TSB & Aftermarket lift
Discussion in 'Suspension' started by FamouzStarz, Feb 28, 2008.
  1. Feb 28, 2008 at 1:24 PM
    FamouzStarz
    FamouzStarz [OP] The illest taco
    21 TRD PRO
    ICON Build and then some
    so i need to take my truck in for the tsb but would still like a lift as well do i
    1) get the tsb done
    2) get the lift done before the tsb
    3) get the tsb then the lift
    4) tsb only
    looking for a 3" lift possibly the toytec just wondering what everyone else out there has done or will be doing. Or is there a better/ different kit thats works better with the tsb.
    Thanks:cool:
    SX
  2. Feb 28, 2008 at 1:31 PM
    tcBob
    tcBob Gringo Bandito Moderator
    Bob
    07 PreRunner SR5 V6 Black
    tsb then lift
  3. Feb 28, 2008 at 1:51 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Yeah, Toyota might try to give you some crap about having the lift, so I'd wait until after the lift.
  4. Feb 28, 2008 at 2:24 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    tsb then blocks in the rear for the extra that u need. i've got 2.5" up front and the tsb/2" blocks in the back
  5. Feb 29, 2008 at 8:38 AM
    nd
    nd Radical Town. It's a hell of a place!
    Nate
    Greenville, SC
    07 TRD Off-Road 4x4 debadged
    De badged, 5100's, Black Toyota Baja wheels
    my 5100's will be here soon. i was hoping to be able to just use the shocks and the tsb but it looks like i'm gonna have to add blocks to the back. do you think i can get away with just a 1" block in the rear?
  6. Feb 29, 2008 at 8:42 AM
    Hotdog
    Hotdog
    Wet Okole Underwear
    the 5100s are adjustable. Are you planning on setting them at their max? If you set them around 1-1.5 in that will probably level it out.
  7. Feb 29, 2008 at 9:18 AM
    nd
    Nate
    Greenville, SC
    i was hoping to set them at 2.5 but i may set them at 1.75 then put a block on the back and re-adjust the front to 2.5. i was hoping i could set them at max and be level but it doesnt look like that will work
  8. Feb 29, 2008 at 1:38 PM
    The_Hodge
    SC
    are u wanting a completely level look? if so, u should be able to do the tsb and get the 5100's set on 2.5" and it will look pretty damn level. the front might be up about 1/4-1/2". i went overboard w/ 2" blocks in the back...but it does make sense for going offroad and now i have a lil less to worry about hitting rocks under the cab area...eventhough i'll have those sliders on by then
  9. Mar 4, 2008 at 12:23 PM
    Toycoma06
    Toycoma06 Well-Known Member
    Richmond Va.
    2016 tacoma 4x4 dbl. cab
    20% window tint, emblems removed, aftermarket grill, TRD Pro shift knob,4'' RC lift with BDS 2.0 fox rear shocks, 285x65r18 Nitto Ridge Grappler, 18x9 Monster Energy 540B 0mm offset, ...and more to come
    TSB and then the lift !!! Check my pic. out..... I am running a 3'' Toytec OME 884's with TSB and 1.5'' block.( tires and wheels are soon) Not sure if i like the 884's, to me it looks like you get a little more lift out of the spacer puck then the full spring??? Could just be me.......ive got use to looking at the lift.
  10. Mar 14, 2008 at 8:41 AM
    FamouzStarz
    21 TRD PRO
    so did you piece your own kit together? whats your complete lift / tsb kit? i was looking at your pics and the height looks good im thinking this the route i want to go just need some details :cool:
  11. Mar 14, 2008 at 12:18 PM
    Toycoma06
    Richmond Va.
    My kit is a Toytec, part #OME3-05-bk. Also i ordered the 1'' diff. drop kit. You need to go with the 885's coils to get a full 3'' lift on the dbl. cab. If you have got the TSB done, go with the 1.5 block kit (same price). If i had to do it over i would have just went with the Toytec 3'' puk spacer. The reason i say that is about four weeks after install it looks like my OME springs have started a sag alittle. If you are looking for a factory ride, OME springs are the way to go!!!!
  12. Mar 14, 2008 at 12:24 PM
    nd
    Nate
    Greenville, SC
    I like to have a little bit of a raked look. i think i'm gonna go for 1.75 up front with no blocks in the back. I think it will be level and not raked like i want but oh well. i have completely decided against blocks. i have heard too many negative things. i'll just do the 1.75 and stick with taht until the trucks paid off, then put on a 6 inch or something.
  13. Mar 14, 2008 at 12:27 PM
    FamouzStarz
    21 TRD PRO
    im starting to wonder if i should just can the tsb and go with a toytec full 3" lift or something
  14. Mar 14, 2008 at 1:39 PM
    The_Hodge
    SC
    tsb+2" blocks in the rear...and 2.5" up front. i think it'd look a lil better w/ 3" up front and the same as mine in the rear. get that lil extra .5" in the front
  15. Mar 24, 2008 at 2:45 PM
    FamouzStarz
    21 TRD PRO
    well i called to schedule a tsb inspection, it qualified they called a sister store and wam bam tsb fix in one day, now just waiting for the call to go pick up the truck oh yea!!
  16. Apr 16, 2008 at 5:23 PM
    FamouzStarz
    21 TRD PRO
    well i went with your advice 3" up front and 2" block on the rear and its f'in sweet :cool:
  17. Apr 16, 2008 at 6:09 PM
    The_Hodge
    SC
    if u start feeling any vibes over 55mph or while slowing down 20-25mph, get the toytec shims...$25 and it'll fix ya up right
    EDIT: and i wish i had gone 3" spacers up front now as well
