TSB for T/O Bearing Issue:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roxspin72, Oct 27, 2009.
  1. Dec 8, 2009 at 2:31 PM
    #41
    BSP4x4
    BSP4x4 Guest
    I'm not getting the chirping noises other have mentiioned. My problem is a rattleing noise while coating along in N OR while clutched in, AND while driving over bumps in the road. I thought it was just the hanging flywheel, BUT someone just said it could be the T/O bearing. Does anyone have a picture of what i should be looking for? It would heklp if i knew what i was talking about when going to the dealer...HELP!
  2. Dec 8, 2009 at 2:33 PM
    #42
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I've been having a ridiculous amount of noise coming from the throwout bearing on my 2TR since roughly 7K on the truck. Has anyone else has this issue. I'm not sure if its just a fluke, inherent for this particular trans, or what, but something is definitely not right from what I can tell. The second you let the clutch out in neutral it makes a terrible rattling and chirping noise.
  3. Dec 8, 2009 at 4:49 PM
    #43
    SC4333
    Grant
    FL
    5 speed. That's why I'm kind of dumb found about it. I guess ill let the techs at Toyota check it out and see what they think.
  4. Dec 12, 2009 at 9:50 PM
    #44
    71roadrunner
    71roadrunner Active Member
    The following was just posted on the FJ Cruiser forum:
    Re: Throwout Bearing Chirp / Squeak
    fishinfiend previously said: viewpost_0c4bd588142bc14e60ab38198d662eacf313776f.gif
    So I picked the truck up today from its latest round in the shop. I had a large oil leak from the timing cover where it meets bank 1. They replaced the cover and water pump under warranty. 13 hour job apparently. Glad I didn't have to pay for that.
    The TO bearing chirp came back 4 days after the last fix. So they looked at it again. They said they called Toyota Canada Assistance and Toyota is apparently aware of the problem in Canada. I'm not a mechanical person, so I don't know if I'm explaining this right or not. If I'm not, feel free to correct me. The mechanic I talked to said that there is a large hex nut that holds the tranny and everything together. Apparently it needs to be torqued to 450 ft/lbs. If it's not, there is flex in the tranny and that causes the TO bearing failure and damage to the pilot shaft. Toyota has a kit that they are sending around to the dealers to use during the repairs. Mine will be getting done in January now, as the parts are all on backorder. It will take 3 days, as they are going to be taking pictures and documenting every step of the disassembly and assembly process.
    I don't know if they are telling the truth or not. It sounds like they are trying to figure out what's wrong though and not just saying tough, sorry about that buddy. I just hope they figure it out before my warranty expires in 8000kms.
    I don't know, 450 ft/lbs of torque ? That's a really huge amount of torque to put on anything. That doesn't sound right. Maybe he has the value wrong, but it is interesting to note that maybe some parts are not being tightened properly ?
  5. Dec 13, 2009 at 6:16 AM
    #45
    Mr_Torque
    Mr_Torque Buy the Ticket take the Ride.....
    Perkasie,PA
    '07 Tacoma SR5 4WD V-6 6 Spd
    MBRP Exhaust, 17" FJ Steelies w/Firestone AT's, Truxedo Lopro ,Timbren SES, Pioneer FH-X720BT HU & TS-C720PRS Component Speakers, TRD Quickshifter, Bilstein 6112/5160, Light Racing UCA, and Icon Progressive add a leaf.
    I haven't had a Tacoma or FJ Cruiser driveline apart yet but one large nut torqued to 450 ft/lbs holding everything together doesn't make sense.
    Maybe he misinterpreted or the tech fed him a line. I've found more info about the T/O bearing & pilot shaft problem on the FJ Forums.
  6. Dec 16, 2009 at 8:16 AM
    #46
    ridereno
    ridereno Well-Known Member
    Tom
    Reno, NV
    2017 Tacoma DCLB 4X4 TRD-Off Road
    I notice my truck only chirps when it is not on level ground, with the front up, or even on a bit of a side hill. Anyone else have the same thing, or are you chirping all the time?
  7. Dec 19, 2009 at 11:32 AM
    #47
    ESNTACO
    ESNTACO Active Member
    Will
    Md
    06 6 spd DC TRD O/R
    Locker Mod+Safety Switch, Fog Light Mod, ABS Kill Switch, Debadged, Lockable Bed Compartments, Weather Tech Floor Mats, Marathon Seat Covers (highly recommend), Limo Tint, Biceman 4x4 Light, Map Lights on w/Dome, Running Lights w/ Blinkers, Door Buzzer Mod, Cig Outlet Always Hot, Satoshi Grill, Urd Short Shifter, Diff Breather Soon
    I have an 06 w 35k on it and it just started chirping about 1k ago. i have read like 40 pages on various forums today (we're in the middle of a 24"+ snow storm here in Md, nothing else to do) and it seems like all the fixes are temporary, even a new trans because eventually the pilot will wear out again. Is there an after market steel pilot shaft available or after market bell housing w a steel pilot shaft?
    I bought my 06 certified used in sept. w 30k on it. The problem is that the dealership is two hours from where i live and i refuse to have to take my truck and have parts replaced 5 or 6 times in order to get a new bell housing or trans, especially if the problem will only come back.
    This really pisses me off because i feel like i spent more money for the Toyota name/ reputation for reliability than i would have on a GM/Ford/Chrysler. But i figured it would be money well spent. Then a i get on this forum to investigate the possible origin of a squeak and find all this BS
    Anyhow it just started so i doubt its a big problem...yet. If anyone gets a TSB #, post it!
