TSB documents?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by double09, Mar 14, 2012.
  1. Mar 14, 2012 at 1:26 PM
    double09
    double09 [OP] Member
    Jacksonville IL
    2009 Double Cab LB TRD Package
    Side windows tinted, 8 in windshield strip, remote start, head lights
    Where can i find the actual TSB forms on the internet? i want to print one out to take to the dealership. Yea I'm a noob and this forum has helped me alot. Thanks
  2. Mar 14, 2012 at 3:05 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    just print the pdf's from here...easy stuff
  3. Mar 14, 2012 at 6:20 PM
    lj973gm
    lj973gm Sold it, dont miss it yet.
    Ohio
    06 DCSB 4wd
    Stickies at the top of this 2nd gen forum. Read all them and then proceed to posting it will clear up alot of questions and typical mods that pop up.
    You also need to be specific since there is a number of TSBs
    Two recalls that are current as well, accell pedal and reflash and just this week the clock spring in the steering wheel.
    This forum has a ton of knowledge and you will likely get your answer by searching not being a dick it is just faster if you search. These 2nd gens have been around for 7 years now and most everything has been done to them of fixed.
  4. Mar 18, 2012 at 12:25 PM
    double09
    Jacksonville IL
    Ya I seen the codes I was looking for the actual paper that the dealership would get but I got it figured. It's just a lot of information thrown at you at once I've spent hours on here researching. Thanks
