TSB 0132-08 Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Pugga, Feb 17, 2011.
  1. Feb 17, 2011 at 7:40 AM
    Pugga
    Pugga [OP] Pasti-Dip Free 1983 - 2015... It was a good run
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I've got the low growl/grinding noise in that 15 mph range and I'm getting the run around from my dealer because I'm out of warranty. This TSB is supposed to correct the problem by replacing the transmission mount to eliminate the vibration. Funny, the dealer was great to deal with until I hit 36k miles... Anyways, I've got 2 questions for you guys:
    1) If I just say f-it, and don't do anything about it, does this 'secondary driveline vibration' actually do any damage or is it just an annoying sound?
    2) Anyone purchased the parts and installed them yourself? After reading through the TSB, it seems pretty straight forward and I want to make sure I'm not missing something big with the install. Also wondering what the parts ran you.
  2. Feb 17, 2011 at 3:06 PM
    Pugga
    Massachusetts
    No takers?? :cool:
  3. Feb 18, 2011 at 4:47 AM
    Pugga
    Massachusetts
    Wow, no one? :confused:
  4. Jul 28, 2012 at 9:12 AM
    DR Da_da
    DR Da_da Infrequent Member
    Alabama
    '06 4x4 V6 TRD Offroad auto access cab
    ToyTec ultimate lift, LR UCAs, TRD gen 1 CAI, TRD cat-back, bull bar, anytime fog lights, lighted 4x4 switch, factory SS step tubes, factory interior lighting package, factory VIP 3200 alarm, FJ TRD center caps, rear diff breather relocate, tint, bug deflector, Weather Tech liners
    Pugga,
    I know this is reviving an old thread, but I thought I'd answer your question (it's irritating when you post a question and no one answers you!). I just ordered the parts from Champion Toyota Gulf Freeway in Houston, TX (closest/cheapest OEM parts I could find). I paid just over $94 with shipping. The parts are listed below, and my other post on this is here.
    1. 12371-31250: Insulator, Engine Mounting, RR
    2. 90201-10033: Washer Plate, 6.5mm (two required)
    3. 91671-80820: Bolt w/ Washer, 20mm (two required)
    4. 91671-B0816: Bolt w/ Washer, 15mm (four required)
    The mount is backordered and is due in to his dealership in 7-10 working days (he said Toyota is moving a lot of these right now). I'll post results in the other thread when I get it all installed.
  5. Sep 17, 2012 at 12:00 PM
    Pugga
    Massachusetts
    Damn, I completely missed your post! I read through the other thread also, there's some interesting stuff with driveline vibes going on. I just asked Camelback Toyota for the part numbers for the TSB stuff and got the same list you have. $70 for the isolator and then some hardware. After reading the other thread (thanks for the link by the way), I think my vibration is further back. I don't have a bad takeoff shudder, it's the 15-20MPH vibration. I might actually give my CB drop a shot before trying the TSB.
    Thanks for the help, I'll post back with the results!
