TSB for T/O Bearing Issue:
Discussion in '2nd Gen. Tacomas (2005-2015)' started by roxspin72, Oct 27, 2009.
  1. Mar 4, 2012 at 12:15 PM
    #161
    Mandy3206
    Mandy3206 Well-Known Member
    San Juan PR
    Sand Pearl Black 06 6spd DC SB TRD OR Moded
    They lubed mine on the 60k warranty check and now 1 yr later the chirp is back, I guess it lasted this long since I haven't been doing water crossings for the last yr, in fact only highway use for the last yr.
    Out of warranty, same problem back, Toyota really fucked this one, I guess that my only option would be to do it myself with the PDM kit, maybe while at it I'll throw in a new and improved clutch kit, need to do my research on the clutch kit.
  2. Mar 4, 2012 at 5:31 PM
    #162
    Superwhitetaco10
    Superwhitetaco10 Member
    Georgetown, MA
    TRD DCSB
    285/70/17 Duratracs, Camburg Ball joint UCA's, Moog ball joints, Icon ext coilovers, Alcan triple AAL, Grillcraft, Tint, K&N filter
    Does anyone know if they updated anything in the 6 speed transmission for 2012?
    I just purchased a 2012 Sport DC , SB with 6 speed and was wondering if i might encounter this issue in the future.
  3. Mar 4, 2012 at 6:05 PM
    #163
    Mr.Ed
    Mr.Ed Well-Known Member
    Wilbur's Barn
    08 TRD Rugged Trail V6
    Toytec Ulimate W/Dakar leaf pack, LR UCA'S, Undercover, Weather Tech, Block Heater
    Next time you are at that dealer ask them how they lubed it. I thought the whole trans had to come out.
  4. Mar 4, 2012 at 6:24 PM
    #164
    Mandy3206
    San Juan PR
    Yep they took it out for inspection and decided that only needed a new bearing and the pilot shaft to be lubed, I fought for a new transmission since the pilot shaft is part of the bellhousing but they deny it
  5. Apr 21, 2012 at 1:02 PM
    #165
    Tricky Mike
    Tricky Mike Member
    Well, add me to the list. Started noticing the dreaded chirp this afternoon. Thanks Toyota!!! Way to go. :mad:
    Oh well... Guess I'll be placing an order with URD.
  6. Apr 21, 2012 at 2:31 PM
    #166
    71roadrunner
    71roadrunner Active Member
    A little more info on these failures. After talking to 3 different individuals over the last couple years (including 2 Toyo Tech's who have R&R'd several T.O. Bearings), each case had a mismatch of the Bearing to the Pressure Plate (ie : LUK bearing to AISIN pressure plate or vice versa). In looking at the relevant TSB, Toyo pays particular attention to the matching of like vendors. It's beginning to look more and more like there were a bunch of mismatched clutch parts on the earlier built vehicles. Which could also explain why there are a lot of them going well over the 100k mark with no apparent problems.
    Also, I'm again posting the TSB :
    http://www.fjcruiserforums.com/foru...ut-bearing-chirp-squeak-fj-clutch-bearing.pdf
    And here's a thread with a bunch of Throw Out Bearing info (along with pics of some DIY work starting at #116) :
    http://www.fjcruiserforums.com/foru...475-throwout-bearing-trouble-6-speeds-12.html
  7. Apr 24, 2012 at 5:39 AM
    #167
    Tricky Mike
    Tricky Mike Member
    Thanks for the info...
    I haven't torn into it yet, but soon...
    URD kit is on a FedEx truck somewhere.
    I may use their bearing but machine my own stainless sleeve for w heat/shrink fit over the shaft. I'm not in love with the set screw approach, but I'll see when it all comes apart. It's probably fine.
  8. Apr 24, 2012 at 6:29 AM
    #168
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    Mine has been squeaking for about 40k miles. I've got about 90k on it now. The squeaking bothers me, but I figure I will run it til it dies and then put a new transmission under it. I figure the pilot shaft is buggered beyond recovery by now anyway.
    Wonder how much that would cost me....?
