TSB 0273-17 Leaf Spring silencer noise
Discussion in '3rd Gen. Tacomas (2016+)' started by Murrayb4, Aug 18, 2017.
  1. Apr 15, 2018 at 5:26 PM
    #101
    Homesteader64
    Homesteader64 Well-Known Member
    Alberta
    Alpine White 17 DCSB TRD OR
    None of my old Chevy’s squeaked, and I’ve had them continuously since 77. Toyota should be ashamed if they are still putting the same squeaking shit out. If you never leave the pavement squeaks are far less likely. Any off road, and mine squeaks.
  2. Apr 21, 2018 at 9:00 AM
    #102
    j5Taco
    j5Taco Well-Known Member
    Finally took the truck in. Surprise surprise they’re blaming my springs instead of fixing their shitty pads.. hopefully I can fix in my own.
  3. Apr 21, 2018 at 9:34 AM
    #103
    TXTaco13
    TXTaco13 Taco/CJ7 Enthusiast
    Dallas, Texas
    3RD GEN AIN’T CARE 4x4
    '83 CJ7 '19 MT 07
    Your springs?
  4. Apr 21, 2018 at 9:35 AM
    #104
    j5Taco
    Headstrong add a leaf pack
  5. Apr 21, 2018 at 9:44 AM
    #105
    TXTaco13
    Dallas, Texas
    '83 CJ7 '19 MT 07
    That add a leaf goes right into the pack itself, so technically it’s still there. Since you are lifted, you might be able to take the add a leaf out, put a cheap block underneath your oems, and then get the tsb. I’d tell the Mgr they’re just rubber pads and there is a documented problem with squeaking, before adding the aal. You might also see about them just giving you the silencers for free, and putting them in yourself.
  6. Apr 21, 2018 at 9:46 AM
    #106
    j5Taco
    We’ll see... might try a more competent dealership further away.
  7. Apr 21, 2018 at 10:24 AM
    #107
    j5Taco
    “We can do it if we remove your aftermarket springs which is very labor intensive, $400”
    What a joke
  8. Apr 21, 2018 at 10:27 AM
    #108
    TXTaco13
    Dallas, Texas
    '83 CJ7 '19 MT 07
    Forgot to ask earlier, but did they squeak before the aal?
  9. Apr 21, 2018 at 10:47 AM
    #109
    j5Taco
    No but wasn’t immediately after the install either though. Asked for the new parts to do myself and he said the tsb doesn’t replace anything. Obviously he didn’t even look at it... should have trusted my gut that it would be a waste of time going there they did a horrible job updating me when my rear differential was leaking.
  10. Apr 26, 2018 at 3:27 AM
    #110
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    So tried and was rejected. The cleaned them and greased them because that's what corporate told them to do. The guy said to complain every single time I go there, and even call and complain sometimes and it will hopefully change. He said this is the process they had to use for the 16-17's and I'm not the first to come in with an 18 squeaking. Pretty much bullshit, and Toyota is not impressing me or anyone on this thread with they way they are unable to make leaf springs that don't suck after 60 years.
  11. Apr 26, 2018 at 12:20 PM
    #111
    PNWskibum
    PNWskibum Well-Known Member
    2018 TRD off-road Access cab,blue
    LED interior lights,LED lows/highs,window rain guards
    Ya when I go back in for my nex oil change I’ll be having them silence them. Had them put the noise problem in the system during the first oil change but was short on time that day and don’t live close enough to leave the truck. Will update after the next time around when I plan on leaving it there long enough for them to do something. I’m also going to make sure I go drive on some bumpy as shit roads right before I go in so they are extra loud. Will be taking to Toyota of Seattle,so far my experience with them has been positive. Last oil change they let me come in an hour early of scheduled time so I could get out to make it to another appointment that came up same day.
  12. Apr 26, 2018 at 2:32 PM
    #112
    Bridge4
    MA
    Yeah corporate shut me down, the local dealer isn't the problem. They are already squeaking again...oh well.
  13. Apr 27, 2018 at 3:13 PM
    #113
    Tibetan Nomad
    Tibetan Nomad Well-Known Member
    2016TRDOR:DCLB:JBL
    NitroGear5.29,B6112,.25"spcr,SPC:UCA,Diff-drop,ECGS
    B5160,Dakar-HD-leaf-pk+OL,UBolt-Flip,33s,Superbumps
    How many of those round plastics did they install between leafs?
    Whats the part #, maybe i should just buy and install if dealership refuses.
  14. Apr 28, 2018 at 10:29 PM
    #114
    Travisg03
    Travisg03 New Member
    Travis
    2016 Tacoma TRD Off Road
    OEM Audio Plus
    I complained to the dealer last year and they greased the springs. I went back just last week and showed them the TSB. They ordered the parts and are doing the install next week. Do I need an alignment after the round disks are installed?
    I had to show the dealer the TSB printed out in my hand. They acted like they had never heard of it before.
  15. Apr 29, 2018 at 2:54 AM
    #115
    Bridge4
    MA
    I do not think you need an alignment after, it shouldn't affect that at all.
  16. Apr 29, 2018 at 5:51 AM
    #116
    Pot_Lickr
    Pot_Lickr Well-Known Member
    Ontario, Canada
    2017 Access Cab TRD Off Road
    You can fix this yourself... I've been doing it for years on all sorts of trucks..
    Chalk your front wheels... Jack up the rear of the truck off the rear hitch, just enough to sag the springs, not so that it is off the ground...
    Take a putty knife and some "easy slide" made by "Kleen Flo" and apply it to all the spring pads,,, There is 4 I believe... Squeak will be gone..
    It is imperative that you use "easy slide"... It is a specialty brake lube for servicing your sliders... It is very resilient.. Its a form of silicone, not petroleum based..
    Normal grease doesn't hold up.. Nor does sprays..
    Good luck... this takes less than 15 mins, and it will fix it for months..
    peavey02 and Tibetan Nomad like this.
  17. Apr 29, 2018 at 6:19 AM
    #117
    Bridge4
    MA
    might have to try this since Toyota won't own up to it yet on my model year.
  18. Apr 29, 2018 at 11:14 AM
    #118
    greengs
    greengs Well-Known Member
    Calgary
    2017 ORSB Blazing Blue
    Mine just started doing it at 4,000 miles. 2017 OR. It's a bit annoying. Will have to take it in and see what they say. For the Canadians that have done this, is there a separate TSB or do they just know about the issue?
  19. Apr 29, 2018 at 3:14 PM
    #119
    Pot_Lickr
    Ontario, Canada
    Its so much easier to just do it yourself the way I explained above...
    Your going to have to eventually anyways when your warranty is out... The new ones will squeak to!
  20. Apr 29, 2018 at 3:27 PM
    #120
    Tibetan Nomad
    2016TRDOR:DCLB:JBL
    Thank you Sir!
    I will keep this in mind.
    Pot_Lickr likes this.
