TSB Done for harsh ride but...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by michaelmad21, Jul 21, 2010.
  1. Jul 21, 2010 at 6:15 PM
    michaelmad21
    michaelmad21 [OP] Well-Known Member
    Michael
    El Paso, Tx
    Hey guys well I just got my Tacoma back from the service department. the tsb was done and got my new leafs springs. As I left I notice my alignment was off big time!!! This was at 5:30 and they closed at 6:00. If I'm not mistaking should of that been done as well. I don't wana go tomorrow and look like a fool so anyone who has gotten this done my questiion is should the alignment have been done as well???:confused:
  2. Jul 21, 2010 at 6:17 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 4Runner TRDOR Prem. MGM
    I didnt get an alignment with mine. might want to make sure they put everything back together correctly in the front. I know they replace all 4 shocks when they do this TSB, well they did on my truck anyway.
  3. Jul 21, 2010 at 6:28 PM
    westport toyota
    westport toyota Active Member
    mine was off , steering wheel off center but wasnt pulling. Took quite a bit of talking to get them to get them to do it later on after i drove it for a while like that. He claimed my warrenty could be void because of lift; being kinda a dick , then he said- ill do it this time. Drives:) so perfect now.. After that I went and got tons of lumber, It did scawt down but not too much, then I was bumed for a second thinking she will not return to her perky stance, but happy to report she sprung back . thanks TOYOTA
  4. Jul 21, 2010 at 6:34 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The TSB states that an alignment should be done and the work is reimbursed by Toyota. It does not state that an alignment is not needed if the shocks aren't changed.
    In my mind if the rear is lifted due to a new leaf assembly the front geometry will be affected as well.
  5. Jul 21, 2010 at 7:48 PM
    GT150
    GT150 Well-Known Member
    Blairsville Ga
    2010 Prerunner V-6
    My springs were replaced and my front end was re-alinged................without replacing any shocks
  6. Jul 21, 2010 at 8:08 PM
    SOSHeloPilot
    SOSHeloPilot Well-Known Member
    U.S.A.
    2016 SR5, AC/LB, 4x2, V6, Auto, w/Tow, SiriusXM, Stock
    UnderCover SE, Bed Mat, Tint, Weather Techs & DashGoPro
    They only replaced the rear springs on mine and did the alignment.
  7. Jul 21, 2010 at 8:40 PM
    michaelmad21
    Michael
    El Paso, Tx
    well what the heck I'm just gonna to go and what ever happends happends
  8. Jul 21, 2010 at 8:58 PM
    Coloradomx24
    Coloradomx24 Well-Known Member
    Colorado
    2015 Dbl Cab L/B Sport
    They did an allignment on mine with the TSB
  9. Jul 21, 2010 at 9:00 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    X2
  10. Jul 21, 2010 at 9:09 PM
    Devildoc
    Devildoc Well-Known Member
    Lincoln, California
    Speedway Blue off road
    Running board, K&N air filter, Nitto Terra Grapplers G2 on ProComp 7089(285/70/17), 3" front lift and 1.5" AAl rear, all with bilstein 5100's with Eibach spring, 1/2 spacer in driver side and 1/4 spacer on the passenger, Wicked Flow exhaust, Debadge, satoshi raptor grille (HomerTaco)
    Print the TSB and show them, I just got mine done and it reads that it needs to be align regardless of what model you have. It does not matter if they only replace your leaf springs, still needs to be re-align. Make sure to ask for a copy of the alignment sheet, to make sure they do it. x2 on checking your vehicle because it should not be off the much if they only replace your leaf springs.
  11. Jul 21, 2010 at 9:13 PM
    solus
    solus HOME!!!
    Mark
    Bremerton, WA
    RR 4wd SR5
    they usually include new front and rear shocks...especially if you not a trd therefore it would need to be aligned
  12. Jul 21, 2010 at 9:14 PM
    michaelmad21
    Michael
    El Paso, Tx
    I notice on the alignment sheet it on goes up 265/70/17's I'm running 285/70/17's you think mybe thats why I didin't get mine done???
  13. Jul 21, 2010 at 9:21 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Your alignment wasn't off when you brought it in was it? Take it back. Make them fix it.
