all over later I would do both. Luckily I have a buddy with a press so it wasn,t a huge deal.
  7. Jul 24, 2011 at 11:31 PM
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    I have to do the same thing. I heard that it is not worth the money to buy a new steering knuckle. So, what I have heard is that you just have to take the steering knuckle off and take it to a machine shop with your new bearings and they will press them out/in for you for a modest fee. Check with them to be sure that you can bring in parts. Some shops sell bearings and don't install parts that are brought in by the customer.
    And yes- do both sides. One at a time is a good idea.
  8. Jul 25, 2011 at 7:24 PM
    TacoBlitz
    Jake
    Omaha, Nebraska
    Thanks everyone, this helps a lot. Can anyone tell by looking at my picture if the bearing I bought is the right one? Im just kinda confused because it doesn't even look like it will fit.
  9. Jul 25, 2011 at 7:49 PM
    Bloodhound
    Bloodhound Space For Rent
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Floor-mats, Running Boards, Shorty Antenna, AFE Pro Dry Air Filter, AVS In-Channel VentVisors, Beer cans in the bed
    I haven't done one on a Tacoma but, in my eyes and background, a press-fit bearing is a press-fit bearing...
    Heating the hub is a good advice but I've had good luck pulling them out with a slide-hammer (un-thread the pulling assembly, slip the shaft through and re-thread the pulling assembly back on) to remove them over the years. While doing this, put the new bearing in the freezer and let it thermally shrink and they go in quite a bit easier. I've actually had better luck doing them that way than with a hydraulic floor press w/o cooling the bearing. Like mentioned above, you can pull the knuckle off and have a local machine shop/well trusted garage do it for a couple bucks but the choice is yours ultimately.
    Worst comes to worst, try it yourself, if you fail, then take the knuckle off and take it to a shop. FWIW, a normal "press-fit" bearing application is around 6-9 thousandths....pretty easy to accomplish with heating for removal and letting the hub/knuckle come to ambient temp with a cold bearing.
  10. Jul 25, 2011 at 7:58 PM
    Bloodhound
    Greg
    East Moline, IL
    '10 TRD O/R DBL-CAB
    Can you measure it?
    What I got for a front wheel bearing measures:
    OD: 3.7795-96mm
    Width: 2.126-54mm
  11. Jul 28, 2011 at 6:13 AM
    Tylerm5000
    Tyler
    Oregon
    That "looks" like the right one. You can always look up the part number.