  9. Apr 24, 2012 at 6:43 AM
    #169
    Tricky Mike
    Tricky Mike Member
    Thanks again for that link... really helpful. Making me think I won't bother with the custom sleeve. Seems it's mainly an alignment issue with the fork, bearing and release cylinder. The biggest issue, though, in my somewhat uneducated opinion is that the TO Bearing NEVER stops spinning. I'm surprised I got 60K out of mine. This will never get fixed permanently with sleeves, new TSB parts, etc. Seems it needs a whole new design that only has the bearing spinning when you engage the clutch.
  10. Sep 20, 2012 at 2:37 PM
    #170
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
  11. Sep 26, 2012 at 12:53 PM
    #171
    TechJunky
    TechJunky Well-Known Member
    Eric
    Atlanta Ga
    Taco 4X4 6spd
    Ironman 4x4
    :(:(:(Add me to the list.
  12. Oct 16, 2012 at 8:05 AM
    #172
    TechJunky
    Eric
    Atlanta Ga
    Taco 4X4 6spd
    Ironman 4x4
    :pout:Truck has been in service since Saturday.... I'll post the outcome:bored:
  13. Oct 16, 2012 at 11:38 AM
    #173
    TechJunky
    Eric
    Atlanta Ga
    Taco 4X4 6spd
    Ironman 4x4
    New fork,
    new T/O bearing,
    and new slave cylinder.
    :thumbsup:
  14. Oct 16, 2012 at 11:56 AM
    #174
    ruler
    ruler Well-Known Member
    SoCal - Los Angeles - SGV
    08 Tacoma, TRD Sport, DC 4x4
    Fox Extended Travel Coilovers 2.5 (front), Fox 2.0 shocks (rear),Total Chaos UCA's, AllPro Expedition leaf pack, AllPro front plate style bumper,BHLM, GrillCraft MX series Grill, ATX Thug 17inch rims, Toyo Open Country MT (295,70,17), TRD CAI,Rear smoked LED tail lights, slimcubby HID Head Lights (50w 1200k), ADVMonster 60 Series 3600 Lumen LED Off Road Lights , Pioneer Avic-F700bt (navigation,head unit)
    had this issue for a while now, im outta warranty so Im guessing im screwed and gotta put up with this until my clutch takes a crap on me again?
  15. Oct 17, 2012 at 1:41 PM
    #175
    TechJunky
    Eric
    Atlanta Ga
    Taco 4X4 6spd
    Ironman 4x4
    Just got the truck back. Fixed.
    Parts List:
    31230-60241 Bearing assy...
    31236-35050 Support, release for
    31470-35181 Cylinder assy...
    Hope this helps someone....
    BTW, I bought this truck in June of this year. The dealer was able to pull the vehicle history for me. The T/O bearing was replaced in Feb 2010 @ 20K miles, but not the support or the slave cylinder.
  16. Nov 2, 2012 at 9:53 AM
    #176
    matadorCE
    matadorCE Well-Known Member
    Melbourne, FL
    '05 Prerunner Accesscab TRD Offroad
    So what are the implications of not treating this issue? Is it just the noise or is it making permanent damange to something in the transmission?
    I'm looking to buy an '05 that I test drove last night and I think I hear the T/O bearing noise during the test drive. The owner has never had the truck in for any of TSBs so I don't know how long it's been there.
  17. Nov 2, 2012 at 1:56 PM
    #177
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    It does help, thanks. any other part #'s ?
    Getting ready to have my clutch done soon, and I want to make sure I replace everything in there with the most current stuff as long as it is apart.
  18. Nov 3, 2012 at 5:21 AM
    #178
    TechJunky
    Eric
    Atlanta Ga
    Taco 4X4 6spd
    Ironman 4x4
    That is it. A customer service rep should be able to find the TSB and the technical details for replacing the parts.
  19. Nov 3, 2012 at 5:30 AM
    #179
    TechJunky
    Eric
    Atlanta Ga
    Taco 4X4 6spd
    Ironman 4x4
    I don't know for sure, but the chance of total failure? Can't shift, chewing up more parts, stranded on the side of the road.
    In the case of your shopping. Go to toy service and ask how much it would cost, then use the quote in negotiating your purchase.
  20. Nov 9, 2012 at 12:28 AM
    #180
    oteck
    oteck Member
    Igloos
    Toyota fan but no truck yet
    strange post but anyone still have their old TOB they want to send me? I'm not putting it in but i need it for a mock up on a new gearbox im setting up
