TSB for pinging 4.0
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sammy4x4Taco, Jun 18, 2022.
  1. Jun 18, 2022 at 6:45 AM
    Sammy4x4Taco
    Sammy4x4Taco [OP] Well-Known Member
    Sam
    Silver 2014 Tacoma Limited Double Cab Long Bed
    Stock
    Anyone have the TSB number for the pinging 4.0? My truck is cackling at low rpm. Not sure the plugs were ever replaced and at 120k I'll try that first. Going to have my buddy's Toyota service writer son see if he can do the TSB still.
    anything else I should be looking at to get her running better?
  2. Jun 18, 2022 at 9:43 AM
    esotaco
    esotaco Well-Known Member
    Ed
    Fairfax, VA
    '13 Silver 4.0L AT SR5 4X4
    T-SB-0044-14 (July 2014).
    I had the same problem with my '13 4.0L. TSB took care of it.
    TnShooter likes this.
  3. Jun 18, 2022 at 4:27 PM
    Sammy4x4Taco
    Sam
    Stock
    Thanks! That's good to hear. I'll see if I can have it done.
  4. Jun 18, 2022 at 9:28 PM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Interesting.
    Both of mine ping under load at low RPM. Both have around 120k on them. Plugs have been replaced (several times).
    Running premium makes it not do it at all.
  5. Jun 19, 2022 at 9:54 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    Have y’all tried a PEA type fuel system cleaner. Although I have a 15 and use 87 top tier fuel there’s no ping under light loads. Fuel system cleaner every 5K.
  6. Jun 21, 2022 at 5:38 PM
    Sammy4x4Taco
    Sam
    Stock
    Is this a change in engine timing or trans mapping?
  7. Jun 21, 2022 at 5:42 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    That TSB is engine tuning. It should help.
    That stated, a bit of ping/knock is to be expected (and is OK) with the way the adaptive timing on these trucks works, get the TSB done but dont expect it to get rid of it completely.
  8. Jun 21, 2022 at 5:44 PM
    captaintofuburger
    captaintofuburger Well-Known Member
    2011 Base 4wd 4banger
    I would wager its backing off on spark/timing. Under hot conditions to cause a ping it's detonating pre-mature. I don't see how the trans would come into play. Out of morbid curiosity I wonder if slightly over gapping the plugs would yield the same result, I'm not advising that by any means though.
  9. Jun 21, 2022 at 6:55 PM
    Tarheel22
    Tarheel22 Well-Known Member
    Raleigh, NC
    2012 Silver TRD Sport 4X4 DCLB
    none yet
    I had the TSB done on my 12' and it helped but on hot days it still pings on hot days. Mostly when accelerating in 1st gear. Like others said, premium gas makes it go away. I may start using premium in the hot summer months
  10. Jun 21, 2022 at 7:05 PM
    captaintofuburger
    Anyone here have bin dumps of the pre and post TSB files? I can't personally do it myself, but know where to go and how easy enough just to tweak it a bit. More or less just make a tune file aimed at the parameters that were changed for the TSB. Well it's just ecufiles.com or use someone on mhh. I haven't tried to dump a tacoma ecu but i feel a cheap $25 MPPS cable would work for the dumps and flash.
  11. Jun 21, 2022 at 7:10 PM
    captaintofuburger
    Err... I do actually have all the files somewhere. I keep accidentally downloading repacked dumps of my own code. I know I have a mess load of Toyota calibration files somewhere, that was back when I was on tundraworld and wrote a keygen for some version of techstream I've long forgot.
  12. Jul 17, 2022 at 8:01 AM
    Sammy4x4Taco
    Sam
    Stock
    I got it done and it runs pretty good. I can feel how it cleaned up off-idle acceleration. Not bad. Still a slight ping under certain conditions but I'd say an improvement for sure. They
    somehow wiped my thumb drive that I had in the USB port with music on it.
