'TSB' for the THROW OUT BEARING (aka: clutch release bearing) is finally here ......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 71roadrunner, Dec 29, 2010.
  1. Dec 29, 2010 at 8:43 AM
    71roadrunner
    71roadrunner [OP] Active Member
  2. Dec 29, 2010 at 9:03 AM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, white lithium grease mod for creaky clutch pedal
    Good. And it's covered by the powertrain warranty. Hopefully mine starts making the noise before 5 years is up.
  3. Dec 29, 2010 at 10:38 AM
    AKTACO420
    AKTACO420 Well-Known Member
    RETODD
    Anchorage AK
    2009 tacoma
    bucket seats grille craft mesh grille and lights behind grille
    Anyone know when it will be for the 5 speed
  4. Dec 29, 2010 at 10:40 AM
    fatsac
    fatsac Well-Known Member
    Millbury, MA
    07 Tacoma DC Offroad
    Katz Leather, heated seats, Tint, KN Filter, OME 887, Camburg UCA, Dakar packs, 17x9 XD, 295/70 Toyo MT w cab mount chop, fender massage, Weathertechs, Black PC steps, skidplate, 2012 grill, Bushwacker painted flares, Nearly every TSB you can think of, TRD quickshift, All-Pro front w/ Skids, 9k winch, Tonneau cover, voodoo tailgate cap...
    Unless I'm missing something, this looks like what they've already been doing. R/R with the same junk. I'm still going to have the PDM kit installed next week. Rather spend the $200 and be done with it!
  5. Dec 29, 2010 at 10:44 AM
    TACK
    Nevada
    It says "Changes have been made to the clutch system to eliminate this noise."
  6. Dec 29, 2010 at 10:45 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Nice...but I'm out of warranty, so I guess I will just deal with the chirp until it comes time to replace my clutch.
  7. Dec 29, 2010 at 10:54 AM
    fatsac
    Millbury, MA
    I see said the blind man! So what to do here... should I get the PDM kit or just try this? If covered under powertrain, I'm good for two more years.
  8. Dec 29, 2010 at 11:02 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Figure 5. "It is normal to see wear on the transmission input sleeve." :mad:
    Still glad I have the URD solution sitting in my garage. Just need to time to install that thing.
  9. Dec 29, 2010 at 11:03 AM
    TACK
    Nevada
    If you're under warranty I would have the TSB done because it has Toyota's name behind it. If there are further problems you can go back to them.
  10. Dec 29, 2010 at 11:06 AM
    AZBACKCOUNTRY
    AZBACKCOUNTRY Well-Known Member
    Doug
    AZ-between the hammer and the anvil
    11' AC TRD OFF-ROAD 4x4
    Pelfreybilt front aluminum bumper,AVID off road weld on sliders, RCI Offroad IFS & transmission Skid (steel), RCI LCA skids (aluminum),upper grillcraft, relentless hi clearance bumper,OEM color matched front grill color, ARE MX camper shell, wet Okole realtree seat covers,pelfreybuilt hi lift mounts,ICON 2.5 Coil-overs extended,, ICON tubular UCA's. Allpro expo leafs, SS extended brake lines.Bilstein 110 extended rear shocks.prinsu Cabrac.dwreck pod mounts OKLED 18w cubes.Baja Designs Squadron-R Sport, LED Wide Cornering, Ambers fog/driving 20" IGGY LED Single Row bar.tepui awning,rotopax 2 gallon, TREDs and mount , 100 watt renogy solar panel.victron 20 amp Bluetooth charge controller,Pro comp wheels - cooper st maxx 285/75/16 tires. Skygear bussman fuse relay smart box. ARB 12v plug hard wired for ARB fridge. Pelfreybilt gas tank skid. Smittybilt X2O 10K winch
    Thanks for posting this. Getting tired of the cricket farm under the truck ... They seem to be multiplying... (LOUDER)>>>>>>
    AZbackcountry
  11. Dec 29, 2010 at 11:14 AM
    fatsac
    Millbury, MA
    I would like to do both but we'll see what the dealer says. The sleeve wear being normal is what the PDM or URD kit is all about!
  12. Jan 2, 2011 at 12:25 PM
    71roadrunner
    Yep, that one line in the TSB bothers me a little too.
    A Toyota mech from the FJ board says the new bearing is physically much larger (call it thicker or wider or taller when laying flat on a surface). Plus the fork arm support and slave cylinder are both new items shown in the TSB. It kind of looks like what they're doing is placing a heavier (and wider) bearing in there. The inner race would then be 'wider' to provide more contact area with the shaft. Under a load from the fork it will be less likely to wobble/rock on the shaft.
    Is this the answer for long term reliability in this area ? Who knows, I guess time and mileage will tell.
  13. Mar 25, 2011 at 2:43 PM
    11BSSG
    11BSSG Well-Known Member
    33°28'18"N /-86°48'2"W
    07 4X4 A/C 6 Spd
    Front-Billy 5100'2 @ 2.5, Rear- Wheelers 1.5" AAL w/ Billy 5100's, 17" XD Addict's, 285/70-17 Nitto TerraGrappler AT's, 20% Tint, UWS Low Pro Toolbox, N-Fab Nerf Steps, K&N, Black Head Lights, Hard Wired GPS, XM Onyx, Hardwired Radar Detector, Ultraguage, Thule Mtn Bike Lock, Sleeved Fog Light Housing, Black Emblems, Satoshi/Color Matched grille, Misc. Security Upgrades.
    Any updates? I just printed out the TSB and plan on going by the dealership with it in hand to see what we can do.
  14. Mar 25, 2011 at 2:51 PM
    jaredm85
    jaredm85 Member
    Colorado
    07 Tacoma Double Cab Short Bed TRD Sport
    I am so tired of that noise! i wish i would have know about this noise problem 6 months ago when i replace the clutch, i replaced the slave cylinder and all and at 10k miles and 6 months its noisy again, so pissed!
  15. Mar 26, 2011 at 6:54 PM
    merrit
    merrit Well-Known Member
    Las Vegas
    seriously depussified oc to
    subscribed
  16. Apr 7, 2011 at 5:16 PM
    michaelg589
    michaelg589 Well-Known Member
  17. Apr 7, 2011 at 5:18 PM
    11BSSG
    07 4X4 A/C 6 Spd
    Got it done today....VERY HAPPY WITH THE RESULTS. (Clutch is also much lighter, any thoughts on why?)
  18. Apr 7, 2011 at 5:21 PM
    sethr21785
    sethr21785 Well-Known Member
    Seth
    Lake Jackson TX
    00 Tundra
    prob cause the new slave cylinder...
  19. Jan 2, 2012 at 3:46 PM
    jaredm85
    jaredm85 Member
    Colorado
    just installed the TSB parts on mine, no more chirp. lets see how long it lasts!
  20. Jan 2, 2012 at 4:54 PM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    I tried to download and save the pdf file. But it say there was an error d/l it and the file is damaged and cannot be repaired. Anyone else getting this?
