TSB: Leaf Springs - Leveling
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ShaneHD, Mar 6, 2011.
  1. Mar 6, 2011 at 9:23 AM
    ShaneHD
    ShaneHD [OP] Taco Tuesday
    Fort Worth TX
    2010 Tacoma CrewCab TRD
    I just had the TSB for the leaf springs on my 2010 Taco CrewCab TRD done. The truck rides and feels so much better. Now, not that this is a huge deal, but my truck now slopes forward (more than I would like).
    I have read up on these Bilstien 5100's and wondered if that was all I needed to have put on in order to level out my front end. I have never lifted/leveled out a truck before and would most likely have a local shop put these on, but how easy is it?
    Is this all I need? Using stock wheels and speakers as well.
  2. Mar 6, 2011 at 9:29 AM
    Victoria2657
    Victoria2657 Well-Known Member
    Valentina
    New Mexico
    2011 TRD Sport PreRunner, Speedway Blue
    I was wondering the same thing.
  3. Mar 6, 2011 at 9:55 AM
    alx_alx_69
    alx_alx_69 Well-Known Member
    Alex
    Hope Mills, North Carolina
    I have done alot of research on this website, I have ordered some billies for my front end after having the TSB done, and if you set them at 1.75, should level your truck out.
  4. Mar 6, 2011 at 10:08 AM
    ShaneHD
    Fort Worth TX
    How hard are these to swap out? Are they better than the stock Bilstien shocks?
  5. Mar 6, 2011 at 10:10 AM
    vermintrex
    vermintrex Well-Known Member
    Vancouver
    TRD SPORT Shorty
    BFG A/T KO 265/70/17, '11 FJ wheels, 5100's all four corners, Eibach springs, 1/4" Taco lean spacer, Leer 100XR, WeatherTech liners, trimmed mud flaps and I farted in it.
    Type "Bilstein 5100" in the search field and you'll get a good solid 3 months of reading material.
    1.75 on the 5100's and the 4 leaf TSB pack will get you close to level, possibly a tad nose high once the leaf pack settles, or you load the truck bed.
  6. Mar 6, 2011 at 1:38 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    If you have the tsb and front billies you need set them at 1.75" to have the back just a tiny bit higher. If you dont have the tsb and get billies then set the front to .85" to level it.
  7. Mar 6, 2011 at 3:40 PM
    dbarn
    dbarn Well-Known Member
    Texas
    Tacoma 4X4 V6
    Having had the TSB and four leaf pack done to mine a year ago, my suggestion would be to go with a .85 setting if you intend to haul any kind of a load. The TSB will settle and the 1.75 setting will put you nose high with a slight to moderate load. At least it did for me.
  8. Mar 6, 2011 at 3:49 PM
    B_brand
    B_brand Well-Known Member
    Brandon
    Oklahoma
    Mine is a 2010 DC as well. I also have the TSB done in the rear. I put Bilstein 5100s on all four corners. I left the front ones set at zero, but also used some Toytec springs in the front. I got about 1.6" of lift in the front. I also used the 1/4" top plate spacer on the drivers side, so I got a bit more lift on that side. I love the look and ride now!
  9. Mar 6, 2011 at 4:12 PM
    nelztaco
    nelztaco Well-Known Member
    Neil
    Levittown, PA
    09 TRD Sport DCLB 4x4 SW
    UNDERCOVER, EIBACH COILS, TSB 4 LEAFS, TRD WHEELS, 255/85R16 KM2
    I installed eibachs in front after I got the tsb done. The truck still has some rake to it. They didn't completely level it out. But I love the ride now.
  10. Mar 6, 2011 at 4:14 PM
    Detective_Dan
    Detective_Dan "Place original and witty user title here"
    Colorado Springs
    2014 DCSB Beast / 2016 Yamaha FZ-07
    Pelfreybilt Front Plate Bumper, Brute Force Fab High Clearance Rear Bumper, Pelfreybilt Sliders, OME 886/Dakars, SCS F5's, 33" Ko2's, Cobra 75WXST/3' Firestik, oil catch can, aero turbine 2525, rear differential breather extension, bedmat, weathertech digital fit front/rear, BHLM, custom shiftknob (made by me),
    you mean stock wheels and TIRES right? ;)
  11. Mar 6, 2011 at 4:20 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    After doing the TSB, the rear end lifted about 1.5 inches.
    Ordered the 5100s to level the truck.
    got the 5100s about a week later.
    just prior to installing the 5100s, i remeasured the back end.
    the truck settled to only 1 inch above the stock height.
    I was planning on setting the 5100s to 1.75
    but when the back end settled to only a inch,
    i went with the .85 setting instead.
    the truck sits with a slight forward rake, just like stock
    but i think the 1.75 would make it nose high.
    <<< - check out all my photos and see what you think
  12. Mar 6, 2011 at 4:24 PM
    Detective_Dan
    Colorado Springs
    see my pics above mike. mine are at 2.5 with the TSB and it sits damn near level. i have had the TSB for about 8 months so it has had plenty of time to settle
  13. Mar 6, 2011 at 7:21 PM
    ShaneHD
    Fort Worth TX
    After looking online, there are a ton of different models and prices.
    What exact model do I need for my 2010 Tacoma CrewCab Shortbed TRD? Where is the best place (price) to get these? Do I only need 2? Again, I just had the TSB done on the rear leaf springs.
  14. Mar 6, 2011 at 8:34 PM
    ShaneHD
    Fort Worth TX
  15. Mar 6, 2011 at 9:57 PM
    skistoy
    Western New York
    its up to you
    I only put the 5100s on the front, got new shocks with the TSB in the rear.
    but i think i paid 200 just for the fronts, so sounds like a good price
  16. Mar 7, 2011 at 5:12 AM
    ShaneHD
    Fort Worth TX
    If I got them all the way around, do I need to set them all at 1.75?
  17. Mar 7, 2011 at 5:25 AM
    ShaneHD
    Fort Worth TX
  18. Mar 9, 2011 at 4:38 PM
    ShaneHD
    Fort Worth TX
    I bought the 5100's from downsouth and they will be here tomorrow. What a great place to buy from!
    With this said, I have only ever installed rear shocks before. Is there a detailed walk through of how to swap out the shocks? What all tools do I need (I don't have an impact gun)?
