tsb and 33's
Discussion in 'Suspension' started by lakerlax, Sep 7, 2010.
  1. Sep 7, 2010 at 6:06 PM
    lakerlax
    lakerlax [OP] Member
    I am getting the Spring tsb work done next week on my 09 dc tacoma trd sport. How can i fit 33's now after getting the tsb done keeping the stock wheels or going to the procomp steel wheels.
  2. Sep 7, 2010 at 6:07 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    which size of tire: 255/85 or 285/75?
  3. Sep 7, 2010 at 6:08 PM
    08pretaco
    08pretaco Almost there
    Oliver
    az
    2014 Tundra 4x4 CM 5.7L SR5
    AFE pro dry s, Husky X-act Contour
    that back isnt the issue its the front. you need a 3" front lift
  4. Sep 7, 2010 at 6:11 PM
    Brunes
    Brunes abides.
    Rotorhead
    ^This....
  5. Sep 7, 2010 at 6:13 PM
    tacosupreme54
    tacosupreme54 Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    yeah, you will need at least 2.5 or a true 3 inches in the front. as far as the 33's...the 255/85's will work as is on the stock wheels. you do need to know that this tire is pretty "skinny" and they are also pretty hard to find. to fit a 285/70, you should get some wheel spacers. if you get wider wheels, you can do either. your first step will have to be some type of front lift though.
  6. Sep 7, 2010 at 6:18 PM
    S.B.
    Sean
    another thing to consider is that 285s will eat your gas milage. I still get 20mpg (same as with stock tires) with my 255s.
  7. Sep 7, 2010 at 6:19 PM
    lakerlax
    i have no problem going with aftermarket wheels. i was hoping to just paint my stock ones but it doesnt matter. I would like the 285's though or true 33's. I will drop to 16in rim if necessary. my old jeep had 33'sx12.50 which i loved but not sure if i can fit on tacoma. I just am looking for a good less expensive lift for some offroading without going the spacer route.
  8. Sep 7, 2010 at 6:23 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    i think 285's will be fine. if you get the 33x12.5, you will lose a lot of mpg's. you can do it on a 3" lift, but there will be a lot of trimming.
  9. Sep 7, 2010 at 6:28 PM
    lakerlax
    so can anyone give me the exact setup i need with the tsb to fit the 285's with 17 or 16in rims.
  10. Sep 7, 2010 at 6:32 PM
    S.B.
    Sean
    I would get 16" rims. there is more sidewall and they are cheaper.
  11. Sep 7, 2010 at 6:32 PM
    Brunes
    Brunes abides.
    Rotorhead
    Any 3 inch lift...Toytec, OME, etc...Should get you there.
  12. Sep 7, 2010 at 6:34 PM
    lakerlax
    i would just prefer not to go with spacers up front or blocks in the back. just a true 3in suspension lift for 285's on 16s.
  13. Sep 7, 2010 at 6:34 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue V-6 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 305/65/17 mickey thompson baja atz Allpro hybrid bumper with 3 kragen HID lights color matched headlights grill craft grill AFE stage 3 CAI wicked flow muffler under cover bed cap inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    i had 33 on stock height and stock wheels.........
  14. Sep 7, 2010 at 6:38 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    that's up to you and your budget. you will have to pick out suspension parts you can afford/actually need. i can give you an idea of what you need to be looking for; you need to get at least 2.5-3" in the front and i'm not sure about the rear bc i don't have the tsb springs. but you would probably need to go with the 1.5" tsb aal. if you stick with the wheels you have, you need some wheel spacers. if you get aftermarket wheels that are 8 or 9" wide, you won't need the spacers. you also might want to look into new uca's, you don't have to have them, but they can help out. all of that should help you clear 33's. you can find all this stuff on toyteclifts.com. we can't pick this stuff out for you specifically because we don't know what you can afford or exactly what you want. they have complete lift kits on there also.
  15. Sep 7, 2010 at 6:40 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    Nice Post +1 But I would go with 5100s at 2.5 with 285s and spidertrax. You might have to trim, but it looks good you dont need new UCA at 2.5
  16. Sep 7, 2010 at 6:41 PM
    toyo freak
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    Hey tacosupreme what size tires you running?
  17. Sep 7, 2010 at 6:43 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    thanks, and what do they look like to you...? :cool:
  18. Sep 7, 2010 at 6:44 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    265/70/17 ?
  19. Sep 7, 2010 at 6:45 PM
    OZ-T
    Peter North
    British Columbia
    265/75/16 ?
  20. Sep 7, 2010 at 6:45 PM
    lakerlax
    i would prefer to keep the lift under $500. I am getting bilstein 5100's for the front and will get pro comp 16's.
