tsb leaf pack
Discussion in 'Suspension' started by Willcory, Jun 7, 2013.
  1. Jun 7, 2013 at 6:07 PM
    Willcory
    Willcory [OP] Well-Known Member
    Will
    San Antonio TX
    coming soon!
    2013 dbl cab 4x4
    The truck came with a 4 leaf pack and I had the tsb done they installed what seems to be softer/flatter 3 leak pack should i be concerned about saggin and riding my bump stops cause i pull a boat and dont want problems
  2. Jun 7, 2013 at 6:09 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Why would you get the TSB done on a truck with 4 leafs ?
  3. Jun 7, 2013 at 6:11 PM
    Willcory
    Will
    San Antonio TX
    coming soon!
    its part of the vibration fix
  4. Jun 7, 2013 at 6:14 PM
    Nickel
    Nickel Well-Known Member
    Diego
    Rio Rancho New Mexico
    2013 T/X TRD
    does turning tires to black wall out count? How bout added snug top rebel.
    ? I thought the tsb was to replace the three leaf pack with the four leaf for better load handling. My 2013 only has the three leaf pack, and I've asked for the tsb four leaf at the dealer twice, and both times they told me that there was no tsb yet for the 2013 model.
    I don't know why they would have switched to the three leaf, did you ask them or did they offer? I'd go back and ask for my four leaf pack to be reinstalled if I planned to carry anything over a couple hundred pounds in the back. Just my two cents, I'm not telling you what to do.
  5. Jun 7, 2013 at 6:31 PM
    Nickel
    Diego
    2013 T/X TRD
    Oh, vibration fix. Did it work?
  6. Jun 7, 2013 at 6:47 PM
    Tacoma Mike
    Tacoma Mike 42 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    There are two different part number sets for 3 and 4 leaf packs.
    If in fact you went from 4 to 3 you downgraded. Double check and take back.
    You won't be happy towing now
  7. Jun 7, 2013 at 8:01 PM
    Willcory
    Will
    San Antonio TX
    coming soon!
    I think it took care of some of the shudder in the tranny when coming to a stop but still got vibes when accelerate from a stop
  8. Jun 7, 2013 at 8:04 PM
    Willcory
    Will
    San Antonio TX
    coming soon!
    ya i'am! hooked up my boat and noticed its alot softer..
    part # on my invoice
    48210-35A90
    48220-35070
  9. Jun 7, 2013 at 8:05 PM
    MGMTacolover55
    MGMTacolover55 Well-Known Member
    Orygun
    2013 MGM Taco TRD Off Road
    floor Mats
    Well my truck came with the three leaf pack and it seems fine
  10. Jun 7, 2013 at 8:07 PM
    OZ-T
    Peter North
    British Columbia
    The Toyota springs suck period , doesn't matter if it's 3 or 4
  11. Jun 7, 2013 at 8:09 PM
    MGMTacolover55
    Orygun
    floor Mats
    It is sad the Toyota springs sag and break so easily considering my dad has a Chevy 3500 and the leaf springs are still good
  12. Jun 8, 2013 at 5:09 AM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
    True....
    The 4 leaf did fix my towing issue but if I was to do some serious towing I would be swapping out of a different set. MMMMMMM I have the 3 leaf set in the garage. A longer centering pin and I could have a 7 leaf set up. But I think it would only raise my ass end like a set of blocks and not do much more hehehe.
  13. Jun 8, 2013 at 5:15 AM
    OZ-T
    Peter North
    British Columbia
    http://www.wheelersoffroad.com/05uptacohdleafsprings.htm
  14. Jun 8, 2013 at 5:18 AM
    Tacoma Mike
    Southern Maine
    2011 Double Cab V6
  15. Jun 8, 2013 at 5:36 AM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    I answered you in the other thread too but when I had the driveline vibe TSB done they put new 4-leaf packs in, same as I had stock. Not sure why they put 3-leafs on yours. Didn't help at all though, really. Can't wait to pull them off and put my Dakars on in 2 weeks.
  16. Jun 8, 2013 at 7:46 AM
    kodiakisland
    kodiakisland Well-Known Member
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    5100s/1.6in eibachs, wheelers AAL, OME N182 rear shocks, 4.56s, Detroit truetrac, 255/75/17, SOSConcepts sliders
    So are the 2012 eligible for the TSB 4 leaf springs? Mine came new with 3 springs and sags with just a leer top on it.
  17. Jun 8, 2013 at 7:47 AM
    bjboucher
    Brad
    San Antonio, Texas
    Not the leaf TSB. That's only up to 2011. If you complain about drive line vibrations though, part of that TSB is to replace the leafs.
  18. Jun 8, 2013 at 7:58 AM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    If u put anything in the bed or tow anything u will need the 4 leaf pack at minimum. Some people put different springs or a aal as a fix.
    I am running the 3 leaf now, & can not put a 4 wheeler in the bed without hitting the bumpstops & riding completely unsafe. You will not be happy towing your boat with the 3 leaf. Take it back asap!
  19. Jun 8, 2013 at 8:10 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Sounds like they gave you the 3 leaf pak to drop your pinion angle to try and fix driveline vibes.
    That's a totally different TSB than the issue back in 07. It was a handling /hauling issue back then....I have the 4 leaf pak. Surprisingly - I had no driveline issues regardless of the springs on my truck.
    If the springs are exactly the same (3 & 4) since 05...sounds like you have other issues and they're just swapping springs to try and fix it.
    If its under warranty - keep taking it back!!!
  20. Jun 8, 2013 at 8:30 AM
    kodiakisland
    NW Arkansas
    12 AC 4x4 2.7L 5MT
    Sounds like I need to go the AAL route to be able to haul much stuff in the bed.
