TSB and AAL
Discussion in 'Suspension' started by ninjanate, Feb 1, 2011.
  1. Feb 1, 2011 at 2:01 PM
    ninjanate
    ninjanate [OP] Active Member
    Nate
    Brigham city UT.
    2011 TRD Sport 4X4 double cab long bed
    custom light bar w/extra reverse light. blacked out tail light mod. Satoshi grille mod. Goodyear Wrangler Dura Tracs 265-70R-17.
    I feel totally dumb but I am seeing a ton of post about TSB and AAL with the dealership changing them out to help with towing and load carrying but am confused on what it actually is. Can someone help me out please?? I have a 2011 4x4 sports SR5 and just want to know if this is something I should look into getting. This is my first 4X4 truck which is why I am confused with the off road truck talk. Thanks allot. Please don't judge lol
  2. Feb 2, 2011 at 7:08 AM
    MedlinAround
    MedlinAround Failure is the result of letting setbacks stop you
    Cody
    Kentucky
    2008 TRD off-road edition Tacoma
    Bilstein 5100's, OME 885X Coils, Dakar HD Springs, Fox 2.0 Rear Shocks, Magnaflow exhaust, Volant Intake, OKledlight pods, Front Skid Plate, Weathertec Floor Liners, Custom Bed Rack, TRD Nation interior LED dome kit, 4X innovations sliders, DIY Roof Rack, Smittybilt RTT.
    TSB is simply where Toyota adds a leaf with a new lift spring pack (some do it for height, some like the ride a little stiffer, sone both). On non TRD packages they replace the suspension. It is free, call and set up a appointment.
    AAL or add a leaf, you buy it to however high you want, and install it yourself.
    You can do both for a bigger lift if you'd like.
  3. Feb 2, 2011 at 7:26 AM
    BryWi
    BryWi Psalm 109:8
    Earth
    2011 TRD off-road DC SB w/JBL
    5100s, black valance
    Be aware, it will stiffen up the ride a bit and give you about 1" in rear lift when it settles.
  4. Feb 2, 2011 at 7:58 AM
    Rich Beauregard
    Rich Beauregard Well-Known Member
    Rich
    New London, CT
    17 Taco 4x4 SR5 Access Cab White
    TSB is Technical Sevice Bulletin and there are many of them foe the Tacoma. One happens to be for rear leaf springs. Some TSB's should be recalls, but since they do not tell anyone but the dealers about them, it saves Toyota money and screws the rest of us. If you don't complain to your dealer about the poor leaf springs, they will not tell you about them. Same for all the other TSB's. That way after you pass 36,000 miles they will say "To bad, you want it fixed then you have to pay." There many TSB's for 05-09 Tacomas and these may include the 2010 & 20011 but you will have to find out if they apply to yours or if they were fixed by the new model year etc...
    Here are some:
    TSB List for 2005 - 2009 Toyota Tacoma
    TSB = Technical Service Bulletin
    A TSB is not a recall.
    AU001-05 FEB 06 Audio System - Amplifier Won't Turn OFF/Battery Drain
    AU001-06 FEB 07 Audio System - Quick Reference Diagnostic Guide
    BO001-06 JAN 06 Body - Front/Rear Window Runs Deformed
    BO003-05 MAR 05 Body - Overfender Refinishing Process
    BO004-05 APR 05 Body - Water Leaks Onto Front Floor
    BO018-07 NOV 07 Body - Bent Rear Tailgate
    BO022-06 NOV 06 Interior - Driver's Side Lower Dash Panel Poor Fit
    EG011-07 JUL 07 Engine Controls - Intermittent No Start Condition
    EG021-06 APR 06 Exhaust System - Ticking Noise Between 2,000-2,500 RPM
    EG043-05 MAY 06 Fuel System - MIL ON/DTC's/No Start in Extreme Cold
    EG046-06 AUG 06 Intake System - Air Intake Hose Rattle
    NV003-06 MAR 06 Body - Front End Rattle/Squeak on Bumps
    NV004-06 MAY 06 Interior - Front Seat Squeak Noise
    NV006-07 AUG 07 Body - Windshield Wind Noise at Highway Speeds
    NV007-05 JUN 05 Body - Front/Rear Popping/Knocking Noise on Rough Roads
    NV007-07 JUL 07 Body - Dech Side Panel Rattle
    PD039-04 SEP 04 Pre Delivery - Initial Calibration Of Compass
    PD075-06 AUG 06 Pre Delivery - TPS Initialization Procedure
    PG004-06 NOV 06 General - TPS Diagnostic Tips
    SS002-07 APR 07 Engine Controls - ECU Flash Reprogramming Procedure
    SU002-05 NOV 05 Suspension - Rear Suspension Noise
    SU006-07 SEP 07 Suspension - Harsh Rear Spring Ride With Heavy Loads
    TC004-06 JUN 06 M/T - Clutch Pedal Squeaking Noise
    T-SB-0132-08 JUL 08 Drivetrain - Driveline Vibration Between 15 - 25 MPH
    T-SB-0305-08 SEP 08 Suspension - Rear Spring Harsh Ride
    T-SB-0164-09 MAY 09 Abnnormal Sound from JBL Subwoofer
    Just use the search section and put in "TSB"
  5. Feb 2, 2011 at 8:53 AM
    ninjanate
    Nate
    Brigham city UT.
    thanks a ton so i just need to call and complain about the rear leaf springs then i will get the new higher stiffer ones? complain about bottoming out with load in it or what ? i just wanna bullshit the dealer without them thinking im bullshiting them. :cheers:
  6. Feb 2, 2011 at 8:41 PM
    MedlinAround
    Cody
    Kentucky
    yeap you just answered your question. Call act like when you have something in the back it bottoms out and is very soft. Tell them you talked to Toyota and they said it was a " Harsh Ride" bulletin. Somewhere on here you can find the exact document, print it out, and take it to the dealer so no questions could be asked.
  7. Jun 20, 2011 at 6:25 AM
    gray liquid
    gray liquid Member
    NC, for now
    '08 2.7, 4x4, access cab
    rmvd 2ndary air filter, memphis audio speakers,lce header, mobil1 full syn engoil(factory filter), afe pro dry s drop in,
    Just made an appt fot tomorow to have the squeak looked at. the svc guy even said if it is the springs, there will be a much stiffer ride. anyone have any exp with this, just want to know how much stiffer not sure it will be worth it.
  8. Jun 20, 2011 at 6:32 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    It's not much stiffer. I actually think it rides better! It's hard to explain but as soon as you drive one with it done you'll notice it.
  9. Aug 16, 2011 at 9:35 AM
    pearlthetaco
    pearlthetaco Current Member
    Duxbury, VT
    05 DblCab V6 SR5 (6-speed), 4.0
    front mud guards removal; line-x'd rocker
    With the non-trd option package, they replace the shocks and struts with billstein 5100's that are adjustable correct? Or is it another series of Bilstein? Sorry if this is a stupid question? Taking forever to search forum through and find this answer
  10. Aug 16, 2011 at 9:43 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    For the older TSB, they would replace the shocks and struts with Bilstein shocks, NOT the 5100's. It's the same ones that came stock on the TRD Sport and Off Road models. Still better than the Tokiko shocks that came on the SR5 and base models. I don't think your truck will qualify, the TSB is covered in the 3 yr 36k mile bumper to bumper warranty. I think you're a little late.
  11. Aug 16, 2011 at 2:26 PM
    pearlthetaco
    Duxbury, VT
    thanks pugga