  8. Dec 19, 2009 at 12:13 PM
    #48
    71roadrunner
    If you got some extra time on your hands, then you can read the 317+ posts in this thread on the FJ Cruiser Forum :
    http://www.fjcruiserforums.com/forums/engine-performance/42991-throwout-bearing-chirp-squeak.html
    The Taco's and FJ's share the same tranny and are having the same problems. What pi$$es me off is that last May I bought a brand new FJ with stick shift. I could have had an auto tranny as a brand new one was sitting next to my stick shift model on the lot. I opted for the stick because I was thinking long term durability. Since I recently retired, I didn't want to be spending 'stupid money' on expensive repairs. Color me dumb I guess !
  9. Dec 19, 2009 at 1:18 PM
    #49
    ESNTACO
    Will
    Md
    06 6 spd DC TRD O/R
    Does anybody know the release bearing Toyota part number?
  10. Dec 19, 2009 at 3:08 PM
    #50
    afireinside
    afireinside Active Member
    Southern Utah
    05 TRD
    K&N CAI, 2" leveling kit, 18" wheels and 285 Nitto Terra Grapplers
    I bought my 2005 6 speed 3 months ago with 65,000 miles. I am having the same chirping problems that everyone on the thread is complaining about. Is there any chance that Toyota will atleast share the cost if the warranty is expired??
  11. Dec 19, 2009 at 3:20 PM
    #51
    71roadrunner
    This should be it:
    31230-60240 bearing,release
  12. Dec 19, 2009 at 7:05 PM
    #52
    ESNTACO
    Will
    Md
    06 6 spd DC TRD O/R
    This should be it:
    Thanks. I know a guy who builds cars for fun. Im gonna see if he can help me replace it.
  13. Dec 19, 2009 at 7:45 PM
    #53
    71roadrunner
    If you tackle this job, there is something you must look at very closely. See the att'd. pics of the TO Bearing and Pilot Shaft it rides on. The pilot shaft is getting buggered up where the TO Bearing rides on it and that is causing the noise. It seems to be because the pilot shaft is made of aluminum. The TO Bearing inner race is of course steel. Not a good combo to have against each other. There are many who consider this setup a crappy design. There are many owners who are getting everything (TO bearing, bellhousing, even the entire tranny) replaced under warranty. It's because the pilot shaft is non-replaceable.
    . [​IMG]
  14. Dec 21, 2009 at 8:35 AM
    #54
    71roadrunner
    Hey guys, even though I own a stick shift FJ, I thought I would keep you all posted on this TO Bearing issue. This post is the latest from the FJ Forum site:
    I had my trans,complete clutch,flywheel replaced under warranty at 15000 mi. and it started squeeking again @ 20000mi. Took it back to the dealer{Northpark in San Antonio} and told them I wanted them to talk to Toyota before throwing more parts at it only to have it do it again. They agreed. Last week they finally called me back{ 1 month later} and told me that Toyota has a redesigned throwout bearing and release fork that will solve the problem for good but to be patient as it won't be available to dealers until FEBRUARY!!!! Was asked to please live with the noise till they call me in Feb. I agreed to wait. I really don't want them wrenching on my FJ any more than required. They also admitted that there are some Tacomas doing the same thing.
  15. Dec 24, 2009 at 2:37 PM
    #55
    Bryan07sport
    Bryan07sport Well-Known Member
    Bryan
    Smyrna, Delaware
    '22 TRD off-road.
    Bilstein 6112/5100. Icon progressive AAL. Overland Torque Tune. Toyota roof rack. Toyota bed extender. Gator trifold tonneau. Bora .75" wheel spacers. 265/75r16 tires.
    well darn. thought i had dodged a bullet because i've been reading all about the t/o bearing issues without any noises from mine at all. but the noises started yesterday and def doing it today (31k miles) ... just got the truck in september and between the clutch pedal squeak and the t/o bearing, this thing sounds like some old rusty pos. as others said here i really thought that the extra money i was putting out for the tacoma would keep me away from problems like this. really frustrating to hear that even the people getting it fixed are having the problem come back... ahh jeez. what to do?
  16. Dec 24, 2009 at 4:12 PM
    #56
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
  17. Dec 24, 2009 at 7:01 PM
    #57
    Oppie1
    Oppie1 Member
    I wrote a letter to Toyota Experience BS to to give them a piece of my mind. My truck is out of warranty and this started happening. They better do something for those of us who are out of warranty.
  18. Jan 11, 2010 at 6:04 PM
    #58
    tonkatoy
    tonkatoy Well-Known Member
    Billy
    Phoenix, AZ
    08 White TRD Sport Acc 4x4 6 spd
    Okay... anything official yet??? Come on toyota, this will come back to haunt you!
  19. Jan 11, 2010 at 6:38 PM
    #59
    TACOMAJESSE
    TACOMAJESSE Well-Known Member
    GA
    05 4X4 tacoma 33's
    TRD short shift,exhaust intake,33" michelins, Urd y pipe Urd supercharge(no longer on)
    nothing yet, they are busy working on the whole gas petal tsb thing..In school they showed how to "cut and reshape" the petal...
  20. Feb 3, 2010 at 9:45 AM
    #60
    ClimberE
    ClimberE New Member
    Eric
    Seattle
    05 4x4 TRD Off-Road
    I just bought a used 2005 6 speed, 4x4 double cab and a week later noticed the squeel of death...
    Checking to see if the powertrain warranty will be honored even though I am not the original owner.
