TSB-0092-20 is awesome!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mrengineerical, Nov 26, 2020.
  1. May 11, 2024 at 11:36 AM
    #1061
    M85
    M85 Well-Known Member
    Colorado
    2019 SR ACLB
    When I'm accelerating slowly, mine will shift up around 35mph, not sure which gear it takes, but the engine drops to 1500RPM where there is no power. I wasn't done accelerating, so it has to immediately downshift to the gear it was just in. Post TSB it does this process almost instantly. Pre-TSB it would hesitate for a second in the higher gear.
  2. May 11, 2024 at 1:25 PM
    #1062
    CoolnsTaco
    CoolnsTaco Member
    Nick
    2023 Lunar Rock Tundra TRD Sport
    RC M1 Strut @ 2" Lift - Front RC N3 Shocks & 1.5" Block - Rear
    Okay yeah I have this as well. I did unplug the battery to restart the learn adapt. Mine definitely likes to finds bigger gears quickly.
  3. May 16, 2024 at 9:01 PM
    #1063
    mrengineerical
    mrengineerical [OP] Well-Known Member
    Baltimore, MD
    2019 Tacoma TRD Sport DCSB
    I noticed that the traction control is what causes hesitation during acceleration as well. It's almost like the computer is telling the engine/transmission to not give it the beans when I'm trying to give it the beans. It will take a second or two then finally decide to down shift into the proper gear.
    I turned off traction control (long press button for >3 seconds while stopped) and drove it like that and noticed significant improvement. The hesitation is only slightly there, like a fraction of a second instead of one to two seconds. Obviously you're likely to spin the wheels now that it's off, but at least the truck responds better. I'm sure a tune would make it even better.
    Canadian Caber likes this.
  4. May 17, 2024 at 11:58 PM
    #1064
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    I’ve always suspected there was a correlation between the lag and traction control. Can’t prove it. Always with the safety stuff while taking control away from the driver. Great in some situations but not so much in others. I intervene sometimes with S-mode, ECT and pedal manipulation. It’s like fighting the computer and wrestling control back.
  5. May 20, 2024 at 5:11 PM
    #1065
    CoolnsTaco
    CoolnsTaco Member
    Nick
    Honestly after adding blackhawk 2.1 tune I feel much better about the shift points. The delay before it downshift is gone... it just does it now. I have full power and feel like I own a 2023 tacoma v6. Before I was pretty disappointed in the truck.
  6. May 20, 2024 at 5:39 PM
    #1066
    mrengineerical
    Baltimore, MD
    Did you lose any mpg with the tune?
  7. May 20, 2024 at 5:40 PM
    #1067
    CoolnsTaco
    CoolnsTaco Member
    Nick
    Lol I let you when I stop having fun but I'm getting like 18.3 mpg right now.
  8. May 21, 2024 at 9:10 AM
    #1068
    baboltin
    baboltin New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    How can I tell if my truck has this update or not and if not how to install it?
  9. May 21, 2024 at 9:15 AM
    #1069
    M85
    Colorado
    2019 SR ACLB
    If the dealer does it, they are supposed to add a sticker under the hood that says something like this vehicle has been modified, new ECU program, for emissions reasons. But mine didn't add that.
    I believe there's a way to do it yourself with a Tech stream cable. I had it done at the dealer and they charged me $200 (which is probably too much).
    baboltin[QUOTED] likes this.
  10. May 21, 2024 at 10:22 AM
    #1070
    CoolnsTaco
    CoolnsTaco Member
    Nick
    baboltin likes this.
  11. May 22, 2024 at 3:45 PM
    #1071
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    I’m in California so I have to have a tune that will pass smog
  12. May 22, 2024 at 3:47 PM
    #1072
    CoolnsTaco
    CoolnsTaco Member
    Nick
    Interesting, we have emissions here in AZ as well but not sure if it changes how the emissions goes during testing.
