TSB Advice
Discussion in 'Suspension' started by MTL Tacoma, Apr 16, 2009.
  1. Apr 16, 2009 at 8:53 AM
    MTL Tacoma
    MTL Tacoma [OP] Well-Known Member
    Montreal, Canada
    2016 DC LB TRD Sport
    Hey Guys,
    I have an appointment next Monday morning (April 20th) to get the TSB done. It was a bit of an issue because I purchased my truck in Vermont and i'm getting the work done here in Montreal. Long story short, once I presented a copy of the TSB and mentioned that I had a case file open with Toyota, they were more than happy to schedule the corrective work;).
    As you can see I have a TRD Sport, so if I understand correctly, they will swap the current 3 leaf pack for a 4 leaf assembly and install new U-bolts and they will perform an alignment. Is that it? What should I be looking for once I pick up the truck. Don't be afraid to "spell it out", as I have limited automotive knowledge!
    Thanks in advance for the advice and thanks to all of those who have posted information and stories regarding this issue. I was more than prepared when it can time to "fight it out" with the dealership!!!
    I'll keep you guys posted!!
  2. Apr 16, 2009 at 9:20 AM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    Great news!! Thats awesome!!
    So the parts were ordered?? Or are they "checking" things out on Monday, then ordering parts?
  3. Apr 16, 2009 at 9:22 AM
    MTL Tacoma
    Montreal, Canada
    Parts are ordered and they will do the work on Monday!
  4. Apr 16, 2009 at 10:41 AM
    MTL Tacoma
    Montreal, Canada
  5. Apr 17, 2009 at 6:05 AM
    MTL Tacoma
    Montreal, Canada
    bump X2
  6. Apr 17, 2009 at 6:08 AM
    brianr
    brianr go shit in your hat
    2010 4x4
    BUILT, not bought...
    They should present you with a sheet that details the alingment.
  7. Apr 17, 2009 at 6:09 AM
    Brunes
    Brunes abides.
    Rotorhead
    That's it. You have the TRD shocks already so they won't be replacing those and the 4 leaf swap with the correct hardware for fitment and the alignment (with print out) is the deal.
    Should be pretty easy for them to do...but they HAVE messed them up in the past. check to make sure the part #'s on each side are correct (That will ensure you have 4 leaf packs set on the proper sides) and make sure you don't hear any weird sounds (squeaking or grinding are especially bad).
    Best of luck!!
