TSB for 2010
Discussion in '2nd Gen. Tacomas (2005-2015)' started by heffer, Aug 23, 2009.
  1. Aug 23, 2009 at 1:41 PM
    heffer
    heffer [OP] Well-Known Member
    Jeff
    Los Angeles
    '15 Magnetic Grey 4X4 TRD Off Road
    Icon Extended Travel, SPC control Arms, OME Dakars, B110's
    hey guys, i just picked up a 2010 yesterday, and i was wondering if any of you might happen to know if toyota fixed this for this year? thanks
  2. Aug 23, 2009 at 1:43 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Fixed what, exactly?
  3. Aug 23, 2009 at 1:44 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Yea, there is a good number of TSB's... Though if I were to venture a guess, I presume you mean the 3pack vs 4pack of leafs. Easiest way to look is look under the truck's rear, if there's 3 leafs, or 4...
  4. Aug 23, 2009 at 2:36 PM
    JKD
    JKD Well-Known Member
    They could also use thicker leaves, or ones with different spring rates. They probably didn't, but they *could*.
  5. Aug 23, 2009 at 11:52 PM
    heffer
    Jeff
    Los Angeles
    ok, i just checked my truck today, and there is only 3 leaf springs.
    do you think i would be able to get the service done? thanks
  6. Aug 24, 2009 at 12:00 AM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    I didnt even know the '10s were out yet.
  7. Aug 24, 2009 at 12:03 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    The last year updated to the TSB was '08. The '09 guys are still having problems getting it done, but some have had some luck. You can view, download all the TSB's using the following link:
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/7107-tsb-list-2005-2008-toyota-tacoma.html
    What seems to work the best thus far is try to get a decent load (say about 800lbs) and show up to your dealer, request a ride with the manager and/or tech to confirm the harsh ride. They may work with you, may not. If they don't, call Toyota corporate and start a claim. That way, even if its' denied... when/if Toyota accepts the '10 for the TSB and you're out of the warranty period they may still do your truck as it was a documented issue within the period.
    Best of luck...
  8. Aug 24, 2009 at 6:31 AM
    Veccster
    Veccster bass turds
    Eric
    Pittsburgh - The City of Champions
    2020 Pro
    I'd be interested to have you check the part numbers on those springs. We could compare them to the part numbers for the previous years to see if you have the same problem.
    Part numbers are on a sticker on the top of the springs. It's not hard to see.
    Do you have a yellow sticker in the drivers side door jam?
  9. Aug 24, 2009 at 6:37 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    2017 Tacoma 6MT TRD Pro
    Falken Wildpeak MT 285's
    :worthless:
    ....lets see some pics of this 2010!!
  10. Aug 24, 2009 at 6:40 AM
    nad
    nad mmmm tacos!
    Jordan
    Canada
    2014 Sierra All Terrain
    I would say get a custom spring shop to fabricate you some springs and put them on, it wont be that much money for me it was 400 canadian, should be a lot less in the states,
  11. Aug 24, 2009 at 6:47 AM
    GeoTaco
    GeoTaco the town is back that way
    Freeda Feltcher
    Denverish
    '21 Army Green TRD OR DCSB
    Car seats
    would it be easier to get the TSB with or without the sticker? does it even matter?
  12. Aug 24, 2009 at 3:35 PM
    JKD
    Are you already carrying loads heavy enough to bottom out the rear suspension?
  13. Aug 24, 2009 at 3:37 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Doesn't really matter...Your truck is an 09 and not directly covered by the TSB...Take it to a dealership and see what they have to say tho...
  14. Sep 16, 2009 at 1:29 PM
    tyboxr
    tyboxr Member
    2010 Sport, V6, 6sp, Mag Gry
    So all this talk about the rear springs has made me paranoid about the springs on my 2010 DC Sport. I have three leaves with the lowest being about twice as thick as the upper two. I also have the sticker on the door but it states that the modifications have changed the capacity from "0" to "0"? So I am guessing that the thickened third leaf was the fix? Or was it always that way? Any TSB survivors out there?
