TSB for T/O Bearing Issue:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roxspin72, Oct 27, 2009.
  1. Oct 27, 2009 at 5:02 PM
    roxspin72
    roxspin72 [OP] Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Attention all, there is a current TSB for the 2nd Gen 6spd Trans T/O bearing issue. My Tech admitted it to me today during casual conversation. He would not give the #, being his boss was right there next to us. However, I'm sure that someone on this site has the ability to acquire this vital piece of information.:D
    Here is what my Invoice states:
    CUSTOMER STATES HEARING NOISES IN TRANSMISSION WHEN CLUTCH IS RELEASED... ADVISE
    FOUND SPLINE FOR OUTPUT SHAFT HAS WEAR MARKS
    REPLACED TRANSMISSION...
    One thing I must point out is that they replaced the bearing once for me earlier this year. When I dropped it off to my tech, he automatically informed me I would be getting a new trans. This was without the inspection. So apparently this repair has had prior aproval to replace trans. He said im like the 5th customer he knows of so far.
    Ok enough rambling, point is it's out there. I cant find the TSB # on my invoice, not sure if it would be or not.
    Will post more info when or if I get some.
  2. Oct 27, 2009 at 5:44 PM
    IndigoTaco
    IndigoTaco Well-Known Member
    07 Access Cab Sport 4x4
    Interesting. What type of noises were coming out of the trans?
  3. Oct 27, 2009 at 5:48 PM
    roxspin72
    NC
    Oh Yeah!!!
    I was complaining of the chirping noise the Bearing was making. Don't think that was in the trans, but that's how my tech wrote it up. Second line is what needs to be found upon inspection for trans to be replaced.
  4. Oct 27, 2009 at 5:52 PM
    Terrier
    Terrier Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
  5. Oct 27, 2009 at 7:10 PM
    Toph
    Toph Addicted to V8s
    Interesting...I had a new TOB installed a little over a month ago...and low and behold the squeak is coming back.
    So new transmission...right on. Not a moment too soon either...got 57k on the odometer.
  6. Oct 27, 2009 at 7:13 PM
    roxspin72
    NC
    Oh Yeah!!!
    Ok I'm trying to figure this out as I type...
    FP Number (Part #)???
    33030-35A22 Transmission Unit
    Is this the same Trans in the current 2005-2010?
    Another ? is, I had previously installed the URD short shifter. I cant feel any difference, but would this have been removed?:confused:
    I was looking at the install PDF, and wondering if they kept the spacer for the trans. Should be some major side effects if not, right???
  7. Oct 27, 2009 at 7:23 PM
    df4iguy
    df4iguy Well-Known Member
    Dan
    Chicago
    I would remove it for sure. they can deny a claim for anything that could potentially damage that section of the vehicle in question.
  8. Oct 27, 2009 at 7:28 PM
    roxspin72
    NC
    Oh Yeah!!!
    Huh, :confused:
    I already have the new trans installed. Just asking if the mech would have removed anything from my shifter assembly in order to swap the trans...
  9. Oct 27, 2009 at 7:33 PM
    usnatclee
    usnatclee Well-Known Member
    Clark
    Corpus Christi, TX
    13 corvette 12 Camaro 13 And Wrangler
    (SOLD)4 Bilstein 5100's, OME885s, 2" Toytec AAL rear, 3" total lift, 285/70/R17 BFG MTX on stock rims, AIRAID cold air intake w/ secondary filter removed, CB radio w/ firestik shorty antenna, custom bumper and sliders from those guys rod and customs, URD stage 3 competition clutch, Tom Woods one piece double cardan drive shaft, and URD short throw shifter.
    subscribed! I have the same problem with my trans. bad thing is I am not under warranty anymore :(
  10. Oct 27, 2009 at 8:57 PM
    df4iguy
    Dan
    Chicago
    I though you were asking if you should remove it before you went in to the dealer
  11. Oct 28, 2009 at 3:50 PM
    roxspin72
    NC
    Oh Yeah!!!
    No prob. Yeah I'm gunna rip out my center console just to check if my spacer is still in or not. Other than that getting a new trans is awsome:D
  12. Nov 8, 2009 at 12:54 AM
    tonkatoy
    tonkatoy Well-Known Member
    Billy
    Phoenix, AZ
    08 White TRD Sport Acc 4x4 6 spd
    Any more news on this issue? I've got the squeaky bearing too... I bought this truck for Toyota dependability. Its been anything but. Lets keep on this issue. I'll be bringing my truck in this week for the second time around for the squeaky bearing. I'll let everyone else know what happens.
  13. Nov 8, 2009 at 3:01 PM
    tonkatoy
    Billy
    Phoenix, AZ
    bump this one to the top! There has to be more people out there with the same issue.
  14. Nov 8, 2009 at 4:34 PM
    roxspin72
    NC
    Oh Yeah!!!
    I recommend you insist they explain to you why is it that some dealerships are automatically replacing the Trans for this issue. Good part is you already have leverage due to the fact that you had the T/O bearing replaced once. That was my same situation, second time in and new trans:D
    There must be a TSB, it's just not readily available to public. So for now it's case by case and dealership specific.
    Good luck...
  15. Nov 8, 2009 at 4:38 PM
    dbbd1
    dbbd1 Well-Known Member
    Good info to know, anyone with the TSB number yet?
  16. Nov 9, 2009 at 9:27 PM
    Oppie1
    Oppie1 Member
    I looked through AllDatapro and can't find any TSB for the infamous chrip, which I am also experiencing with 80k.
  17. Nov 12, 2009 at 12:47 PM
    mak90
    mak90 Well-Known Member
    Central Coast, Ca.
    06 Tacoma 4x4 TRD Off Road 6 spd
    TRD Exhaust, TSB springs,Weathertech mats,Bed mat, Wet Okole seat covers, TRD Pro Suspension
    Also having this problem om my 06 with 30k. Anyone have the TSB number?
  18. Nov 12, 2009 at 1:06 PM
    JayAre
    JayAre Well-Known Member
    OR
    13 TRD Sport DCLB
    I had the squeaky t/o bearing issue. They replaced it under the certified used warranty about a month ago. I bought the truck a few months ago, they probably sold it to me with the problem I just hear it then. They replaced the bearing same day and gave me a rental. I asked the tech to check the pilot shaft for wear, and he said it was fine...only time will tell if the squeak will come back, but from what I hear about the problem, it probably will. 2005, 35k miles. According to the invoice, it was a $350 job.
  19. Nov 15, 2009 at 5:35 PM
    TACOMAJESSE
    TACOMAJESSE Well-Known Member
    GA
    05 4X4 tacoma 33's
    TRD short shift,exhaust intake,33" michelins, Urd y pipe Urd supercharge(no longer on)
    Getting my new transmission and T/O bearing done tomorrow at the local Toyota dealer,:D yeah!!! No more chirping can't wait, its embarrising
  20. Nov 15, 2009 at 6:11 PM
    Terrier
    Idaho
    Anyone, can you be a little more descriptive of the chirping sound your Tacoma is making? For example, is it high pitched?
