TSB-0063-18 A/C issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by okccj, Aug 30, 2018.
  1. Aug 30, 2018 at 9:27 AM
    okccj
    okccj [OP] Well-Known Member
    Anyone have this TSB work done on their truck? If so, what symptoms were you having and what was the outcome of the work performed? Thanks in advance.
  2. Aug 30, 2018 at 5:33 PM
    okccj
    Just a little bump
  3. Aug 30, 2018 at 7:22 PM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    Mine has no problems but I just have it done anyways. Now it’s a lot better. It has linear pull when accelerating . After a thousand miles on the new program, it mellowed down a bit but still better than the original program. Holds 5th gear longer and no longer down shifts hard on 4th or 3rd gear on slight inclines. I wouldn’t even know it downshift to 5th.
  4. Aug 30, 2018 at 7:25 PM
    Raistlen0
    Raistlen0 Well-Known Member
    PA
    2017 TRD Sport DCLB AT QS
    Umm I know every one sees TSB now and thinks about the ECU update. This one being asked about is in regards to the AC:hattip:
  5. Aug 30, 2018 at 7:29 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    My baaaaad lol
  6. Aug 30, 2018 at 7:31 PM
    bulalo
    SoCAL Inland Empire
    KDMax pro 9.0
    Does this include the height pitch harmonic sound that sometimes happens during acceleration? Only happens when a/c in on . Sounds like when you lightly touch the edge of a wine glass with your fingertip
  7. Aug 30, 2018 at 7:50 PM
    Hambone437
    Hambone437 Well-Known Member
    Northern California
    2018 Tacoma TRD Off-road
    Pop & lock power tailgate Passenger Door Smart Key System mod (thank you @Victory) HomeLink garage door rear view Mirror Pro front grille swap Letter inserts on tailgate and glovebox “Tacoma” TSB-0063-18 and TSB-0058-18 performed.
    Yes, I am having this TSB done on my truck. I took my truck in last week for my AC blowing warm air on hot days when the engine is at idle. Along with getting the TSB 62-18 done and the 5k service. Unfortunately some of the components for the 63-18 are on back order and they told me that it will be about a month before they come in.
    The symptoms I had were when running the AC on hot days, it would blow nice cool air as long as I was driving at speed. But as soon as I stopped at a stop light, the air coming out of the vents was noticeably warmer. Unacceptable for a new truck. Thankfully there was this TSB 63-18. It involves installing a cooling fan in front of the AC condensing coils along with sensors and other stuff...
  8. Aug 30, 2018 at 7:57 PM
    Flash1034
    Flash1034 Well-Known Member
    N/W Montana
    2023 Toyota Tacoma TRD Pro, Solar Octane, Automatic
    MESO Stage 1.5 LED Taillights Falken Wildpeak AT3W Tires in 265/75-16
    What is involved in performing this TSB. What do they actually do?
  9. Aug 30, 2018 at 8:18 PM
    Hambone437
    Northern California
    A lot! TSB 63-18 is about 60 pages long. In a nutshell, it involves running wires through the firewall and installing a large fan in front of the radiator. I’m trying to find the full TSB. When I find it, I’ll post it. Someone else here will likely beat me to it
  10. Aug 30, 2018 at 8:59 PM
    Flash1034
    N/W Montana
    Wow...
  11. Aug 31, 2018 at 7:06 AM
    okccj
    Thanks for the reply. I found the TSB posted int he "master" TSB list thread. Here's the first page of it.
    TRD OR BUST! likes this.
  12. Aug 31, 2018 at 7:26 AM
    petr321
    petr321 Well-Known Member
    Petr
    San Diego
    2018 DCSB OR
    Do u guys think the 2019 will come stock with this new fan?
  13. Aug 31, 2018 at 8:34 AM
    Hambone437
    Northern California
    I think if enough dealers are having to implement this TSB and install the fan, that would trigger Toyota recognizing this as a serious oversight on their part and they would either start installing this fan on all Tacoma’s or have their engineers redesign the AC system to eleminate the problem from another angle.
  14. Aug 31, 2018 at 8:36 AM
    Hambone437
    Northern California
    Yup, I saw that too. You can see the whole TSB if you run it through the Imgur app. I was trying to figure out how to create a PDF through the app and apparently you can’t.
  15. Aug 31, 2018 at 9:39 AM
    Baerskin
    Baerskin Rocking in the Free World
    Manitoba
    TRD Sport Premium 4x4
    Stock
    Doing this next service!
  16. Aug 31, 2018 at 12:49 PM
    mmatheny
    mmatheny Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    Tell us if your service advisor fights you about it. I live just south of Houston and it really could use some boost in slow to no-go traffic!
  17. Aug 31, 2018 at 1:49 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    Haha my shit does this on occasion.
    g2dietzy likes this.
  18. Aug 31, 2018 at 8:13 PM
    Hambone437
    Northern California
    When I took my truck in for service last week, they said they would have to verify that there was an issue and they did. The parts are on order already. I’m just waiting for the call to say that they parts are all in. The service guy said it would be about a month (back order)
  19. Aug 31, 2018 at 9:35 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    I looked at the TSB and there’s a lot of work to just put a fan in front of the condenser- why not just have it turn on with the AC? The TSB is talking about putting in a temp sensor near the blower in the cab and having to remove the air bag to do it, etc. isnt the condenser the first radiator behind the horns?
    shakerhood likes this.
  20. Sep 1, 2018 at 6:20 AM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Been trying to understand this TSB... wish the TSB had a schematic or description of new mode of operation. Guess I will have to try and figure it out by seeing what pins it hooks to... maybe
    I didnt see any mention of an interior temp sensor (but it is very long) @OnHartung'sRoad . You remember where in the tsb it was?
    ... I also didnt see them do anything with techstream, but it is in the parts list....
    Anybody had the installation that can say if new fan runs with ac on, or what?
    SR-71A likes this.