  15. Sep 16, 2009 at 1:38 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Doubt they "fixed" the springs. That overload leaf has been like that. Check the part numbers against the TSB and then talk to the dealership about it...
  16. Sep 16, 2009 at 1:58 PM
    tyboxr
    tyboxr Member
    previous current
    48210-04550 48210-04570 Spring Assembly Rear , RH Leaf Spring 1
    48220-04190 48220-04210 Spring Assembly Rear, LH Leaf Spring
    are these the correct parts numbers in question?
  17. Sep 16, 2009 at 6:01 PM
    Edrin55
    Edrin55 Well-Known Member
    Ron
    Chula Vista, CA (Eastlake)
    2010 Magnetic Gray TRD Sport Access Cab
    Avid Off Road Light Bar Line-X'd, Black Sand Pearl Hood Scoope, Truck Covers USA metal roll up bed cover, Thule Custom lockable light bar, TRD Sport Exhaust, Line-X'd TRD skid plate, Slee Off Road Sliders, Upgraded 3.5" Rearview Mirror/Monitor, Anytime Foglight Mod. (TY Jeff), Smoked Foglights, SilverStar Headlight & Foglight Bulbs, Tinted windows all around, Vent visors, Bed mat with security mod, Wet Okoles front & back, Race/Sport Pedals, Tailgate Clamps, PopNLcok 5300 Tailgate Lock, All weather mats, Helo 17x8 Hubcentric Rims & BFG All Terrain 265/70/17, Blisteins 5100's all around with mini leaf add to the rears, AFE Pro Dry drop in filter, Go Rhino Hitch Step, TRD License Plate Frames and Tire Valve Covers. GrillCraft MX Mesh upper and lower grills with "old school TOYOTA" FJ emblem, Cobra CB Radio, Firestick CB Antenna with custom mount.
    Just wanted to bump this thread.... So do the 2010's have rear leaf spring issues?
  18. Sep 16, 2009 at 6:19 PM
    stanford86
    stanford86 Member
    SoCal
    PreRunner SR5 2009
    I bought an O9 prerunner v6 in august, manufactured in July of 08 at nummi, less than two weeks later I call Toyota corporate and complain of a "harsh ride" - that the truck had "bottoming out" issues. All my part numbers matched the TSB. I never mentioned Tacomaworld, I don't think toyota's a fan of the site. Service Mgr questioned me minamally on the phone- mostly pressing that the resolve would give me a "firmer ride" that would be more truck-like, he said. "That's what I bought". The springs and shocks, front and back, were on and ready for the desert by labor day. There is a ride difference and I can understand how some p-, some owners might find the adjustment disparaging to the tuckus, but the invoice said $1338 and I said thanks. Tacomaworld made it possible.
    for 2010, look at the tsb part #'s and friggin, do it. I'm totally confident that if I ever have to move an elephant my truck can handle it.
  19. Sep 16, 2009 at 6:51 PM
    TacoTurd
    TacoTurd Defying Alliances since 2007
    Central Texas
    07 PreRunner TRD Sport
    TRD Exhaust, TRD CAI, Bull Bar, PIAA lights, Passport, Bed Mat, UWS Toolbox, Hood Struts, Rear TSB, TRD/Okole Seat Covers, Hellwig Rear Sway Bar, Burned Carpet, Nasty Dent in Roof
    Only to the extent the rest of the 05+ do. They didn't change anything.
  20. Sep 16, 2009 at 7:28 PM
    paintpimp
    paintpimp Well-Known Member
    Loveland CO
    2016 Tacoma Dbl Cab Long Bed TRD Off Road
    ARB front bumper with 10,000 lb winch ARB rear bumper RSI bed rack 2.5 adjustable lift TRD rims Leather seats
    Been out for a month or so
