Tsb + 5100 = ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MaineTaco, Aug 17, 2009.
  1. Aug 17, 2009 at 8:42 AM
    MaineTaco
    MaineTaco [OP] The NUTS
    Bangor, Maine
    06 AC 4X4 4.0 6speed Base
    K&N drop in, Ride TSB, Tail gate TSB, Scan Gauge ll, Factory seat covers, Hella head lights
    Hey Guys. I’m getting the 5100 next week, and I all ready have the TSB. My question is what should I have the 5100 set at to have the truck level or just a bit ass high? I’m thinking 1.75" but I’m not sure. I searched but couldn’t find just what I wanted, so sorry for the repost in advance.
    Will
  2. Aug 17, 2009 at 8:45 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I think that will give you pretty darn close to an even setup. I went with the TSB AAL in addition to the 5100s at 1.75 to keep a slight rake. I didn't want to put anything in the bed and have the rear sag lower than the front.
  3. Aug 17, 2009 at 8:47 AM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    Put the front at 2.5. Mine is completely level with the TSB.
  4. Aug 17, 2009 at 9:15 AM
    dw77x
    dw77x Those are not my pants
    SE Wisconsin
    2009 Tacoma Sport LB
    5100's all 4 corners (front at 2.5"), rear tsb springs with 1.5" AAL, 265/70/17 General Grabber AT2's
    I have tsb springs with aal front at 2.5, sits very level. I also have a fibergalss cap and some other junk in the back at all times.
  5. Aug 17, 2009 at 9:18 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    I went 1.75, check out my pics, it is pretty level just a slight bit front rake, all stock except tsb and 1.75 5100's.
  6. Aug 17, 2009 at 9:20 AM
    hendooman
    Jeff
    KC
    You have any issues with vibrations or alignment at 2.5? I know some do, and some don't...I kept mine at 1.75 for that very reason.
  7. Aug 17, 2009 at 9:24 AM
    dw77x
    SE Wisconsin
    No vibes and goes down the road great (no wandering that I have noticed). I had the alignment done somewhere decent and it came in very well.
  8. Aug 17, 2009 at 9:29 AM
    hendooman
    Jeff
    KC
    That's good to know thanks. I think I will wait to switch mine when I get an AAL. Should be a nice little height bump. New tread would be nice as well...
  9. Aug 17, 2009 at 9:32 AM
    dw77x
    SE Wisconsin
    Another thought. . .I have the long box = longer drive shaft = less angle thus less drive line vibes? can anyone back that up? seems to make sense to me.
  10. Aug 17, 2009 at 9:32 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    Set them to 1.75....still have slight rake toward front
  11. Aug 17, 2009 at 9:39 AM
    drew02a
    drew02a Rocking your mom's world Since 1997
    San Antonio, TX
    2006 Regular Cab 2.7L 4x4
    Mine's a regular cab, but with TSB, billies at 1.75 and 1/2" top spacer it is perfectly level.
  12. Aug 17, 2009 at 9:51 AM
    raskal311
    raskal311 Well-Known Member
    S. Cal
    5100 set to max, pending LSD and TRD CAI
    I have my 5100 set at 2.5 and it looks pretty level as well.
  13. Aug 17, 2009 at 10:42 AM
    MaineTaco
    Bangor, Maine
    Ok, just so that i have this right, with a stock truck (2006 AC 4x4) with the TSB if I put the 5100 on at 1.75" I will still have some rake. I want that any way because I cut wood and I dont want it to be ass low any time I have more than 200# in the back. I do plan on putting on some "Supersprings" soon and that will add a bit of lift to the rear, then I will bump up the 5100 to 2.5. Thanks in advance.
    Will
  14. Aug 17, 2009 at 12:01 PM
    MaineTaco
    Bangor, Maine
  15. Aug 17, 2009 at 12:05 PM
    yosh2000
    yosh2000 Well-Known Member
    Denver, CO
    '17 Tundra CM 5.7
    as do i. alignment is slightly off according to the numbers, but is as close as you can get w/ OEM UCAs. tire wear isnt that bad.
  16. Aug 17, 2009 at 1:02 PM
    derekabraham
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Nope. Everything is perfect. :D
