TSB-0092-20 is awesome!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mrengineerical, Nov 26, 2020.
  1. Dec 15, 2020 at 8:57 PM
    #241
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    Heading in for my 30K oil change in a few weeks. My VIN# is on the list and it sounds like a no-brainer to get the TSB. My only hesitation is the MPG hit that several have reported.
  2. Dec 16, 2020 at 1:11 AM
    #242
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    I think the mileage hit is based on early reports, pre-full learning the tune, and people trying to make it shift, or enjoying the bit of extra power that is felt. plus... we have winter blend fuel, effecting the fuel economy right now. i would bet after April 1st, you might see an increase in fuel mileage reports, with summer blend fuels showing up.
    i run non ethanol rec fuel so, i dont really see a mileage change, unless i cant keep my foot out of the happy pedal. your results may vary. Ski
  3. Dec 16, 2020 at 5:10 AM
    #243
    hotrodder636
    hotrodder636 Well-Known Member
    2020 Tacoma TRD Pro (MGM)
    I am new to reviewing TSBs, where is the VIN range listed? I am not seeing it or I am looking for the wrong title?
  4. Dec 16, 2020 at 5:16 AM
    #244
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    TSB-0092-20 is not VIN based, it's ECU calibration based. If you have a V6 and either a 2019 or 2020 with the following ECU codes, it applies:
    • 8966304B3000 - Engine
    • 8966304B3100 - Engine
    • 8966304B3200 - Engine
    • 896650407000 - Trans
    • 896650407100 - Trans
    • 8966304B8000 - Engine
    • 896650410000 - Trans
  5. Dec 16, 2020 at 5:19 AM
    #245
    hotrodder636
    Gotcha, thank you. Another noob question about Tacomas, where do I find my code? I googled but didn’t come up with anything.
  6. Dec 16, 2020 at 5:50 AM
    #246
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    If you have an OBD code reader, either wired or wireless to an APP, most will provide that calibration code. Otherwise, auto part stores have readers you can borrow in the parking lot to check.
    hotrodder636[QUOTED] likes this.
  7. Dec 16, 2020 at 5:50 AM
    #247
    MSGulfCoastTaco
    MSGulfCoastTaco Well-Known Member
    Mississippi Gulf Coast
    2020 MGM DBSB OFF-ROAD 4x4
    is this tool able to modify settings or just scan codes? Really want to change the number of blinks on the auto blinker. 3 is to few. 5 would be great!!! However, just trying to justify the cost just for that preference.
  8. Dec 16, 2020 at 6:00 AM
    #248
    mattleg
    Kansas
    2020 OR DCSB AT 4WD
    No, that is going to be the SAE standard powertrain only. To change the customization settings, you need something that can access Toyota specific stuff, Techstream (dealer software, but available to consumers), or something like Carista. For a new purchase, dealers are supposed to offer one free customization as well. Or if they are nice they will do it during a major service that has Techstream connected anyway, fuel pump recall for example.
    If you're so inclined, you can spend $15 for a clone VIM cable, then setup Techstream via instructions here - https://www.tacomaworld.com/threads/ecu-tsb-update.562550/#post-18431380 Then you can customize all you like, add keys, and run diagnostic tests.
  9. Dec 16, 2020 at 6:40 AM
    #249
    KVTaco
    KVTaco Well-Known Member
    Dealer has the truck now for Fuel Pump, Radar and I printed and told them I have the "insert symptoms here" and wanted the TSB. Looked like first time he saw the TSB. Ill let you know what happens, wish me luck.
  10. Dec 16, 2020 at 9:49 AM
    #250
    jimmerheck
    jimmerheck Well-Known Member
    Vancouver, WA
    2019 Tacoma Limited in white
    getting my fuel pump and tsb performed tomorrow. I am going to ask them to change the turn signal interval to 5 from 3. Wish me luck! By the way, truck was made in Jan of 19.
    ktbell444 and tonered like this.
  11. Dec 16, 2020 at 9:53 AM
    #251
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    If not there's always the opportunity to drive to Lynnwood with a case of beer for one of our fellow TW members.
    Tacodog, G8R_Taco and tonered like this.
  12. Dec 16, 2020 at 9:57 AM
    #252
    jimmerheck
    Vancouver, WA
    yes, some of our guys really deserve that beer, but its a long ways for me. If I'm ever up there, I would consider the beer to Lynwood and also Kirkland.
    ktbell444, G8R_Taco and tonered like this.
  13. Dec 16, 2020 at 10:50 AM
    #253
    [TACOMA]
    [TACOMA] Well-Known Member
    SoCal
    '17 DCLB Sport in QS
    Is the performance from this update similar or better to using the ECT?
  14. Dec 16, 2020 at 10:53 AM
    #254
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    Not quite as dramatic as ECT, but close. To me it feels like ECT was improved from the original a little bit too, with even more throttle response. It's never going to be a hot rod, but with the new flash and ECT on it feels pretty sporty. Even w/out ECT on, it feels dramatically sportier than the original factory tune when getting on the gas.
  15. Dec 16, 2020 at 1:24 PM
    #255
    KVTaco
    Got the truck back, they did both recalls and the TSB no problems, phew! I didnt drive it enough home to comment on the TSB's impact but I will after some experience with it.
    This was Middletown Toyota in CT.
  16. Dec 16, 2020 at 2:10 PM
    #256
    mikeaesq
    mikeaesq Well-Known Member
    TRD Off-road 4x4
    Going to Irvine Toyota in SoCal tomorrow for the tsb. Will report on how it goes!
  17. Dec 16, 2020 at 3:41 PM
    #257
    YMMPRO
    YMMPRO Well-Known Member
    Northern Alberta, Canada
    2018 Super White Tacoma Pro
    TRD Intake / Falken Wildpeak AT3W
    Anyone know if there is anything for the 18 , or is the OV Tune 2.0 the way to go ?
    crbr likes this.
  18. Dec 16, 2020 at 4:00 PM
    #258
    ninernation
    ninernation Well-Known Member
    WA
    TRDOR
    OME, ALUCAB, RCI
    Nothing for the 18
    YMMPRO[QUOTED] likes this.
  19. Dec 16, 2020 at 4:07 PM
    #259
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Not exactly true. There's 04A61 and 04A71 depending on transmission and if the earlier TSB was done or not.
    As always, see the TSB Update thread.
  20. Dec 16, 2020 at 5:23 PM
    #260
    gForceDude
    gForceDude Well-Known Member
    No, it's just a Scanner/Reader; but still a very handy tool to have.
    The official Toyota Techstream Software (which you can get free in this thread: https://www.tacomaworld.com/threads/ecu-tsb-update.562550/ ) will allow you to make this and many other changes.
    You will also need the Tactrix Cable to connect your computer to your truck (not free :().
    Or, you might be able to do that with the Carista App and the Carista Adapter (free service for the first 30 days, and then via a paid subscription after that). If you want to go the Carista route, then ask around here first, to be certain that it will do what you want (I don't have Carista, so I'm not certain).
    tonered likes this.
