TSB And AAL?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TheTacoManChach, May 26, 2009.
  1. May 26, 2009 at 7:12 PM
    TheTacoManChach
    TheTacoManChach [OP] I AM THE GREAT CHACHOLIO!!!
    Brian
    Fayetteville, TX
    2006 Toyota Tacoma Double Cab Prerunner SR5
    Halo Headlights Black W/ LED LED TailLights Bermuda 3rd Brake Black Pioneer/Alpine System Debadge Entire Rebadge Driver Side Door Black Volant CAI Tool Box ARB Front Bumper Flat Black Painted Grill Surround
    I want a 3 inch lift from what I got with my prerunner...
    Im trying to get my TSB kit from Toyota, tomorrow their gonna look at it...
    If I do get that TSB what else will I need to get the full 3" that I want.
    I don't want Spacers unless absolutely necessary ( i know u need a 1/4" to eliminate tacolean).
  2. May 27, 2009 at 3:08 PM
    TheTacoManChach
    Brian
    Fayetteville, TX
    got approved today!!!
    bump on question though
  3. May 27, 2009 at 4:42 PM
    Jimirich
    Jimirich Well-Known Member
    Hawaii
    08 4x4 Dbl cab shorty O.R. pkg
    DTRL, Debadged, Donkey tethered in the bed that rips 142 db farts so I can piss off the neighbors and rattle the windows on my house when I'm parked in front.
    Toytec has a AAL that is for TSB rear springs. makes it five total.
    Call them
  4. May 27, 2009 at 6:08 PM
    TheTacoManChach
    Brian
    Fayetteville, TX
  5. May 28, 2009 at 3:24 PM
    TheTacoManChach
    Brian
    Fayetteville, TX
    no one wants to put in their 2 cents? jesus...
  6. May 28, 2009 at 3:30 PM
    neontrail
    neontrail ✈ ✈ ✈ ✈ ✈ ✈ ✈
    Idaho
    2004 NISSAN XTERRA XE/SE
    De-badged, Tint 20%, Blue 48 LED dome-light, .......
    LOL Chach, I'd help ya if I knew. I think they have something aginst Texans....LOL
  7. May 28, 2009 at 3:35 PM
    kingN8
    kingN8 Well-Known Member
    Southern Mississippi
    05 Impulse Red Corolla S
    i asked at this time of day for advice and found out its working hours for most people. Give it some time. You'll get some help
  8. May 28, 2009 at 3:37 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    On your first link- that says for tundra. ome 884s seem a bit much for the tacoma IIRC.
    2nd link is what I used out back with my 3 leaf caca-rides nice now.
    3rd link - yes, but get the 4 pack for 262 with DSM motorsports discount thru the forum here.
    4th link - yes, that is the taco lean spacer I used up front on drvr side.
    You should get new set of TRD bilsteins you can sell when they do the tsb but use the springs, strut hats on the 5100s.
    I just went with 5100s all around set at 2.5 with trd springs/hats & the taco lean spacer on driver side up front. Out back went with Toytec TSB AAL 1.5 that goes with either tsb or non tsb leafs. I didn't get tsb because truck was over 36000 miles. Toytec also has a 2" AAL if you need more lift out back. I also had new upper ball joints put in that ended up having grease fittings so those can be serviced when needed. Also got aligned with no issues. Mine ended up like this......
  9. May 28, 2009 at 3:55 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Oh c'mon, no response to the response?:confused: From TX tryin to help out a Texan, WTF? :( lol
  10. May 28, 2009 at 4:10 PM
    TheTacoManChach
    Brian
    Fayetteville, TX
    1.5" lift gives me a 3" lift? confused?
  11. May 28, 2009 at 4:31 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Me too now...huh? I got 1.5 out back with the 1.5 AAL. Up front the 5100s were set on the 2.5 setting, I got 2.5 up front. Go 2" AAL with 1" blocks out back to get 3" or buy hi dollar aftermarket leafs. You can use 5100s with ome springs, 882s I think, and set the 5100s on first setting which is .85 to get 3 up front. Many options. I didn't go for 3. What I did was enough for my purposes. If you go 3 you are reaching point where you will need UCAs for proper ball joint action if you intend on beating the trails up very much.
  12. May 28, 2009 at 4:49 PM
    TheTacoManChach
    Brian
    Fayetteville, TX
    ok its 6 45 central lets revise this question...
    1 1/2" rear AAL with rear TSB springs
    Front Adj. Bilstein Shocks
    Front Top plate space 1/4"
    OR
    BEST SELLER! 3" Lift With front coils & rear options
    Price per Unit (Each): $299.99
    ----OME3-05-AL----
    Included in kit:
    FRONT: (2) OME 884 standard/light load front lift coil springs
    Optional med and heavy coils can be selected but require OME N140S shocks sold seperately
    Also includes ToyTec Top plate spacers for a full 3" front lift & (6) top plate studs.
    REAR: (2) 2" lift ToyTec Add-a-leafs by Alcan spring (a long add-a-leaf for the best ride), w/OEM style anti-friction Pads, & new leaf spring center pins.
    Installation instructions.
    Now... Whats the difference? and...
    Which do you guys think is better...
    they cost the same... so ima get one of them... which one...
    also is the package you can buy as one able to be installed with TSB?
  13. May 28, 2009 at 5:03 PM
    jrobson
    jrobson Well-Known Member
    Mobile, Alabama
    09 DC 4x4
    Ultimate lift kit, LR UCA's, Bi-xenon 8000K headlights, Xenon 8000K foglites, (4) KC slimlites on N-Fab light bar, Extang trifecta toneau cover
    Go with Toytec. I got their Ultimate lift kit which comes with everything from shims to diff drop down kit. Ask them to swap out the rear AAL with the TSB AAL. They will do this at no extra charge. Trust me, you will not be disappointed with the ride or even the customer service. I will definately use them again.
  14. May 28, 2009 at 5:13 PM
    TheTacoManChach
    Brian
    Fayetteville, TX
    the ultimate lift kit is a bit pricey...
    i was looking at something between those to options
    they are both just under 300
  15. May 28, 2009 at 8:07 PM
    TheTacoManChach
    Brian
    Fayetteville, TX
    so no help huh...
  16. May 28, 2009 at 8:19 PM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    I say either choice is good, it depends on how high you wanna go. 1st option good for 2.5. option 2 will get you in the 3 range but again, you will be pushin on where you might wanna consider UCAs that have ball joints with more range of motion than stock for movement & alignment reasons.
    Where is chris4x4?? Can someone please summon the expert to get this cleared up? lol
  17. May 29, 2009 at 3:31 PM
    TheTacoManChach
    Brian
    Fayetteville, TX
    bumo paging chris paging chris...
  18. May 29, 2009 at 4:32 PM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    Either get spacers or 5100s upfront with your budget and then for the rear, do the TSB + AAL. Thats exactly what I have and it sets perfect! :D
  19. May 29, 2009 at 4:49 PM
    jrobson
    Mobile, Alabama
    09 DC 4x4
    Then just start saving your money. I can tell you one thing, you get what you pay for.
  20. May 29, 2009 at 8:42 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    On Monday I'll be ordering the billys from DSM, the toytec tsb aal, 3 degree shims, and longer ubolts. i've done my research on this site and on toyotanation and most seem to think that this is a good setup. i'm getting the shims on the recommendation of the local shop that has done a taco leveling kit and a long uptravel kit on tacomas and they said it would be good.
