Tsb 0062-18. Anything else?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Philsummers21, Jan 11, 2019.
  1. Jan 11, 2019 at 6:14 AM
    Philsummers21
    Philsummers21 [OP] Well-Known Member
    Phil
    20 OR LB
    Icon stage 4, 285/75-17 KO2, 5.29 gears
    Taking my truck in today to get the 62-18 flash. My truck has never been flashed. 17 PRO. I saw there was a couple tsb for transmission shifting. Will this tsb include all those or do I need to request those as well
  2. Jan 11, 2019 at 7:11 AM
    Modesto Tacoma
    Modesto Tacoma Well-Known Member
    central california
    LIMITED 4X4
    Depends on the dealership My dealer I go they just do it and the advisor usually knows what they are. But some do it as an issue basis. But if it's for transmission they will always do the newest update.
  3. Jan 11, 2019 at 7:20 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Print a copy and take it with you.
    G.
  4. Jan 11, 2019 at 7:25 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    T-SBs 77-16, 58-18 and 62-18 will all provided the newest ECU calibration. Select the one that is most easily communicated in regards to your situation. Convey the issues on the T-SB you chose to the dealership to obtain the most recent calibration.
  5. Jan 11, 2019 at 7:43 AM
    Philsummers21
    Phil
    20 OR LB
    I have both the 0077 & 62 conditions. Just told them to do the 0062. Will see what that does
  6. Jan 11, 2019 at 8:11 AM
    bludweiaer
    bludweiaer Well-Known Member
    pa
    2017 Pro DBL Cab,,2020 F3L Spyder...Polaris 800..
    avs rain guards,,,tyger auto tubesteps... stealth SR8's.265/70/17,ridge grapplers..shiftsense pro...
    had both TSB's done as soon as they came out on my 17 Pro, had 1st one done when it came out, then took it back and had 2nd one done when it came out, no questions asked, they just did it , and i made them put the new calibration sticker under the hood , per TSB
    never would have known about them if i did not come here all the time, and it was a good improvement, as far as shifting goes.
  7. Jan 11, 2019 at 9:57 AM
    Philsummers21
    Phil
    20 OR LB
    I guess my question is does the 62 flash include the 77 or are they different?
