TSB + Front 5100's + alignment HELP
Discussion in 'Suspension' started by lasllc, Mar 15, 2009.
  1. Mar 15, 2009 at 11:41 AM
    lasllc
    lasllc [OP] Well-Known Member
    SW Denver Burb
    13 SuperWhite DCSB Sport 4X4 Tow Pack
    SnugTop Super Sport, BedRug mat, Redline Tuning hood lifts, LED interior lights, 3D carpet protectors.
    Next week Toyota wil do the TSB. I plan on having the 5100's installed on the front the day before. That way Toyota can align the whole enchalada on their dime.
    09 Access cab, leer topper (180# or so), 3000 miles so suspension has no sag any where
    Questions considering the topper -
    I dont want to lift any more than needed to level the truck or close to it.
    Certainly want a rake down at the front, not back, if not exactly level.
    Currently, with the topper I am 21" wheel center to fender rear and 20" front.
    If I go 1.75 in front will the alignment be in spec, just barely in spec, or "as close as they can get it" ?
    And what is your thoughts on rake in this situation ?
    Due to the topper - does 0.85 look like a better setting for a level truck or slightly down at the front; I would assume that 0.85 should not be an alignment issue.
    Thanks for sharing your experience.
    Roger
  2. Mar 15, 2009 at 8:34 PM
    Bolo
    Bolo Well-Known Member
    San Diego
    2007 TRD Offroad
    Billet grill, nerf bars, TSB, Bilstein 5100s, Pioneer deck, Access Literider, shorty antenna
    Go with the .85. I had mine done at 1.75 the same day as the tsb. Initially it was exactly level. But when the springs settled, it lowered about half an inch relative to the front. So the front is a little higher, but not that noticeable. Especially since you're going to add a topper, go with .85.
  3. Mar 16, 2009 at 7:31 PM
    lasllc
    SW Denver Burb
    Thanks for the note.
    The TSB goes in on Thurs and the Front 5100s Fri.
    Will post pics with measurements.
  4. Jun 14, 2009 at 2:41 PM
    hoosiertaco
    hoosiertaco Well-Known Member
    I'm thinkin' of a topper and also some 5100's down the road, and I already have the Rear Spring TSB. How 'bout those pics??:D
