Tsb, aal ?
Discussion in 'Suspension' started by muliefever, Oct 26, 2008.
  1. Oct 26, 2008 at 8:52 AM
    muliefever
    muliefever [OP] Muliefever
    Tillamook, Oregon
    14' DCSB TRD
    5100's, 887', CB, 265's, FM Deltaflow
    I have to get something clarified. The TSB is only for trucks up to 07? Or is it for trucks that only have a 3 leaf pack? I am going to buy 5100's for up front and set them at around 2.5". I planned on buying a toytec AAl to lift the rear. Should I stick to my plan? Or will/should my truck qualify for the TSB? Seems how it only has a 3 pack. I know the TSB will only lift the rear around 1". I was kinda hoping for 2" with a AAL..
    Thanks.
  2. Oct 26, 2008 at 10:17 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    12 Tundra TRDRW
    Nada, Zip, Zilch, Nothing
    TSB is for up to 07 Tacos but some have had good luck with their 08s and some dealers. The TSB is free vs. the AAL which costs $$... might be worth it to try to get the TSB done.
  3. Oct 26, 2008 at 10:29 AM
    Brunes
    Brunes abides.
    Rotorhead
    The TSB now DOES include 08 trucks. This is a fairly recent change...there is a large thread about it.
    Your truck most likely will qualify for the TSB...however the TSB is NOT a lift-It will give you between 1/2 and 1 inch in the back.
    If you get the TSB- You'll have to do some extra work with an AAL to get the full 2 inches.
    If I were you...I'd skip the TSB and get the AAL....It's what...70 dollars or so.
  4. Oct 26, 2008 at 10:38 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I agree. Get the AAL instead. I got the TSB done and bought a ToyTec AAL. However, to get the AAL to work with the TSB springs, you gotta kinda "make" it work. Chris4x4 says that they will work with the TSB springs, but you either have to install them backwards or cut about a 1/2" off the AAL. For that reason, I haven't tackled it yet.
    As a side note, I have an '09 and the dealership didn't even blink about doing the TSB for me, although I think this is a dealership by dealership thing. The '09 isn't officially included in the TSB - but I checked my springs and the part numbers matched. It raised my back almost a full inch, but it will settle.
  5. Oct 26, 2008 at 10:39 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I have to go the opposite way on this. I say GET the TSB. My truck rides much better with the TSB AND AAL than it did with the factory 3 spring and AAL. :)
  6. Oct 26, 2008 at 10:42 AM
    LonghornTaco
    Minnesota
    Sorry dude, I thought I read somewhere that you recommended that if you were thinking about an AAL you should skip the TSB.
    That's what I get for speaking for someone else! I've learned my lesson now, sir...... :eek::eek:
  7. Oct 26, 2008 at 10:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    "SIR"? Dont call me that! :D
  8. Oct 26, 2008 at 10:49 AM
    Delmarva
    Tucson, AZ
    12 Tundra TRDRW
    oops... lol
  9. Oct 26, 2008 at 10:52 AM
    Brunes
    Brunes abides.
    Rotorhead
    So the benefit of the TSB out weighs the hassle of installing the AAL??
  10. Oct 26, 2008 at 10:53 AM
    dtrujillo63
    dtrujillo63 Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    Chris,
    I currently have an AAL and shims. Do you think I can still get the TSB done or will the dealer deny me because I already modified the leafs?
  11. Oct 26, 2008 at 1:04 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. The TSB springs are MUCH better than the stock ones.
    You should be able to. I had my AAL in when I took it in for the TSB. Only problem was that they didnt put the AAL back in because the center pin wasnt long enough. No biggie. Also, they didnt put the new "U" bolts in, so I chewed their asses about that. I asked for the new "U" bolts and just installed everything myself. Center pins are available at any off road shop, and they sell them in only one length, you just have to cut it to size once its installed. Easy task with a hacksaw. :)
  12. Oct 26, 2008 at 6:14 PM
    muliefever
    Tillamook, Oregon
    14' DCSB TRD
    okay so my best option is to get the TSB done.. And get a AAL.. Will that give me a 3" rear lift? How much did yours lift chris?
  13. Oct 26, 2008 at 6:22 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have a 1" AAL. That and the TSB springs gave 2". You can see if a spring shop can make you an AAL (which is what I did), or have them take out some arch on a 2" AAL, or search for a 1" AAL. :)
  14. Oct 26, 2008 at 7:26 PM
    LonghornTaco
    Minnesota
    If I have the TSB done and a 2" AAL, will I need longer shocks or will the rear 5100s work?
  15. Oct 26, 2008 at 7:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The rear 5100's are desighned for a 0" to 2" rear lift. That being said, I REALLY like the ride of the 5100's and I think you should just get the shock extenders from Toytec.
  16. Oct 26, 2008 at 8:19 PM
    LonghornTaco
    Minnesota
    ToyTecs site says that the shock extenders are for the "stock TRD Bilstein" shocks. Will they work with the 5100s? Also, will I need to extend any brake lines?
  17. Oct 27, 2008 at 6:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They should work just fine with the 5100 shocks. If they dont, you can always return them. I didnt extend my brake lines. I just bent the bracket to allow full droop.
  18. Oct 27, 2008 at 6:16 PM
    Ghost96Romeo
    Ghost96Romeo What is the Search Tab for????
    Texas
    06 TRD Off-Road D-Cab
    3" Pro-Comp Suspension Lift AAL Rear w/TSB, All-Pro Plate Bumper, Lightforce 240 Blitz lights, Lund Genesis Roll-top Bed cover, K&N Filters, Spidertrax Wheel spacers, Built-by-Me Rock Sliders, Jeep Tow-Hook, Black Leather seats, 48"Hi-Lift Jack mounted in the bed, Blacked out TRD Rims, BHLM, FLM..... and Awesomeness
    What is an AAL?:confused:
  19. Oct 27, 2008 at 6:26 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Add A Leaf. :)
  20. Oct 27, 2008 at 6:28 PM
    Ghost96Romeo
    Texas
    hahaha.....why didn't I catch that? :rolleyes: To think I already have that done to mine anyways....
    Will dealers do the TSB if a AAL is already installed?
