TSB for T/O Bearing Issue:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roxspin72, Oct 27, 2009.
  1. Nov 15, 2009 at 7:25 PM
    Oppie1
    Oppie1 Member
    Were you able to get this covered, or are you paying out of pocket? Yes, it is quite embarrassing. I hold the clutch in whenever I go by neighbors or co-workers. Sighh....
  2. Nov 15, 2009 at 7:38 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    subscribed since i have the 6 speed. :popcorn:
  3. Nov 15, 2009 at 7:57 PM
    TACOMAJESSE
    TACOMAJESSE Well-Known Member
    GA
    05 4X4 tacoma 33's
    TRD short shift,exhaust intake,33" michelins, Urd y pipe Urd supercharge(no longer on)
    its covered under my 5/60k. I have 58,975miles, pretty damn close to being out of pocket. Well first off, i work in the parts dept, so getting things done is kinda easy, with legit claims. The sound is almost like a squeeky belt that goes away when you push in the clutch. The problem is in the T/O bearing and shaft that it rides on. The shaft is aluminum, and the bearing is steel, if you pop off the inspection cover (located on the drives side of the trans under the truck) with the truck running you'll see the bearing actually wobbling on the shaft (not normal), the real way to fix it is to get a new bell housing, but most dealer wind up throwing in a trans b.c its cheaper in labor.
  4. Nov 15, 2009 at 8:00 PM
    TACOMAJESSE
    GA
    05 4X4 tacoma 33's
    first time complaint, your most likely gonna get just a T/o bearing (thats what happened to me about 15k miles ago), Now the noise is back. So we inspected the shaft while the truck was running as i said above and the service manager approved a trans replacement.
  5. Nov 15, 2009 at 8:01 PM
    TACOMAJESSE
    GA
    05 4X4 tacoma 33's
    Being an employee of Toyota, NO TSB AS OF YET, Sry guys. But if one does appear, ill post up all the info
  6. Nov 15, 2009 at 8:14 PM
    Taccat
    Taccat 2009 Base
    Caribbean
    2009 Base
    Does this problem include 5 spd?
  7. Nov 15, 2009 at 8:41 PM
    Outlaw
    Outlaw Well-Known Member
    Iowa City, Iowa
    2006 GX470
    Water Pump, Timing Belt, Sparkplugs, Plastidip Grill emblem
    Subscribed...please keep us informed.
  8. Nov 15, 2009 at 8:51 PM
    Terrier
    Terrier Well-Known Member
    Idaho
    2008 SR5 Access Cab 4x4 2.7
    Thanks for the sound description, TACOMAJESSE.
  9. Nov 16, 2009 at 6:17 AM
    TACOMAJESSE
    GA
    05 4X4 tacoma 33's
    No the 5sp has a different design, ONLY 6SPD's. Thats the best i can do on the noise desription. As i write this im watching my trans come out:p..
  10. Nov 16, 2009 at 5:09 PM
    TACOMAJESSE
    GA
    05 4X4 tacoma 33's
    Well the trans came out today you can deffinatly move the T/O bearing up and down and wiggle it all over the shaft.. (sry it sounds perverted) It didn't get finished today bc we ran into a few rusted out bolts and whatnot, but tomorrow ill let you all know how nice and quiet it is
  11. Nov 18, 2009 at 1:47 PM
    TACOMAJESSE
    GA
    05 4X4 tacoma 33's
    AHHHHHHH So nice and quiet now, shifts smooth, feels like it did back in 05
  12. Dec 4, 2009 at 8:51 PM
    FoxRacR17
    FoxRacR17 Well-Known Member
    Kevin
    SoCal
    09 4x4 SR5 DoubleCab Short Bed
    Fox 2.5 C/O's, Fox 2.0 rear shocks, toytec 1.5" AAL, TC UCA's, blue/white dashboard lights, seatbelt chime removed, Synthetic leather armrests, WO seat covers front and back, Goodyear Wranger Duratrac 285/70/17, KMC XD Addict 17x9 rims
    subbed, hopefully this is true because I have a 09 6spd, havent experienced any chirping *yet* but it is always in the back of my mind when I drive my truck.
  13. Dec 4, 2009 at 9:23 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    for the guy who asked: yes it does affects 5 speed also Proof: just had the problem with mine 2 weeks ago. I made a thread about it in the 4 cyl forum. They replaced the t/o no problem, but I hope it will not be a recurring problem. I asked the guys if my shaft was damaged; no. I also asked if they greased the inner side o f the bearing and they sais they did, with bearing grease. So let's hope it does not come back.
  14. Dec 4, 2009 at 11:20 PM
    Negative1
    Negative1 Well-Known Member
    Thanks for the heads up...
    So all of you who are getting your transmissions replaced...
    Has toyota actually re-designed or remedied this issue.. Or are they just slapping in the same old tranny in there which will lead to same premature failure in due time.:confused:
    My 6spd is perfectly fine BTW, only have 16K on her though.... crossing fingers.
  15. Dec 5, 2009 at 8:31 AM
    #35
    dktaco
    dktaco Yes MAObama is a joke!
    Josh
    So. Cal (D-town aka Downey)
    05' Pre-Runner SR5 6-spd Modded
    5100's set @ 2.5", Wheeler's AAL, Toyota factory trailer hitch w/ a Reese 3.5" drop ball, Gaylord's Tonneau cover, BLHM w/ 35w 6000k HID's, Lumincs yellow fogs, Sylvania 886 bulbs in taillights for reverse lights, Debadged, Dee-Zee nerf bars, Shorty black antenna, 3M rubberized billet grille & surround, Toyo Open Country AT's 31's, K&N intake, 40 series Flowmaster, Redline Racing Synthetic fluid all the way around, Wet Okole set covers, dash mat, Sirius Starmate 5 hardwired, Cobra radar detector hardwired, paint always taken care of the finest products from Autogeek.net and a Porter Cable dual action polisher.
    Subscribed, but does anyone have pics of the throw out bearing and areas of concern so we can check ours? Thanks!
  16. Dec 6, 2009 at 8:58 PM
    #36
    71roadrunner
    71roadrunner Active Member
    Do you know if the new throwout bearing pilot shaft is still made of aluminum ? There have been some indications that a new design was going to include a steel pilot shaft.
  17. Dec 6, 2009 at 9:32 PM
    #37
    tictoc
    tictoc Active Member
    HAWAII
    FABTECH
    fabtech 6 in,33 procomp x terrain/micky thompson 17" beadlocks,steering stabilizer kit,k&n 77 series intake with throttle body spacer,ravin exauhst
    i have been having this problem 4 a long time... is it a recall? or do i just complain to my local dealer?
  18. Dec 8, 2009 at 2:11 PM
    #38
    BSP4x4
    BSP4x4 Guest
    I still see no proof of this tsb: Does anyone have the pdf or has anyone had this done?
  19. Dec 8, 2009 at 2:28 PM
    #39
    TACOMAJESSE
    GA
    05 4X4 tacoma 33's
    To be honest it looks like the same thing, but the part number is different, it has changed somewhere.
  20. Dec 8, 2009 at 2:29 PM
    #40
    TACOMAJESSE
    GA
    05 4X4 tacoma 33's
    NO TSB still, just go and complain and have them inspect it in the air with the inspection cover off... You'll clearly see the t/o bearning wobbling on the shaft
