TSB for Clutch pedal Squeak/Creak 2005-14
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rambone71, Sep 24, 2014.
  1. Sep 24, 2014 at 7:39 AM
    Rambone71
    Rambone71 [OP] Well-Known Member
    TJ
    North east
    2014 tacoma off road
    FYI - here is a new TSB for a complaint, Clutch pedal Squeak/Creak they just revised it on Sept 10th 2014... added model years 2012-14 and also updated to included 2007-2012 the old TSB was TC004-06
    Norton and scottalot like this.
  2. Oct 22, 2014 at 10:03 AM
    mailman2000
    mailman2000 Member
    central ny
    2013 tacoma off road
    I just had my clutch pedal and master cylinder replaced, old clutch pedal started squeeking but it had no play in it and was really tight. I could slam those gears like a race car, it was awesome. now new setup is soft and spongy, I am waiting for clutch to return to shift, I cannot hit those gears like I used to. Toyota said old style setup was no good this is a good fix, but I miss my heavy duty like pedal with my 6 speed manual
  3. Oct 22, 2014 at 10:15 AM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    I assume TSB repairs are done under warranty for free.It is interesting they included 2007 to 09.
  4. Oct 22, 2014 at 10:24 AM
    Timberland Taco
    Timberland Taco Well-Known Member
    Berlin, NJ
    2013 V6 6-speed 4x4
    Bilstein 5100's set at .85, OME 885x coils w/ 1/2" top plate spacers, Total Chaos UCA's, Wheelers 1.5" HD 3 leaf progressive AAL w/ factory overload leaf, DT Pipe Bomb Ypipe, Vibrant resonator, Magnaflow pro series catback system, URD Short Throw Shift Kit, Debadged, BHLM, BTLM, 6000K BiXenon Headlights & Fogs.
    I also did notice that the pedal is softer now, but not any less strong. Im still chirpin 33"s grabbin 2nd when im in that kinda mood :cool: Kinda just gotta do the stomp and lift hard like its a fuggin chevelle lol
  5. Oct 31, 2014 at 6:50 AM
    PburghTaco32
    PburghTaco32 Well-Known Member
    Brennan
    Pittsburgh
    13 Sport
    Weathertech Liners, Ultragauge, Pop n' Lock PL5300
    Well, add another TSB that I'm going to take to the dealer.
  6. Oct 31, 2014 at 6:55 AM
    sr5vic
    sr5vic Buy & Hodl
    British Columbia
    '13 Access Cab SR5 4x4
    295/70/17 Geolander G003 M/T's, 17" Work S1HC's, 1" Bora Wheel Spacers, King 2.5 EXT Coilovers, King 2.5 Tundra Rears, Total Chaos UCA's, Total Chaos LCA's, BruteForce Fab Rear Bumper w/ Tire Carrier, OME Dakar CS047R Leaf Springs w/ D29XL AAL, 'OCTACO' Custom SS Brake Lines, Extended R.Diff Breather, RDI Aluminum Skid Plates, BAJADESIGNS Squadron Sport LED Yellow Fog Lights, BAJADESIGNS Squadron Sport LED Clear Front Spot Lights & Rear Work Lights TRD PRO Grill, TRD PRO Headlights, US Offroad Winch Mount, SmittyBilt X2O 10k Winch, RotoPax 2Gal. Fuel & Water Canisters , VIAIR Constant Duty OBA System, Custom Bussmann RTMR Panel, Total Chaos Bed Stiffeners, StopTech Slotted Rotors, TRD Brake Pads, Off-Grid Engineering Dual Battery System w/ Blue Sea 7622 ML-ACR 500 Relay, Dometic CFX40 w/ slide
    I hope they issued this for the Canadian market as well. Mines passing me off and the side to side play is getting worse.
  7. Oct 31, 2014 at 7:35 AM
    robotninjasrule
    robotninjasrule Well-Known Member
    peter
    edmonton alberta
    2013 trd sport
    I had mine done under warranty last year. It was way worse in the winter. 6 months of the year in Alberta lol
  8. Nov 1, 2014 at 11:13 AM
    DolphinJohn
    DolphinJohn Well-Known Member
    Nature Coast, FL
    '13 Access Cab 4x4 SR5
    Hmmm… I just found out about this. My pedal doesn't squeak and there's no play in it. Should I just leave it alone? It works fine as is.
  9. Jan 28, 2015 at 6:12 AM
    rcsb jon
    rcsb jon Well-Known Member
    Pittsburgh
    '17 Ridgeline RTL-T | AWD | White | Ebony
    -WeatherTech liners
  10. Jan 29, 2015 at 6:24 PM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    Went to dealer today. They instantly ordered the parts per the TSB. Will call to schedule appt. when parts are in.
  11. Jan 29, 2015 at 7:07 PM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    Honestly, if you give the white plastic bit that is behind the clutch (in front of with regards to the front of the truck) a twist or partial rotation, your creak may dissappear. Try it, solved mine.
    Jacked Burton likes this.
  12. Jan 29, 2015 at 7:09 PM
    jackwithcorona
    Eastern Mass
    13 DCSB SR5 4x4
    I'll grab photos or a video tomorrow if you need it. I can't remember which of the dozens of threads covering this topic contained that little morsel. Been 4 months of cold winter and the creak is gone.
  13. Jan 30, 2015 at 4:54 AM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    I've been doing that trick, multiple times a day, everyday since Sept... It's a god damn joke.
    The problem is, for me at least. My truck sits in a cool garage when it's hot out. Then it's in a warm garage when it's cold out. The clutch master cylinder casing is made of plastic... it doesn't like those thermal changes when I go in and out of the garage.
    The last few days it will do it on every up and down of the pedal's stoke... its loud as hell. People can hear it over the bluetooth
  14. Jan 30, 2015 at 5:10 AM
    LUSETACO
    LUSETACO Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    This. Solved my problem years and years ago and hasn't been an issue since.
  15. Jan 30, 2015 at 5:42 AM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    Doesn't do it for me
  16. Jan 30, 2015 at 5:57 AM
    Timberland Taco
    Berlin, NJ
    2013 V6 6-speed 4x4
    yea that fix only works on certain trucks for whatever reason. my 2010 it worked and i never touched it again, my 2013 it would last anywhere from 10 mins to half a day. I got the tsb in september and ive had not a squeak since :thumbsup:
  17. Jan 30, 2015 at 6:08 AM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    :pray: I'm hoping it does the trick as well as they adjust the CMC rod properly.
  18. Feb 6, 2015 at 1:29 PM
    Pastadog
    Pastadog Well-Known Member
    Ronnie
    North Hollywood, CA
    05 SWRC Prerunner
    Touchscreen with hands free blue tooth, charcoal filter removed and resignator delete
    Stupid question, I know, but does this apply to my 05 with only 67k miles with no warranty?
  19. Feb 7, 2015 at 1:23 PM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    Read the link above, 05 is covered I think
  20. Feb 9, 2015 at 10:40 AM
    rcsb jon
    Pittsburgh
    -WeatherTech liners
    Had the tsb done this morning... They changed the cmc to a proper metal cased unit. The original was a plastic one. Only less than 10 mi on it... I'll report back as more wear and tear on it happens
