Tsb + aal
Discussion in 'Suspension' started by MyMistress, Apr 27, 2010.
  1. Apr 27, 2010 at 7:10 PM
    MyMistress
    MyMistress [OP] Well-Known Member
    TN
    10 TRD Sport 4X
    Leveled front, TSB rear, TSB Transmission, Always on fog lights, Socked windshield / bedsides, Trimmed mud flaps, Weather Techs, 4 Extra d-rings, Map Light Mod, Avid Light Bar, OEM Bed Mat, Locked Back Window, Secret Stash Area,
    2010 TRD Sport DC 4X with TSB and 2.5 front spacers. Looks pretty level, but would like to regain slight rake. Would i be tempting driveshaft vibration with a 1 inch AAL? Or should I just thro a 1/2 inch block in?
    Oh, I am a daily driver, mall crawler. I just want the truck to look like it could do what many are built to do......
    Thanks
  2. Apr 29, 2010 at 7:53 PM
    twr437
    twr437 Well-Known Member
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    nerf bars, bed cover, husky liners, Icon coilovers, LR UCA, rear 5100s, TSB AAL, diff drop, carrier baring drop, axel shims, AFE pro dry filter, BHLM, mesh grill, Black emblems,
    I dont think there are many people out there with the TSB trying to add a AAL. I have the same question and haven't got much responce. They only make a 1.5" AAL for the TSB. From what I here you really want to stay away form blocks. I just ordered my AAL from Toytec.
  3. Apr 29, 2010 at 8:05 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    good timing with this question......i have an 07 DC 4x4...i do have the TSB springs, and about a month ago, i installed a 1.5in AAL. i got a small vibration from 5 to 10 mph. just this morning i got it to go completely away in literally 10 minutes. i had a piece of aluminum laying around (1.5''x6''x.25'') i used a hack saw to cut two pieces off (dimernsions of about 1.5''x.75''x.25'', drilled a hole in it, and used them to drop the carrier bearing. worked like a charm! if you don't have any aluminum to do this with, or don't have a hacksaw and drill, toytec sells a kit with everythign you need. i think they go for about $10. so 10 minutes or $10 isn't too bad.
    btw, i am running a 2.5in lift up front, so essentially the same as you...the 1.5 inch AAL was perfect when paired with the 2.5 front. toytec actually sells an AAL specifically made for the TSB springs
  4. Apr 29, 2010 at 8:05 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    I dont have the rear TSB but I just ordered that AAL, I'm curiouse as to how much forward rake I'm going to have, if any at all. I do a lot of towing and hauling so I am wondering if that has cause my rear susp. to sag even more. Currently it seems to be bottoming out on every bump w/o any weight in the bed. Hopefully I wont have much forward rake and wont have to add a lift to the front.
  5. Apr 29, 2010 at 8:11 PM
    SamSter0077
    SamSter0077 Happy Camper
    Katy, TX
    09 Tacoma 4x4 TRD OR
    OME 886 Coils, and Struts, Rear Toytec TSB AAL/ OME shock absorbers, Fog Lamp anytime mod, Voyager Brake Controller.
    tsb back end, toytec tsb aal 1.5"... it was too high honestly.. just barely. CB drop took care of mosst of the vibes, and the 3 dgree shim took car of the rest.. there is a VERY slight "shudder" from zero if you barely hit the gas..
  6. Apr 30, 2010 at 9:40 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
